Old 02-04-2022, 01:07 AM   #76
Nima
Blue 67
Re: My 53 GMC 3/4 ton project
I used the same steering linkage which I got with the electric box. I have a little interference with the access to the firewall which I believe will be okay when I finalize the install under the dash. If it doesn't, I have to enlarge the hole:
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 02-04-2022, 01:09 AM   #77
dsraven
Nice, now, what is going on with that brake pedal, haha.
dsraven is online now   Reply With Quote
Old 02-04-2022, 01:32 AM   #78
Nima
Blue 67
It got drunk! LOL
Old 02-04-2022, 08:48 AM   #79
Father&son56project
Awesome detailed description and pics of that electric steering conversion (as well as everything else you have done). I am having a blast watching you problem solve your way through this build!
Father&son56project is offline   Reply With Quote
Old 02-04-2022, 09:26 AM   #80
8man
Fantastic! Well done.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 02-04-2022, 11:41 AM   #81
Nima
Blue 67
Thank you for the comments.
It is fun to mess around with old and new parts and it is satisfying when it comes together. I get a kick out of recycling parts from junkyard!
Old 02-11-2022, 10:43 AM   #82
Jason 56
Just finished reading through you build. I like the steering solution you are using. You are making great progress. I’ll be following!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 02-12-2022, 12:13 AM   #83
Nima
Blue 67
Thanks.
Old 02-12-2022, 12:18 AM   #84
Nima
Blue 67
So, I took the eclectic steering off to do some final adjustment to the steering shaft adjustment and also, I wanted to finalize the mounting hardware under the dash. I was not very satisfied with 5/16 threaded rod, so I ended up with a 5/16 rod which fits very snuggly into the steering box mounting hole and I just threaded the two ends of it. Finally, I painted the steering and mounting bracket:
Old 02-12-2022, 12:29 AM   #85
Nima
Blue 67
Moving on to fuel tank. This is a universal fuel tank from Tanksinc. It has the option of the either side or top fill. I am going with the side fill knowing (based on what I have read, please correct me if I am wrong) that I may have to raise the bed floor a little. The rear crossmember was in the way and I didn't know other tanks options such as Mustangs or Camaros would fit given the fact my truck frame is a 3/4 ton. I moved the stock cross member to the rear and then I made a new one for the front of the tank:
Old 02-12-2022, 12:44 AM   #86
Nima
Blue 67
So, it ended up being a beautiful day in NW and I couldn't stay in any longer. I took one of my favorites out for a drive
I am more of the 4 door guy!
Old 02-14-2022, 09:26 AM   #87
6DoF
6DoF's Avatar
more doors is like more HP right?
will the steering assist be adjustable with that setup?
6DoF is offline   Reply With Quote
Old 02-15-2022, 11:14 AM   #88
Nima
Blue 67
That is the plan.
Yes, the steering has a manually adjustable knob which I have to mount somewhere.
Old 02-15-2022, 11:25 AM   #89
Nima
Blue 67
While waiting for some small parts to arrive, I am jumped around and worked on the seat brackets. The seats are from a 2001 Tahoe. They are thicker (bulkier) than I would like but they are very comfortable for me (I have similar ones in my 2005 truck) and also fully powered including heat! Besides, paying only $50 for them, made them more attractive! Of course I have to either get a set of cover for them or just rebuild them. I also don't know if I should connect the under the cab plates to the frame or not for added security. I would be concern about vibration transfer to the cab?!
Old 02-15-2022, 12:02 PM   #90
Father&son56project
Originally Posted by Nima View Post
That is the plan.
I'm confused! You used a stock electric steering setup from a junkyard, but you are mounting an adjustable knob. Did that stock steering setup have an adjustment knob, or is it some aftermarket gizmo you are adding? I ask because I love what you have done and will likely do it on my next build.
Thanks!
Old 02-15-2022, 01:20 PM   #91
Nima
Blue 67
Thanks!
Stock electric steering boxes adjust the steering assist based on the load (torque) applied in regard to the speed, tires and etc. This adjustment are done through the car's main ECU. Some Asian cars manufacturer s'(Toyota, Nissan and some Hyundai that I know) electric steering boxes can go to a default mode and apply some steering assist if they don't receive any signal from ECU while American car versions (Saturn or chevy Equinox that I am using) do not have a default mode which means if they don't receive the signal from ECU, they don't provide any steering assist. To overcome this issue, there are few companies on Ebay who sell some standalone modules which can send the signal to activate the steering assist but, since there is no ECU involved the steering assist will be controlled by standalone knob. I chose to go with Saturn/Equinox version since I felt they came out of an SUV which hopefully makes them a little stronger for a truck use rather than the ones come out of a Toyota Prius. Besides, me using big tires and wheels, I wanted to be able to adjust the amount of the steering assist to my liking rather than just relying on a default mode.
Old 02-15-2022, 02:05 PM   #92
Father&son56project
Thanks! It makes perfect sense to me now. It will be interesting to see what you think of it once you have some time on the road. Keep up the great work (and the amazing pics and explanations).
Old 02-15-2022, 11:00 PM   #93
Nima
Blue 67
Moving along.
I started working on brake lines and fuel system but first I needed a bracket for the proportioning valve. I titled the valve a little to avoid inner fender interference:
Old 02-15-2022, 11:08 PM   #94
Nima
Blue 67
Now, when I put the inner fender on to mockup things, I came across these two questions which I would appreciate help with the answers (of course if I had an assembly manual ...):
Does the inner fender lip line up with the body inner cowl panel (the arrows in the first picture? And also, I don't remember when I did the disassembly, if the inner fender was attached to the firewall or if there was another panel (the second and 3rd pictures)?
Old 02-15-2022, 11:32 PM   #95
edgeleycanuck
I think if you rummage through your parts you'll find a part that fits between the inner fender and the firewall, light gauge metal. I think 3 bolt holes into firewall and 2 or 3 bolt holes( or maybe captured nuts) to fasten to inner fender. Sort of a square Z in shape about 10 inches long maybe...
When you find that peice you'll see how everything lines up
edgeleycanuck is offline   Reply With Quote
Old 02-15-2022, 11:42 PM   #96
Nima
Blue 67
Okay, thanks. I have to look around better! Everything is at exploded stage now. A picture would be a great help if anybody has one.
Old 02-17-2022, 05:29 AM   #97
NorCalGal
NorCalGal's Avatar
It would be #3 in this diagram
Jan's 53
NorCalGal is offline   Reply With Quote
Old 02-17-2022, 09:40 AM   #98
dsraven
good info on how the electric steering works and the work around for making it work without a stock vehicle's modules. just curious, is there a fine tuner to get the steering wheel centered or is that an alignment issue afterwards?
Old 02-17-2022, 10:52 AM   #99
Nima
Blue 67
Thank you NorCalGal. Very helpful.
There is some process which ofcourse I don't remember now (I don't this is just me getting old or something else)! I have the information buried somewhere! When I get to the wiring and start up I will post an update then.
Old 03-02-2022, 01:47 AM   #100
Nima
Blue 67
So, I have been waiting for some small parts to arrive. Meanwhile, I got my new wheels and tires put together:
