#2576 |
![]() Join Date: Jan 2021
Re: What did you do to your truck today.The 3rd chapter
Doing frame off, mounting and plumbing of brake lines, traffic-bar getting the rear fuel tank ready for final mounting.
Posted via Mobile Device |
#2577 |
At the body shop.
Holley fuel pressure regulator.
The Mr. Gasket one wasn't working out. Need a few more fittings to clean up the rube Goldberg plumbing mess
" That didnt make it any newer " " Dont antique the equipment " |
#2578 |
Mounted new wheels and tires then went for a drive! First time after a nearly three year complete restoration -
#2579 |
![]() Join Date: Mar 2015
Tested my AM radio. Hasn't' be turned on in over 25 years. Works perfectly!
Years ago A coworker at fiber sunk his truck in the Columbia river while launching his boat. A diver was required to attach a line so they could drag it out from 50 feet of water. He got it all running again. But the radio didn't work. A month later the radio started working again. I guess they are tough! |
#2580 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looks good
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#2581 |
![]() Join Date: Mar 2021
Accelo, that's a good one about the radio, hehehe ....... great work on your trucks guys, looking good.
30772 & Zellway, good to see them on the road again.
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#2582 |
Installed a Borgeson steering box. My original type Saginaw box was not worn out, but started leaking slightly shortly after completing the LS swap.
Let me tell you, the Borgeson 3 turns lock to lock box is a major improvement. The box requires a square body rag joint (steering coupler). |
#2583 |
Installed new passenger side window. All the advice / videos here were a great help providing a birds-view. I'm really glad to have had that.
The problem we had is the truck is a full on custom with aftermarket Power windows that had its own set of original installation problems we had to deal with. One of the things you have to deal with when buying someone else's build. Which, I don't have a problem with...you just have to accept to go with the flow. Next up is to pull the panel on the driver's side window and fix up that install...before that glass breaks :0 |
#2584 |
Finally getting this interior to look like something. Installed my rebuilt instrument cluster, dash pad, AM radio and new steering wheel. It is always something when you make changes. Now I need to figure out why the cluster lights aren't working and try to figure out how to get the horn contact button to work.
#2585 |
Finally got some a/c now that it’s not the weather to enjoy it
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
#2586 |
Nicely done Erik, how long did it take you to install the whole ac package ???
#2587 |
![]() Join Date: Jul 2016
Erik, I'm guessing those 3 rotary dials can't be removed from that panel?
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#2588 |
I have only done the interior part of the install and heater hoses. I would say it was about 5 or 6 hours. I took my time to line it all up and clean up some under the dash so I might have been able to knock it out faster.
#2589 |
This was a optional control vintage air offers. The kit comes with what you need if you want to keep the stock controls. I did the same thing in my suburban. It free's up a ton of room under the dash and makes running hoses and wires much cleaner.
#2590 |
![]() Join Date: Aug 2019
#2591 |
Replaced my in cab fuel tank due to previous damage and poor repair (not by me) that started leaking. Also, wrapped the tank in sound deadener to make the fuel pump quiet...it worked.
#2592 |
Looks great, I'm just finishing up doing mine also. I wish I had gotten the 3 buttons for the controls now. Did you happen to install your glove box yet, kinda scares me to think about pushing it in there, afraid it might break?
#2593 |
![]() Join Date: Jan 2016
I found the water leak in fire wall cowling. Had to use a Greenlee hole cutter (4in. hole) in upper cowl for access. Cleaned, treated rust and used 3M 8300 seam sealer to bridge the leak. The old seam sealer was a foam type material. No leaks now..
#2594 |
glove box went in okay. it has some cuts in it to let you fold the top in a bit. overall it was not too bad. I have seen some people not put the side in. I decide to place it in just like the old cardboard one was. Its not too bad.
#2595 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#2596 | |
At the body shop.
Added a support bracket. Ran out of black fittings But it's not gonna flood anymore. 5psi running creeps to 7 after you turn it off. About over carburetors altogether.
#2597 |
Finished the brake lines, final mounting of fuel tank, rough plumbing of fuel lines.
#2598 |
#2599 |
![]() ![]() Join Date: Jan 2005
#2600 |
