Old 01-30-2022, 07:06 AM   #51
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
I like it....a lot!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-30-2022, 08:32 AM   #52
Looking good Doc!
Old 01-31-2022, 11:12 AM   #53
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by Ol Blue K20 View Post
I like it....a lot!
Looking good Doc!
Thanks guys.
It's a nice day today but it will start getting colder soon. I am working on this outside so things may slow down unless I can figure out a place to store the '34 Ford Coupe so I can get it in the shop. I have been working on doing that for the last couple of months....
I think I am gaining on it though.
LockDoc
Leon
Old 01-31-2022, 09:44 PM   #54
LockDoc
LockDoc's Avatar
I made enough room in the big building to put the '34 Coupe in there so hopefully it won't be long until I have the Dually in the shop. I need to do just a little more cleaning first. I am such a "slopo"
I also need to put the steering cloumn in the truck to make it easier to move.
LockDoc
Leon
Old 01-31-2022, 11:54 PM   #55
Getter-Done
Getter-Done's Avatar
I really like the Mud Flaps
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 02-01-2022, 01:10 PM   #56
LockDoc
LockDoc's Avatar
Only problem is they aren't wide enough now....
LockDoc
Leon
Old 02-01-2022, 01:15 PM   #57
LockDoc
LockDoc's Avatar
OK, truck is in the shop. It's a tight fit but I should have enough room to get a bunch of stuff done on it. I started stripping out the wire loom on the engine today. I will be removing quite a few wires from it. I will be jumping back and forth on different things depending in how much time I have each day.
LockDoc
Leon
Old 02-02-2022, 02:16 PM   #58
LockDoc
LockDoc's Avatar
I had a little time to kill so I decided to get started on setting up the ECM using my HP Tuners software this morning. I got it all connected and the laptop fired up. I built a wire loom so I could do all of the ECM programming stuff on the dining room table. It makes it a lot more enjoyable to be able to sit down in comfort......
I got the original tune scanned and backed up to my hard drive, now I can go in and remove the VATS, EGR, rear 02 sensors, A/C, and 4x4 stuff. There are a few other things but I will have to look at my cheat sheet and double check. It has been quite a while since I did my '67 Panel Truck.
In the picture, the large grey box in the back is the regulated 12v power supply. There is a separate rocker switch that turns on the power to the ECM. The large silver box is the ECM (Truck Computer), and on top of it is the Diagnostic connector from under the dash of the donor truck. It has the cable from the HP Tuners interface box plugged into it. The small grey/black box is the HP Tuner interface that connects the ECM to the PC.
The PC will read the "tune" in the ECM, then you can make changes to it and write the modified "Tune" back to the ECM computer. The only thing you really have to remove to make the engine run is the VATS (key resistor chip) information that would keep the engine from starting.
I'm sure some of this stuff will be pretty boring to some but I want to document it for future reference.
LockDoc
Leon
Old 02-03-2022, 06:57 AM   #59
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Leon, do you have the pro version of HPtuners, or just the entry level version?
Ryan
1969 Chevy milk truck
Old 02-03-2022, 07:29 PM   #60
BigBird05
I am looking at installing a LS motor in my truck. I am only in the cost feasibility stage. Can you help others with your knowledge? Maybe charge us for your computer time?
BigBird05 is offline   Reply With Quote
Old 02-04-2022, 01:07 AM   #61
LockDoc
LockDoc's Avatar
Mine is just the standard version. The Pro version is about $250 more.
I don't consider myself knowledgeable enough to be changing parameters in other peoples ECM's/PCM's. It's pretty easy to "Brick" one of them if you do something wrong. There may be others that hang out in the LSx Swaps forum that are more comfortable doing that. Sorry.
LockDoc
Leon
Old 02-04-2022, 06:38 AM   #62
BigBird05
LockDoc
OK just had to ask.
Old 02-04-2022, 10:54 AM   #63
SRU1436
In the picture, the large grey box in the back is the regulated 12v power supply. I has the rocker switch that turns on the power to the ECM sitting on top of it. The large silver box is the ECM (Truck Computer), and on top of it is the Diagnostic connector from under the dash of the donor truck. It has the cable from the HP Tuners interface box plugged into it. The small grey/black box is the HP Tuner interface that connects the ECM to the PC.
LockDoc
Wow that’s pretty trick. I never knew what you’re doing was possible. But then again I never looked into something like that.
Last edited by LockDoc; 02-04-2022 at 02:02 PM. Reason: Corrected the spelling in my quote
SRU1436 is offline   Reply With Quote
Old 02-04-2022, 12:01 PM   #64
67C10Step
67C10Step's Avatar
Just stumbled onto this one and am so glad I did. The photo with the cab and bed on made me smile from ear to ear. Cannot say how much I like that.
I'm in to see how this comes out.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-04-2022, 01:02 PM   #65
kev2809
low n' slo
kev2809's Avatar
man this looks like a fun build.
are you going to leave the rear bed like that...or add dually fenders?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-04-2022, 01:24 PM   #66
LT7A
"I built a wire loom so I could do all of the ECM programming stuff on the dining room table. It makes it a lot more enjoyable to be able to sit down in comfort......"
And enjoy your latest batch of cookies ; )
Very cool that you've been able to get that set up and have that knowledge. I would like to be able to get to that point eventually.
Old 02-04-2022, 02:19 PM   #67
LockDoc
LockDoc's Avatar
The wire loom for this setup was actually pretty easy to make. You can access the truck computer and change pretty much anything you want. I will have to change the rear end ratio, tire size, and tach output among other things in the truck computer to make everything work.
Thanks I'm having fun with this one. My friend made it back from Texas yesterday so we are planning on installing the back slider window and windshield next Wednesday.
I will either leave it as is or put 2 1/2" wide rubber trim around the openings. No fenders....
The cookie container is within arms reach....
If an old school-old fart like me can figure it out anyone can. It just involves a lot of reading. All of the information is on here and numerous other sites on the net.
Thanks guys.
LockDoc
Leon
Old 02-06-2022, 09:30 PM   #68
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
LockDoc
Cool.project Leon, looks like your.making really good progress on it. As for your rear wheel openings keep your eye out for a set of 76-86 JEEP CJ-5, CJ-7 factory rear wheel flares. They fit our wheel arches almost perfectly. They don't cover the entire wheel openings but.most of it. You should be able to find a set cheap and they're molded and look much better than the cut to fit ones.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-06-2022, 09:35 PM   #69
BLAZERMAN
BLAZERMAN's Avatar
Here's a Longhorn dually I saw on a FB group the other day.
Old 02-06-2022, 09:42 PM   #70
pwdcougar
pwdcougar's Avatar
Looks like a fun build Leon!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-06-2022, 09:45 PM   #71
Louisvillekytruck
Looking great
Louisvillekytruck is offline   Reply With Quote
Old 02-06-2022, 09:57 PM   #72
LockDoc
LockDoc's Avatar
Originally Posted by BLAZERMAN View Post
Cool.project Leon, looks like your.msking really good progress on it. As for your rear wheel openings keep your eye out for a set of 76-86 JEEP CJ-5, CJ-7 factory rear wheel flares. They fit our wheel arches almost perfectly. They don't cover the entire wheel openings but.most of it. You should be able to find a set cheap and they're molded and look much better than the cut to fit ones.
Thanks Rob. I have been working pretty steady on it. I hope I can keep the momentum up. I need to go over to the local salvage yard as soon as some of the snow melts so I will check out the Jeep flares.
I was going to do a Longhorn based on a '67-'68 and I pretty much had everything to make it happen except the cab and frame weren't in very good shape. I sure like them.
LockDoc
Leon
Old 02-06-2022, 10:00 PM   #73
LockDoc
LockDoc's Avatar
Originally Posted by Louisvillekytruck View Post
Looking great
Thanks guys. It's been fun so far. I'm looking forward to more progress in the coming weeks.
LockDoc
Leon
Old 02-06-2022, 11:03 PM   #74
68Gold/white
Leon, I vote “ no” on the flares. The look you have now, is better and likely uncommon....
68Gold/white is offline   Reply With Quote
Old 02-07-2022, 10:46 AM   #75
kev2809
low n' slo
kev2809's Avatar
ya I'd have to see the flares I think. I like that look the way it is. there might be laws though in your state since they poke past the wheel well
-_--_--_ _________
