11-14-2021, 08:05 PM | #601 |
Moderator
Re: New 64 Stepper Project
Intersting article on the 200-R4 - https://www.motortrend.com/how-to/cc...mission-build/
11-14-2021, 10:13 PM | #602 | |
Thanks for sharing the link.
11-14-2021, 10:46 PM | #603 | |
Moderator
Oh, did you ever get that converter dust cover?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 11-15-2021 at 09:45 AM. |
11-15-2021, 12:00 PM | #604 | |
I'd read where that source was hit & miss on things. Ultimately, we went back/forth on 'interpretation' of the communications. What seemed so obvious in his mind did not translate over to what was written in his answers as there were key details left out. Lesson learned. They'll only be a final-option source in the future.
01-06-2022, 08:02 AM | #605 |
Moderator
Well it's winter, I thought I'd do a little cleanup and exhaust manifold change-out.
01-06-2022, 12:38 PM | #606 |
Yup, definitely winter! Very tidy looking brackets on your engine.
01-06-2022, 07:28 PM | #607 |
Moderator
The manifolds I'm installing.
01-06-2022, 08:48 PM | #608 |
Sweet....
01-07-2022, 07:59 AM | #609 |
Moderator
01-07-2022, 08:14 AM | #610 |
Moderator
I expect that my engine will run a bit warmer after I conduct the carb re-work as I am changing the jets and the metering rods. When I pulled the plugs they all showed a very rich condition. After searching the internet I find the Street Demon comes in a very rich set-up from the factory for some reason. I think I have it nailed though.
01-07-2022, 08:18 AM | #611 |
they look great - very period. are they chrome plated or ceramic - love ram horn style manifolds - very clean work...
1965 c10 project - how does all this stuff go back together... |
01-07-2022, 09:33 AM | #612 |
Moderator
Smoothed them ceramic coating.
01-07-2022, 09:58 AM | #613 |
Looking at some on speedway motors that say they are smoothed where did you get yours ceramic coated?
01-07-2022, 10:49 AM | #614 | |
Moderator
Just torqued em up this am.
01-07-2022, 12:41 PM | #615 |
The new manifolds look great.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
01-07-2022, 01:21 PM | #616 |
Moderator
01-08-2022, 11:25 PM | #617 |
Did those reduced head bolts come with the manifolds or did you get ARP bolts?…
Those look great on that engine…… |
01-08-2022, 11:47 PM | #618 | |
Moderator
Thank you. Just FYI the bolts Speedway sent were too long for the four end port bolts. I ordered everything from Alan's Fasteners: ARP 3/8-16 HEX FLANGE BOLT STAINLESS STEEL Product ID: 0520 Description: ARP 3/8-16 HEX FLANGE BOLTS STAINLESS STEEL,3/8 WRENCHING,.625 FLANGE or ARP 3/8-16 HEX STAINLESS STEEL FLANGE BOLT 7/16 WRENCHING Product ID: 0520A Description: ARP 3/8-16 HEX STAINLESS STEEL FLANGE BOLTS,7/16 WRENCHING,.698 FLANGE https://www.allensfasteners.com/sear...ze=80&sortBy=3 And ARP STAINLESS STEEL WASHER WITH CHAMFER Product ID: 22247An https://www.allensfasteners.com/sear...1&txtCatName=2
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-09-2022 at 12:02 AM. |
01-09-2022, 09:37 AM | #619 |
Moderator
Almost ready to install the motor back in.
01-09-2022, 03:49 PM | #620 |
Outstanding!
01-09-2022, 05:54 PM | #621 |
Moderator
Thanks Scotti.
I just got the engine stabbed in today and started torquing the trans to engine bolts. What a pain in the keester that is. I took a break, think I'll continue tomorrow.
01-12-2022, 05:59 PM | #622 |
Moderator
Well I'm still at it, haven't given up yet.
01-13-2022, 01:45 AM | #623 |
Man, that would make me nervous to remove and reinstall that engine with all the new paint around it. Good idea with the towels and pads
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-13-2022, 08:14 AM | #624 | |
Moderator
Also just FYI I purchased an articulating engine lift device from Mac's years ago. The first time I installed the engine I had removed the front end, easy. This time I thought it would work as is. Kind of tricky had to remove it over the side fender area. I'm sure a simple engine lift plate would have been better in this instance. I just didn't have one. And I'm not removing the hood!
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-13-2022 at 08:28 AM. |
01-13-2022, 12:23 PM | #625 |
I'm just glad to be here!
Your truck is just outstanding! and now you made improvements. Sure hope to get to see this one in person someday.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
