02-24-2022, 11:16 PM | #26 | |
Re: Update: '99 OBS CC SWB Brake Issue
A new aftermarket prop valve is $125 or under. A donor 88-92 prop valve is <$10. Brake lines? Re-use what you can or snag some parts off wrecking yard donors. After that? You're done. Ever have an issue w/the master cylinder failing in the future? Replace it & bleed the brakes like any non-ABS hydraulic system. No need for the computer access. *EDIT* I've only had 3 vehicles new enough to utilize a scanner (my old '93 x-DPS Mustang, my old '90 model OBS, & it's replacement Spot). All my stuff has been older carb'd rides.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-25-2022 at 09:10 AM. |
02-25-2022, 12:58 AM | #27 | |
OBDI doesn't need a scanner. The "scanners" available for them don't do anything but show you the codes, which you can read off the check engine light with a paperclip and not waste your money. GM and Ford, paperclip. Dodge is even easier, turn ignition on, off, on, off, on. Codes start flashing.
I'm not trying to change your mind on how you want to fix your truck, just that it probably won't be the last time you need to fix it and the Tech2 may come in handy later. Of course, I still haven't gotten one either though. I thought the air would eventually work its way out on its own anyways. Like how a pressure tank with a ruptured bladder gets waterlogged. Fluid displaces the air. When I would bleed the clutch on my F150 I couldn't get all the air out, I had to drive it to work out the rest of the air.
02-26-2022, 01:42 PM | #28 | |
Moderator
A Tech2 only begins to be useful on 1993 and newer vehicles. The earlier ECUs are fairly embryonic tech. Not much in the way of bi-directional controls if anything. The Tech2 will not give you much more than WinALDL or TunerPro on a 1992 and will not give you anything on a 1991 or earlier rig whereas the WinALDL and TunerPro will let you view you any data that's available on the serial comm port back to the 1985ish TPI systems. If you eventually intend to get a 1995-2007 truck I'd keep your eyes open for a Tech2. You can still buy them new from China right now and it'll be something you can sell if you need to. A T800 Master cylinder is not biased for Disc/Drum brake systems because the T800 brake bias is controlled by the ABS system. It'll work but it won't be quite right. On a 1994 and earlier truck I'd bypass the ABS pulse motor between the master cylinder and the metering/proportioning valve with a longer piece of brake line and bleed out the system. It'll work surprisingly well after you get all the air out and properly manually adjust the drum brake shoe clearances.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-26-2022 at 01:58 PM. |
02-26-2022, 02:28 PM | #29 | |
If you're careful, you shouldn't have to buy anything. The line doesn't have to move far and it should be coiled under the fitting.
02-26-2022, 02:42 PM | #30 | |
Moderator
IIRC you have to change the ferrule on the end of the coiled brake line because the ABS pulser has a different diameter and thread pitch from the Combination valve. Still pretty darn easy and non intrusive.
And please let us know if and how your repairs were successful. |
02-26-2022, 03:44 PM | #31 | |
I was thinking the same thing after I posted. Might need an adapter, union the two lines together, or cut swap fittings and reflare.
02-26-2022, 07:31 PM | #32 | ||
02-26-2022, 09:08 PM | #33 |
laying low
Is that like what's on a 91 model? So, at most, you may possibly need an adapter for the rear tube?
02-26-2022, 10:28 PM | #34 | |
My '99 has the big Kelsey-Hayes ABS set-up. But if you remove all of the KH stuff until the master cylinder, the earlier stuff can be integrated by simply splicing a 'T' in for the fronts & connecting to a diff location for the rear line vs. where mine is. I got as much as I could to have the xtra fittings. Will prob have to make some new lines so things can be spliced where it will be easiest under the hood.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-26-2022 at 11:47 PM. |
02-27-2022, 03:03 PM | #35 | |
I tried to get a decent picture of my 99 so everyone can see what you're dealing with.
02-27-2022, 04:31 PM | #36 | |
You were successful w/your attempt so TY for sharing the image. I took pics of mine as well but it was cold, dark, & raining outside when I did so the JY parts images were decent but the under-hood shots were less than usable.
01-09-2023, 04:08 PM | #37 |
Old thread, but how did this turn out Scoti? I have a 93 that I just did a L86/8L90 conversion on and I would like to remove the RWALS. Can I unplug just the module or do I have to delete the solenoids? The current master cylinder is leaking at the seals between the reservoir and the base. Can these be replaced or do I need to buy a whole new setup? Thanks for the help.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-09-2023, 04:33 PM | #38 | |
On NYE, I went over to my buddy's place to see the LS swap updates on my old '90 & to help w/some exhaust routing solutions. Conveniently, he still had the core support out which made it easy to again see/visualize the line routing up front (under the motor + where it connects each side @ the flex lines) as well as the placement of the factory unions for a '90. This thing is scary when braking on irregular surfaces (railroad track crossings & ginormous asphalt road patches) when anything beyond an easy/soft pedal effort braking is used. We discussed my lingering issue & about the latest 'upgrade' guys are doing for the OBS brake systems (GMT800 series & later master cylinder swaps). So that's going to be my plan moving forward. I'll replace the original OBS master cylinder w/a fresh GMT800 (or newer) unit, plumb the lines to a bias adjustable prop valve, make new connecting lines up front, & dial in rear bias once everything is in place & purged/bled. We'll simply delete the ABS alarm in the gauges as a start.
