Old 01-12-2022, 01:30 PM   #1
Slimpickins
2WD lift kit for c20
Whats up everyone, Ive got a 1971 c20 that I want to give a little more beefy look. Ive done the 1 ton springs and spacers but it still doesn't have the right look to me. There is a guy on YouTube, harmon garage that used lift spindles for an 89-99 chevy and swapped the brakes over, tie rod ends, and ball joints. Has anyone done this on a C20. I know they make a kit for the 2500. Id like to keep my 8 lugs? Thank you!
Slimpickins is offline   Reply With Quote
Old 01-12-2022, 04:48 PM   #2
j_cst_10
j_cst_10's Avatar
Re: 2WD lift kit for c20
I did a 1" body lift on my truck for necessary drivetrain clearance. Purchased aluminum body mount spacers for the cab and core support and made my own for the bed.
This isn't a spring lift obviously but gives you some clearance and isn't noticeable from the outside.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 01-14-2022, 06:04 AM   #3
GMC71k20
The member truckenrc used 2008 lift spindles - he's not active but you can do a member search
This Instagram link is more involved - lift and wider control arms from airbagit.com
Also has Hanneman fiberglass fenders
https://www.instagram.com/p/CSQHL6NArID/
GMC71k20 is offline   Reply With Quote
Old 01-16-2022, 08:10 PM   #4
Slimpickins
Yeah thats a good look! a little more pre-runner than Im looking for, but Ill search that member, thank you!
Old 01-17-2022, 04:50 PM   #5
GMC71k20
Keep us posted if you try this out! Good luck
2wd, c20, lift
