01-20-2022, 12:41 AM | #951 |
Re: Frankentruck
It was only a matter of time until it happened, but it finally did. When I installed some halogen bulbs a while back, the retaining ring on the driver's side had a slight bend in one spot. I didn't realize it until I tightened up the screw and the bulb cracked. The crack was small, so it's been like that for a few years. Over the Christmas break, the driver's headlight lost low beam, but still had high. The crack finally got bad enough to let water in, so that's probably what killed it. Anyways, replaced that today.
Went out just now to test it in the dark and the high beams decided to not work. I've noticed that for a few months, I've had to lightly tap the grille around the passenger bulb to get the high beam to turn on. Well, the relay harness I have is starting to come apart at the connection to the battery. I can wiggle it around and make the high beams turn on and off. The low beams are fine. Of course, all my wiring tools are back home, but I know my church family down here has what I need. It'll get fixed eventually I'm also thinking of switching around the wires in the headlight switch plug so that I can have both the park lights on and the headlights on at the same time. And last for the night: check out how well the under hood light works. I didn't use the flash on my phone to take the last picture. It's from a 87-96 Dakota and I think I have an 1156 bulb in it. I got it from a junkyard, so it was around 5 bucks. There's a plug at the bulb and at the base of the hood. I will unplug it at car shows or when I don't need it on while working under the hood. I can check the oil at night without needing a flashlight
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-20-2022, 01:54 PM | #952 |
Re: Frankentruck
It's always something! Keeps us on our toes anyway!
When I replaced my wiring with the AAW kit, I wonder if the new light switch comes so the parking lights and headlights come on together...because mine do and I never had to do anything special for it. |
01-20-2022, 02:52 PM | #953 | |
Re: Frankentruck
Could be the new wiring for yours. I have a factory reproduction fuse block, so I think I just have to switch a wire around in the plug. Slightly more annoying in my case because I have to take the speaker out to get up under there
01-21-2022, 06:57 PM | #954 |
Re: Frankentruck
love the underhood light, I have one I snatched from a mid 80s chevy truck that has a on\off switch and a reel so you can take the light with you and wind it back up. I have had it for years waiting on this project lol.
Edit: I feel like I've already said about this light but not sure lol. they say the memory is the....wait,what was that saying again? Last edited by 350TacoZilla; 01-22-2022 at 06:31 AM. |
01-22-2022, 04:16 PM | #955 | |
Re: Frankentruck
I know I had talked about the light before in my thread, but I was taking night pictures, so figured I would mention it again
02-01-2022, 12:51 AM | #956 |
Re: Frankentruck
I hate waiting on parts to show up. USPS has apparently misplaced the NOS sending unit gaskets I purchased so that I can replace the brass float and sending unit gasket that have both deteriorated beyond repair. I want my fuel gauge back to working, dang it.
Anyways, I was doing some thinking and came up with a name for my trailer. I'm going to call it Half-Wit because it's half a truck and not easily motivated unless hooked to something else I'm planning on taking Frankentruck and Half-Wit to the GA C10 Club swap meet on March 12th. They haven't been together since I before I put the new tires and wheels on Frankentruck, so I'm looking forward to see how that looks
02-01-2022, 10:26 AM | #957 |
I'm just glad to be here!
Re: Frankentruck
I know the feeling of waiting on parts. Order some the other day, they sent the wrong part as someone retagged it with the wrong labels at the warehouse. Now I am waiting of the replacements, but was refunded all my money and then ordered from another source.
I like the name for the trailer. Seems fitting to me.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-01-2022, 04:30 PM | #958 | |
Re: Frankentruck
My seals finally showed up today. Hopefully I'll get a chance later in the week to get the new float and seal installed. Frankentruck and Half-Wit kinda has a nice ring to it
02-02-2022, 05:11 PM | #959 |
Re: Frankentruck
Took a few minutes to get the float changed out. No more leaky brass. The Jeep float fit nicely in the stock sending unit. That NOS gasket was nice to use as well.
02-14-2022, 11:25 PM | #960 |
Re: Frankentruck
I cleaned the glass today, so basically, I washed the whole truck
I have been throughly enjoying using Frankentruck as my daily driver since coming back to school. I had noticed a weird sound that developed. Thought it might have been some piston slap starting up. I went home over the weekend to see one of my good friends for the first time since they moved out to Washington, so I decided to try to identify the noise as well. I was standing on the rear bumper and wiggling the whole truck when my dad noticed the tailpipe moving around a bunch. Way back when I got the muffler installed, I forgot to reinstall the hanger that was near the old muffler. Because of that, the exhaust was shaking around too much and causing that weird noise. Got the hanger back in and that noise seems to have been fixed. Of course, there's other squeaks and rattles, but one day they will be fixed. I think that lack of exhaust hanger helped contribute to the exhaust manifold donut gaskets blowing out a couple times before I replaced with the metal versions a year or so ago. Not going to be doing much to the truck other than enjoying it since I've got this last semester and I've started studying for the first of 4 parts of the CPA exam. Fun stuff
02-15-2022, 12:18 AM | #961 |
Moderator
Re: Frankentruck
Always feels good when you find the problem.
02-15-2022, 01:15 AM | #962 |
Re: Frankentruck
It definitely does!
Now, if only I could fix the other squeaks and rattles... Oh wait, that would mean starting all the rust repair on the cab
02-15-2022, 08:49 AM | #963 |
Re: Frankentruck
Man I'd be worried with that cab that one day your going down interstate and find yourself in a convertible c10. Do they make replacement pillar patch panels and such or are you going to need a donor cab?
02-15-2022, 10:48 AM | #964 | |
Re: Frankentruck
Most likely, I won't be starting the rust repair until I pass the CPA exam. Could be done with that by August, or longer, I don't know yet. I have patch panels for the floor, rockers, cab corners, above the windshield, and entire roof panel. I have the inner and outer upper corners of the windshield from a donor cab and a donor section to replace the damage on the passenger side. I will probably need some other donor pieces as I dig into it, but I want to save the cab since the cab vin and partial frame vin are still matching.
02-15-2022, 07:14 PM | #965 |
Re: Frankentruck
Good luck with your studies. My wife is a returned CPA. She says it was a great career for her for more than thirty years.
I enjoy your truck thread a lot.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" |
02-15-2022, 11:08 PM | #966 | |
Re: Frankentruck
My mom also has her CPA license, so I think I got that from her
02-21-2022, 09:40 PM | #967 |
Re: Frankentruck
Filled up today for $3.29. That was a punch to the wallet, but my 8.5:1 CR heads are making it less painful than it could be.
I chose to daily drive Frankentruck since this is my last semester and I'm close enough to be able to walk to campus. Not complaining about the gas prices. I've made my bed and have to lie in it now
02-22-2022, 02:28 AM | #968 |
Re: Frankentruck
Be happy, we Europeans would be happy if we had such petrol prices. In Germany we currently pay €1.82 for 1 liter of E10 Super. That would be about $6.77 a gallon
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
02-22-2022, 09:05 AM | #969 |
Re: Frankentruck
Dang, that doesn't sound fun
02-22-2022, 11:21 AM | #970 |
Re: Frankentruck
A gallon of regular up here is $4.52US
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-22-2022, 07:37 PM | #971 |
Re: Frankentruck
£1.48 per litre of e10 here so around £6.72 per imperial gallon or $9.14 per imperial gallon.
I didn't even get bought dinner..... P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
02-22-2022, 09:50 PM | #972 |
Re: Frankentruck
That would be $7.59 for a US gallon, they are smaller than an Imperial gallon.
02-22-2022, 10:23 PM | #973 | |
Re: Frankentruck
03-04-2022, 08:41 PM | #974 |
Re: Frankentruck
Drove up to Athens this morning to take my first of four CPA exam sections. I feel like I passed, but now I get to wait anxiously until I get my scores back on the 17th.
Frankentruck did great as usual, both there and back. I've passed an antique shop in the little town of Bishop every time I've gone up to Athens, so I stopped in on the way back. I found a 1970 Cherokee county license plate to add to my collection. The 35 was the county code for Cherokee county back then. Since that's the county I've lived in most of my life so far, I couldn't say no
03-06-2022, 01:44 AM | #975 | |
Re: Frankentruck
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
