06-14-2015, 10:15 PM | #1 |
68 k20 hubcaps pictures and info please
I have a 68 k20.
new to me did they come with hubcaps as an option or as standard. I understand they are larger in diameter than the half ton caps. anybody got pictures of a 20 series hubcap and pict of the truck with them mounted? pertty please? and also front hub caps on the k20 with factory lock ing hubs. are thes hubcaps hard to come by? Thanks in advance |
06-15-2015, 01:29 AM | #2 |
Currently Blazerless
Re: 68 k20 hubcaps pictures and info please
No hubcaps were offered from the factory for the K/10. K/20 series trucks in 67 and 68. Starting in 69 you could get the bright dog dish caps from the factory for both the 10 and 20 series 4x4s. No
White painted caps were offered on 4x4s either but I have seen some guys cut the center out for the fronts. I'm not sure when the full wheel covers were first offered as an option, I know you could get them on 71 And 72 4x4s
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
06-15-2015, 05:15 AM | #3 |
Standard black wheels were as pretty as they came on a K10 or 20.
Next question is are you running the original base 17.5" wheels or one the optionals like 16, 17 or 16.5"? The stock 4x2 hub caps were a clip on style shown on the red panel below. If you are not running original wheels then you might want to ID what you have and what your options would be if you decided to add hub caps. For additional information check out this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=523328
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-15-2015, 06:53 AM | #4 |
Yep, no caps on 4wds till '69.
02-06-2022, 08:01 AM | #5 |
If GM had offered hub caps for 67-68 K20
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-06-2022, 08:49 AM | #6 |
I like your style. My kind of custom, do what GM coulda or shoulda. Make people scratch their head and ask, "Is that factory?", or, "I didn't think GM did that"... Nope
02-06-2022, 09:57 AM | #7 |
X2! Hubcaps were used on late 50's and early 60's GM 4x4's, then they magically disappeared on '62-'68 Chevys and '65-'68 GMC's. Something the owner could have done from day one, visit the GM parts dept man. One odd note, as Blazerman correctly mentioned, the base model painted caps never re appeared on 4x4's, only the bright metal caps '69+
