Old 02-01-2022, 11:20 PM   #1
pwdcougar
pwdcougar's Avatar
Leaf spring bumpers
Anyone have a source for the correct leaf spring bumpers for a K10? My truck is a 70 Suburban but I would think the pickups are the same. LMC lists a style that bolts in as being correct for a 4WD truck but my truck take the ones that have the solid rubber type that push into the rectangular hole in the bracket.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-01-2022, 11:33 PM   #2
Richard
Re: Leaf spring bumpers
There are some used ones on the parts board. https://67-72chevytrucks.com/vboard/...d.php?t=830124
Richard
Old 02-02-2022, 12:05 AM   #3
pwdcougar
pwdcougar's Avatar
Thanks Richard
The pictures of the stops are what I need but in the post someone says they are for 2wd truck not 4wd. I'm confused. My 4wd uses this style not the ones that are bolted on.
I guess I'll have to see if I saved the ones that were on my truck.
Old 02-02-2022, 12:20 AM   #4
Richard
AFAIK only the later trucks used the bolt in bumps. The earlier 4x4's used the push in style. If your bump brackets are fastened to frame by rivets, they are factory.
Richard
Old 02-02-2022, 09:56 AM   #5
pwdcougar
pwdcougar's Avatar
Thanks again. My brackets are original. Let’s see if LMC will take them back.
Old 02-04-2022, 02:17 AM   #6
Bob B.
Funny, I have been looking for rear axle bumpers for my leaf spring '67 2500. These are rectangular, pointed top, with an inverted 'T' on the bottom that pushes into a slot on the axle. According to the parts book, it's supposed to be the same bumper as on the coil spring trucks, part #3843849. These are reproduced and easy to find.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 02-04-2022, 01:36 PM   #7
pwdcougar
pwdcougar's Avatar
Thanks! That’s the style on my truck. LMC lists two that style. They are different front and back. The rear ones they list are probably correct.
Old 02-05-2022, 08:49 PM   #8
Bob B.
Yes, the rear ones are taller.
