Old 11-21-2021, 11:48 PM   #2576
C101972
Re: What did you do to your truck today.The 3rd chapter
Doing frame off, mounting and plumbing of brake lines, traffic-bar getting the rear fuel tank ready for final mounting.
C101972 is offline   Reply With Quote
Old 11-22-2021, 12:19 AM   #2577
KQQL IT
At the body shop.
KQQL IT's Avatar
Holley fuel pressure regulator.
The Mr. Gasket one wasn't working out.
Need a few more fittings to clean up the rube Goldberg plumbing mess
Old 11-22-2021, 01:33 AM   #2578
30772
Mounted new wheels and tires then went for a drive! First time after a nearly three year complete restoration -
30772 is offline   Reply With Quote
Old 11-22-2021, 02:09 AM   #2579
Accelo
Accelo's Avatar
Tested my AM radio. Hasn't' be turned on in over 25 years. Works perfectly!
Years ago A coworker at fiber sunk his truck in the Columbia river while launching his boat. A diver was required to attach a line so they could drag it out from 50 feet of water. He got it all running again. But the radio didn't work. A month later the radio started working again. I guess they are tough!
Accelo is offline   Reply With Quote
Old 11-22-2021, 08:28 AM   #2580
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by zellway View Post
Slowly getting my 67 fixed up. A long neglected work truck is starting to look much better.
Looks good
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-22-2021, 08:31 AM   #2581
Jiggers72-GMC
Jiggers72-GMC's Avatar
Accelo, that's a good one about the radio, hehehe ....... great work on your trucks guys, looking good.
30772 & Zellway, good to see them on the road again.
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 11-22-2021, 09:43 AM   #2582
Davidf
Installed a Borgeson steering box. My original type Saginaw box was not worn out, but started leaking slightly shortly after completing the LS swap.
Let me tell you, the Borgeson 3 turns lock to lock box is a major improvement. The box requires a square body rag joint (steering coupler).
Davidf is offline   Reply With Quote
Old 11-22-2021, 10:04 AM   #2583
KW5413
KW5413's Avatar
Installed new passenger side window. All the advice / videos here were a great help providing a birds-view. I'm really glad to have had that.
The problem we had is the truck is a full on custom with aftermarket Power windows that had its own set of original installation problems we had to deal with. One of the things you have to deal with when buying someone else's build. Which, I don't have a problem with...you just have to accept to go with the flow.
Next up is to pull the panel on the driver's side window and fix up that install...before that glass breaks :0
KW5413 is offline   Reply With Quote
Old 11-28-2021, 11:27 AM   #2584
Chevys4life
Finally getting this interior to look like something. Installed my rebuilt instrument cluster, dash pad, AM radio and new steering wheel. It is always something when you make changes. Now I need to figure out why the cluster lights aren't working and try to figure out how to get the horn contact button to work.
Chevys4life is offline   Reply With Quote
Old 11-28-2021, 11:51 PM   #2585
zellway
zellway's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Finally got some a/c now that it’s not the weather to enjoy it
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 11-29-2021, 09:04 AM   #2586
Jiggers72-GMC
Nicely done Erik, how long did it take you to install the whole ac package ???
Old 11-29-2021, 12:46 PM   #2587
NoStopN
NoStopN's Avatar
Erik, I'm guessing those 3 rotary dials can't be removed from that panel?
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 11-29-2021, 09:19 PM   #2588
zellway
zellway's Avatar
I have only done the interior part of the install and heater hoses. I would say it was about 5 or 6 hours. I took my time to line it all up and clean up some under the dash so I might have been able to knock it out faster.
Erik
Old 11-29-2021, 09:20 PM   #2589
zellway
zellway's Avatar
This was a optional control vintage air offers. The kit comes with what you need if you want to keep the stock controls. I did the same thing in my suburban. It free's up a ton of room under the dash and makes running hoses and wires much cleaner.
Erik
Old 11-30-2021, 10:43 AM   #2590
1968 K20
Nice truck, that's a good day when you finally get to take it out for a drive after all that time. Really looks good.
1968 K20 is offline   Reply With Quote
Old 11-30-2021, 11:41 AM   #2591
Davidf
Replaced my in cab fuel tank due to previous damage and poor repair (not by me) that started leaking. Also, wrapped the tank in sound deadener to make the fuel pump quiet...it worked.
Old 11-30-2021, 12:38 PM   #2592
old51sedan
old51sedan's Avatar
Looks great, I'm just finishing up doing mine also. I wish I had gotten the 3 buttons for the controls now. Did you happen to install your glove box yet, kinda scares me to think about pushing it in there, afraid it might break?
old51sedan is offline   Reply With Quote
Old 11-30-2021, 12:53 PM   #2593
paul blair
I found the water leak in fire wall cowling. Had to use a Greenlee hole cutter (4in. hole) in upper cowl for access. Cleaned, treated rust and used 3M 8300 seam sealer to bridge the leak. The old seam sealer was a foam type material. No leaks now..
paul blair is offline   Reply With Quote
Old 11-30-2021, 01:51 PM   #2594
zellway
zellway's Avatar
glove box went in okay. it has some cuts in it to let you fold the top in a bit. overall it was not too bad. I have seen some people not put the side in. I decide to place it in just like the old cardboard one was. Its not too bad.
Erik
Old 12-02-2021, 04:38 AM   #2595
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have one of those in the box to be put on in the Spring and bought their rag joint too. I also bought their Power Steering pump and hoses.. I was hoping someone would post their experience with the Borgeson box.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is online now   Reply With Quote
Old 12-11-2021, 08:24 PM   #2596
KQQL IT
At the body shop.
KQQL IT's Avatar
Made a new line up.
Added a support bracket.
Ran out of black fittings
But it's not gonna flood anymore. 5psi running creeps to 7 after you turn it off.
About over carburetors altogether.
Old 12-11-2021, 09:32 PM   #2597
C101972
Finished the brake lines, final mounting of fuel tank, rough plumbing of fuel lines.
Old 12-11-2021, 09:33 PM   #2598
C101972
Of course pictures have to be sideways.😞
Old 12-11-2021, 10:27 PM   #2599
pjmoreland
pjmoreland's Avatar
Those hard lines running all the way to the tank look very clean.
pjmoreland is online now   Reply With Quote
Old 12-11-2021, 10:35 PM   #2600
C101972
Copper lines, they are easy to bend and flare, had to make the differential brake lines. Differential is 2-1/2” narrower each side.
