Old 06-11-2002, 12:18 AM   #1
zardiw
Faster horses, yw, ow, mm
Unhappy 292 in a C60 making oil....
The oil level has been increasing. Oil pressure about 5 . Drained a little out of the pan and it's pretty thin...i.e. gas mixing with it I guess. Any ideas why? My guess is a stuck carb float, but am willing to listen to any other ideas that you all have.....z
'73 C20, 383, 3500 leaf springs, 38.5 Mickey Thompson Baja Claws (More ground clearance than an H2 Hummer), Performance Distributor (Tits!!) w/Clear cap (awesome at night), Edelbrock intake+IAS shocks, Tri Y headers, Dr. Gas Xover(for that NASCAR sound).
zardiw is offline   Reply With Quote
Old 06-11-2002, 12:19 AM   #2
zardiw
PS. The gas tank is behind the seat, and above the engine........z
Old 06-11-2002, 12:21 AM   #3
68 Stepside
huh?
68 Stepside's Avatar
Sounds like you're getting WAY too much fuel. I'd try swapping carbs.
Also, does it have an electric fuel pump? Some did, don't know if that was stock or not, but if it does, also check your fuel pressure regulator.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-11-2002, 12:23 AM   #4
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Making oil? Good lord, you've got a gold mine on your hands!
I don't know what's causing it, but if it is gas mixing with the oil, you want that stuff out of your engine pronto. Not real good for lubricating main bearings and such..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 06-11-2002, 12:32 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yup, I agree, sounds like fuel gettin into the crankcase.
Either floats, or fuel dripping into the intake and not burning...just washing past the rings.
Old 06-11-2002, 12:32 AM   #6
zardiw
Lol. I WISH it were really making it...It's got a stock mechanical fuel pump btw. The level is so high that it's forcing it out of the dip stick tube when it's running (I'm not running it til I a)find out what's wrong, and b) refill it with oil)....z
Old 06-11-2002, 06:20 AM   #7
Dan69 step
Check your fuel pump. It sounds as though it is leaking internally and directly into your pan. I wouldn't drive it until the problem is corrected.
69 short step
68 50th Anniversary Gold/ White lwb
72 2wd Blazer
63 Studebaker Avanti
85 Avanti
66 Studebaker Cruiser
49 Studebaker pickup
3-49 Studebaker 1 1/2 truck
94 White/ GMC coe (cabin hauler)
95 chev
2015 chev Duramax 2500
Dan69 step is offline   Reply With Quote
Old 06-11-2002, 06:43 AM   #8
Sammy
Exclamation
If you have a increase in the oil pan of fluid ..Its about a 95% chance ur fuel pump is feeding it..You better get the fuel pump off in a hurry..Suppose you could smell the fuel in the oil mixture!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-11-2002, 07:38 AM   #9
tom hand
CCRider
tom hand's Avatar
I agree if the oil level is increaseing, the fuel is coming from the fuel pump seals right into the oil pan. If you were getting that much gas thru the carb it would foul the plugs and quit running. Replace the pump before it blows up.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-11-2002, 10:41 PM   #10
racedvl
racedvl's Avatar
Exclamation
GET THAT FUEL PUMP OFF OF THERE!!!!!!!!!!!!!
racedvl is offline   Reply With Quote
