11-14-2021, 10:06 PM | #876 |
Re: Frankentruck
Yesterday's adventure in Savannah with Frankentruck:
Got to have the mossy trees, of course The big bridge River Street with the Georgia Queen Bonaventure Cemetery After that, I headed for Milledgeville. As the sun was dropping behind the trees, I wanted to find a tree with good, fall colors. Found one on a 2 lane between Adrian and Wrightsville. Not much farther up the road, I spotted a crewcab square up on a small dam. I took the risk and pulled up. Met some nice guys fishing on their farm. We talked trucks for about 30 minutes, I took a few sunset pictures, then made the last hour of the trip back in the dark. With some rough calculations, I believe Frankentruck is getting around 13 mpg combined. Again, that's rough and the speedo reads 64 when I'm going 70, so I don't know how accurate the odometer reading is
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 11-14-2021 at 11:11 PM. |
11-14-2021, 10:41 PM | #877 |
Re: Frankentruck
Nice pictures Christian...I like the cargo ship in the background under the bridge! Did anyone complain about taking pictures on River St?
11-14-2021, 10:51 PM | #878 |
Re: Frankentruck
Thanks, Andy! No one directly complained to me. I noticed several other people taking pictures as I was driving through. I ended up driving through twice because there were way too many cars behind me on the first time through
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-14-2021, 11:22 PM | #879 |
Re: Frankentruck
Thanks for sharing the pictures
They bring back memories of My visit to Savannah We went to Lady and Son's Restaurant. Stayed down on the river in a room there.
11-14-2021, 11:29 PM | #880 |
Re: Frankentruck
I got to stay at the Alida hotel. It's a fairly new one not directly on the river, but right across the street from the old power plant. It was definitely the nicest hotel I've ever stayed in. Thankfully, Georgia College is reimbursing me since I did go down for work purposes
11-24-2021, 07:17 PM | #881 |
Re: Frankentruck
Made it home yesterday evening, but not with a slight adventure.
Since the gas gauge isn't reading right, I thought I had more fuel in the tank from looking inside the fill hole than what i actually did. Ran out of gas 2 miles from the restaurant I was planning to meet my parents for dinner at. Got some gas, enjoyed some food, made it home. Today, I got a chance to put my birthday present from last month together. My many years of Lego sets paid off. Also diagnosed why my Dakota wouldn't start after I parked it back when I brought Frankentruck to Milly. I had power to the starter wire, power to the solenoid wire with key turned to start. I flipped all the relays around to make sure, but still nothing. Finally, I pulled back tbe blue, rubber cover over the wire from the solenoid to the starter motor and found a bunch of corrosion on the wire. Cleaned that, and the bendix started clicking, but wouldn't engage. Wacked it a couple times with a hammer and sure enough, she started right up again. Going to keep that hammer in the truck for a while, just in case
11-25-2021, 07:46 PM | #882 |
Re: Frankentruck
Figured out why the fuel gauge stopped working well. The float was full of fuel!
There was a very small crack that I pressed on and there's the hole. Jb weld is most likely not a permanent fix, but hopefully it will work long enough until I can swing by Summit Racing to pick up a new one
12-01-2021, 09:09 PM | #883 | |
But Found Her 25yrs Later!
Re: Frankentruck
12-02-2021, 12:59 AM | #884 |
Re: Frankentruck
Thank you! They aren't too bad for a smart phone that's about 4 years out of date
Current phone is a Samsung Galaxy S8 if anyone was wondering
12-02-2021, 01:09 AM | #885 |
Re: Frankentruck
The annual tradition continues!
Also, update on the float. I don't know if it's reading accurately yet. When I filled up, I'm not sure that I got a full tank. I'm also not sure that I put the float back on the arm in the right spot. If I put it back on the wrong way, I'm wondering if it could be hitting the side of the tank and not going all the way to full when the tank is full. One other thing: I found out in a different thread that I was using tapered seat spark plugs in non tapered seat heads. Whoops. I robbed the plugs out of the old engine, then found a second set I had kept. I forgot I had changed the plugs twice on the old engine. Anyways, I also spent a little more time messing with the idle mixture screws and a vacuum gauge while I was back home. Seems to be running good still and doesn't smell like raw fuel as much at idle now. I checked one of the plugs today and it did look better than before, but I'm really considering getting an AFR gauge to better tune the carb in all driving conditions. Sure, it would be nice to have an EFI system, but the carb hasn't treated me wrong yet, so I feel inclined to keep it around for awhile longer
12-02-2021, 01:41 AM | #886 |
Re: Frankentruck
I personally like the personality of a carbed car or truck I think it gives them charictor.
But I grew up with my parents driving old carbureted cars and I will always remember them pumping the pedal and cranking until the engine started lol. guess it's just a childhood memory thing. Those are some good pics of frankentruck btw!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! Last edited by straight6chevyguy; 12-02-2021 at 01:49 AM. |
12-02-2021, 03:15 PM | #887 | |
Re: Frankentruck
Switching to an electric choke made a world of difference in the drivability year round. The Quadrajet I'm running will start every time with one pump of the gas unless it's been sitting for longer than a week
12-04-2021, 09:56 PM | #888 |
Re: Frankentruck
Went up to Winder for a car show this morning.
A good amount of nice Chevy trucks were there, but only three 60-66 trucks
12-04-2021, 11:44 PM | #889 |
Re: Frankentruck
One thing I always look for when people mount their beds is if they get things lined up correct. It erks me when it isn't. You got yours right on.
12-05-2021, 03:48 PM | #890 |
Re: Frankentruck
Thank you for the compliment. I tried to get it as best as possible with the frame I have. I believe the frame is slightly tweaked from when the truck was wrecked, so the passenger bedside is slightly higher in the front than in the rear. Once I have the frame straightened, it should look even better than it does now
12-05-2021, 04:33 PM | #891 | |
Re: Frankentruck
I'm erkd again.
12-05-2021, 05:32 PM | #892 |
Re: Frankentruck
Perfect!
Hopefully I'll get it into the frame shop over Christmas. Once that's straightened out, you and I both won't be erkd anymore
12-08-2021, 07:18 PM | #893 |
Re: Frankentruck
I bought these a while ago, but finally had a chance to start the caster mod. My dad and I don't have a working drill press, but my adopted church family in Milly has one. Thankfully, he had a 5/8" drill bit. We had it set to 620 rpms and with plenty of cutting fluid, new holes were drilled fairly quickly. The drill press is definitely the way to go
12-08-2021, 08:28 PM | #894 |
Re: Frankentruck
Fantastic mod. I fully approve.
I usually move 3/4", but I usually also have to bash the lip of the crossmember to clear the (larger squarebody) bushings.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-08-2021, 09:46 PM | #895 | |
Re: Frankentruck
12-08-2021, 10:01 PM | #896 | |
Re: Frankentruck
That's not a bad idea. I'll have to look into it. The other option is to try to fix the drill press my dad and I have. It spins, but the chuck is frozen up on it. Might try to fix it over Christmas
12-09-2021, 12:20 AM | #897 |
Re: Frankentruck
When you get that Drill press going.
I suggest 2 things Center Finder Center Drills
12-09-2021, 08:42 PM | #898 |
Re: Frankentruck
Getter-Done,
Thanks for the suggestions. I like that center finder
12-11-2021, 06:43 PM | #899 |
Re: Frankentruck
Got back from Milledgeville on Thursday. Yesterday was another C10 Club Georgia meet, so drove up for that. Was then able to help return the lights used for lighting up the location. This morning was a show at Auto Metal Direct's warehouse. The rain, and cost, was a deterrent I think, but there were still some nice trucks. I didn't take a bunch of pictures though
12-11-2021, 06:44 PM | #900 |
Re: Frankentruck
Here's my favorite from the show. A home built 64
