Old 02-19-2022, 12:25 PM   #101
LockDoc
The Older Generation
LockDoc's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
Originally Posted by cj847 View Post
Quote- I also have a van tilt column that I am going to use in this project so I will get it ready to install in the next couple of days. I need to shorten the intermediate shaft for it and move the NSS down lower on the column.
I didn't know you could move the NSS, or at least not without a ton of work. However, I have a suggestion for you. You can tap NSS and BU lights off of the transmission wiring. That is what I did on my Willys with an LS swap. I bought the cheapest Ididit column (floor shift, key in dash, no NSS). You do need to use a relay to trigger the starter as you don't want to run high amperage thru the 20 gauge transmission wiring. Also the BU and NSS are more accurate this way (can't get out of adjustment).
I am not sure that the allison transmission uses the same connector as 4L60/4L80 but here is a diagram to get you started if you want to do it.
Here is a complete write-up on using the van column including moving the NSS. It isn't too bad to do. I have done a couple of them.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Thanks for the tip and visuals. I saved the picture. I will check the Allison wiring diagrams and see if I can figure this out. That sounds like a viable solution for the BU lights and NSS.
LockDoc
Leon
Old 02-25-2022, 09:18 PM   #102
LockDoc
LockDoc's Avatar
I started working on the van tilt the other day. It needed quite a bit of cleaning, prep, and a new lower bearing. and I needed to shorten the intermediate shaft to accommodate the longer van column main shaft.
Member "cj847" mentioned in his post above about using the NSS and reverse light function from the transmission wire loom. I checked the specs for the Allison and it actually uses a switch located on the side of the transmission and integrated with the shift linkage. I am going to try and use this instead of the column mounted stock NSS. I may go ahead and cut the tube to move the van NSS down in case something doesn't workout with the Allison components. It isn't that hard to do and it may save me from having to pull the column back out later. I hope to get that done and get it painted tomorrow, and get the column installed tomorrow or Sunday. I need to get the defroster duct installed before I set the gauge cluster in, it makes it a lot easier.
LockDoc
Leon
Old 02-26-2022, 03:37 AM   #103
pjmoreland
pjmoreland's Avatar
Will you be able to tie that van cruise button on the turn signal lever into the ECU somehow to get cruise control working?
pjmoreland is offline   Reply With Quote
Old 02-26-2022, 03:34 PM   #104
LockDoc
LockDoc's Avatar
No, because the column fell over after I painted it and broke the handle off of the lever. It upset me, but luckily that was the only damage and I wasn't planning on using it. I just hated to see it get broken. I am going to use a later one with the multi function cruise.
LockDoc
Leon
Old 02-26-2022, 04:47 PM   #105
pjmoreland
pjmoreland's Avatar
That sounds disappointing. Makes sense that you'd need full controls though to take full advantage of the modern cruise control. I've thought about trying to add a cruise control system from an 80s S10, which would be able to use the style of turn signal lever that Dakota Digital sells. The challenge would be to figure out how to replace the speed sensor that those pickups had built into the back of the speedometer.
https://www.dakotadigital.com/index....prod/prd50.htm
Old 02-27-2022, 12:37 AM   #106
LockDoc
LockDoc's Avatar
From what I read, if you use the Dakota Digital lever that you have to use relays to change the "Normally Open" state they use to a "Normally Closed" state. What I was reading was a little dated so maybe they now have one that is NC. I don't know.
LockDoc
Leon
Old 02-27-2022, 12:45 AM   #107
pjmoreland
pjmoreland's Avatar
LockDoc
That sounds like a bit of a headache.
Old 02-27-2022, 12:55 AM   #108
LockDoc
LockDoc's Avatar
That's what I thought too.
LockDoc
Leon
Old 02-27-2022, 12:58 AM   #109
LockDoc
LockDoc's Avatar
I installed the van tilt and gauge cluster today. I am going to have to pull the column back out because when I installed it I moved it down so the steering wheel would be a little closer to the dash. I used one of the two factory locator slots in the mast jacket and it moved it down too far. If I use the lower slot it would move it up too far. I think I will just drill a hole for the locator tang instead of cutting a new slot since I know exactly where it has to be now. The steering wheel is not going to stay, I just put it on there for the picture. I will either use a '67-'68 wheel that I have, or get one of the new 15" stock type wheels.
LockDoc
Leon
Old 02-27-2022, 04:07 PM   #110
rickcdewitt
rickcdewitt's Avatar
Hey doc with that 02 you may want to change the intake gaskets as a prevetative measure while its easy to get to.
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 02-27-2022, 09:49 PM   #111
LockDoc
LockDoc's Avatar
Thanks Rick,
I think I will do that. I already changed the crank sensor before I installed the engine. Another problem area. I'm pretty sure it had been changed before, it came out pretty easy.
LockDoc
Leon
Old 02-28-2022, 08:02 PM   #112
CG
BlahBlahBlah
Coming along nicely, and quick!
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
Old 02-28-2022, 09:36 PM   #113
LockDoc
LockDoc's Avatar
Thanks Mark.
I worked on cleaning up the cab lights today. I am going to use the Yankee 77's.
I bought the lights from member "countr" (Russ) couple of years ago. I got lucky, when I opened the boxes there were a couple of original GM installation instruction sheets in them. That will make it easy. Can't have a C30 without cab lights...
LockDoc
Leon
Old 03-01-2022, 07:52 AM   #114
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
LockDoc
That column would be fine for me where it's at but I'm sure your arms would be stretched out with it like that. Nice work on it.
Ryan
1969 Chevy milk truck
Old 03-01-2022, 09:56 PM   #115
LockDoc
LockDoc's Avatar
The problem was that the shift collar was actually underneath the cluster bezel and rubbing on it. I moved it up so I have about 1 1/2 inch clearance on it now..
I usually have the seat adjusted all the way back with the stock steering wheel. Now I can slide the seat forward a little. I think I am going to use a '67-'68 wheel on it and they have a little more dish to them also.
LockDoc
Leon
Old 03-02-2022, 12:05 AM   #116
Yerboogieman
Yerboogieman's Avatar
That's awesome. The only thing that would make it better is if it were a crew cab. I wanted to do an 8.1 swap into my Suburban but I couldn't find one anywhere.
-Taylor
1971 Chevy Suburban 4x4 Build Thread
Yerboogieman is offline   Reply With Quote
Old 03-02-2022, 08:39 PM   #117
regan wilson
regan wilson's Avatar
Lookin good Doc.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-02-2022, 09:58 PM   #118
LockDoc
LockDoc's Avatar
Fortunately I don't need a crew cab any more... .. The 8.1's are pretty easy to find around here.
Originally Posted by regan wilson View Post
Lookin good Doc.
Thanks guys!
LockDoc
Leon
Old 03-02-2022, 10:31 PM   #119
LockDoc
LockDoc's Avatar
I worked on the cab lights today but I only got 3 of them installed. The used ones I have are in pretty good shape but I still disassembled everything and cleaned them inside and out. Also cleaned the bulb sockets and connectors.
I didn't take the camera out with me so pictures tomorrow.
LockDoc
Leon
Old 03-03-2022, 05:05 PM   #120
LockDoc
LockDoc's Avatar
Finished Mounting the cab lights today. I couldn't decide whether to mount the outboard ones straight or on an angle. After looking at some pictures on here I decided to mount them straight. I had one light that all of the chrome had come off of so I disassembled it and used it for the setup. Without the wire and rubber base on it, it was real easy to tell where the light fit the curvature of the roof the best.
The assemblies that are on there now are not the good ones. I used these to get all of the holes drilled and lights mounted, to make sure of my spacing. I will remove these and run the wiring and install the good ones tomorrow.
LockDoc
Leon
Old 03-04-2022, 08:24 AM   #121
Dieselwrencher
That turned out nice! I like them as you don't see much of them out on the road anymore.
Ryan
Old 03-04-2022, 10:44 AM   #122
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
They look great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-04-2022, 06:50 PM   #123
LockDoc
LockDoc's Avatar
Originally Posted by Ol Blue K20 View Post
They look great!
Thanks Guys. I didn't get to work on it much today. We will see what tomorrow brings....
LockDoc
Leon
Old 03-05-2022, 07:13 PM   #124
LT7A
Lots of cool progress. I like how you're buildng almost the entire thing out of parts you already had.
Old 03-05-2022, 10:59 PM   #125
LockDoc
LockDoc's Avatar
Thanks! Lord knows I have a lot of parts. I'm just trying to use up a few of them...
LockDoc
Leon
