03-03-2022, 01:32 PM | #76 |
Re: Dummy Filler Neck for 67-72 Trucks with Removed In-Cab Tank
No hurry for me
03-03-2022, 01:42 PM | #77 | |
One of the First
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
03-06-2022, 07:47 PM | #78 |
At the body shop.
Got mine on today.
Super easy install. Looks factory And some sweet patina fell out of the front cab support. Closer to an air ride cab yet.
" That didnt make it any newer " " Dont antique the equipment " |
03-06-2022, 07:51 PM | #79 | |
Looks like you tightened those four larger screws a bit. Did they help snug up the fit? |
03-06-2022, 07:57 PM | #80 |
At the body shop.
Maybe a turn more than touching. Seemed like it tightened the whole deal up.
Very happy with the install and end result. Thank you
03-06-2022, 07:58 PM | #81 |
At the body shop.
And only the locking cap because that's what I had.
Still want the chrome one with a springy snake to surprise someone
03-06-2022, 08:00 PM | #82 |
03-06-2022, 08:07 PM | #83 |
At the body shop.
Probably 60% of the reason I got it.
40% for deleting the cab tank and not having to fix the hole
03-07-2022, 08:29 AM | #84 | |
03-07-2022, 03:20 PM | #85 | |
1966 Ford Mustang 1969 Chevy C10 1971 Chevy C20 |
03-07-2022, 05:19 PM | #86 |
i would like to get in on the next batch of these if you plan another patch one modiifed for outlett
03-07-2022, 05:20 PM | #87 |
I will add you to the list. I am currently making a batch of 25, and you will be #19 on the list. Thanks!
03-07-2022, 05:22 PM | #88 |
sounds good jus tlet me know when to pay you thanks man
03-07-2022, 05:22 PM | #89 |
03-09-2022, 10:29 AM | #90 |
Just checking to see if you have had a chance on the 60-66 grommet fitment.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-09-2022, 10:51 AM | #91 |
I did purchase a 60-66 grommet, and I see that the filler neck passes through it at an angle. Also, the cab hole is smaller on 60-66, so the 67+ grommet won't work. I plan on trying a couple of different ways of dealing with that angle once I've fabricated this next batch.
03-09-2022, 10:57 AM | #92 | |
03-11-2022, 07:17 PM | #93 |
Thundarr, who made the original suggestion to make this dummy filler neck work with an AC power outlet, posted a photo of it in his build thread. Thank you, Thundarr!
https://67-72chevytrucks.com/vboard/...70#post9050170 By the way, in this next batch, I am going to use standard pan-head screws instead of flat-head screws on the regular non-power-outlet version. For those of you who plan on attaching a power outlet, you will need to let me know so I can machine the countersinks for flat-head screws for you. |
03-15-2022, 05:11 PM | #94 | |
03-15-2022, 05:24 PM | #95 |
03-21-2022, 07:17 PM | #96 |
Super! Just let me know and I’ll send you some $$
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
03-21-2022, 07:26 PM | #97 |
03-24-2022, 07:07 AM | #98 |
Nice!!
03-25-2022, 07:01 AM | #99 |
You are a machine
03-25-2022, 04:03 PM | #100 |
It occurred to me that I need to be able to pull my truck out of the garage to paint the filler necks. My rear axle assembly is removed at the moment, so I'm going to need to spend the next few days getting that put back together before I can paint the filler necks. I'm sorry about the delay.
