02-20-2022, 05:53 PM | #651 |
Re: New 64 Stepper Project
Until I get mine all back together I am guessing when it comes to tyre size and the amount of coils to lop off the front end but, if it comes close to what you have achieved, I will be a happy camper.
I am wavering between a 225/70/15 and a 215/75/15 both on a 7" rim but that purchase can wait another month yet. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
02-20-2022, 06:07 PM | #652 |
Moderator
Thanks again. I wish you the best.
03-07-2022, 08:36 AM | #653 |
Moderator
So I drove out to the new So-Cal shop in Waco this weekend it was 56 miles round trip and I got 17.9 mpg. The route had 65 MPH, 55 MPH 60MPH and city driving stop signs to and from. I don't want to go any leaner. Still have some choke tweeking to do though. It's a process.
I guess I'm going to find a local job now cause I need the gas money.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 03-07-2022 at 08:41 AM. |
03-07-2022, 09:37 AM | #654 | |
03-07-2022, 09:43 AM | #655 |
Moderator
I wasn't sure if that was good or not. I was getting like 10mpg when I started.
03-07-2022, 09:51 AM | #656 |
Over 16mpgs for a 350ci/auto trans/3500# brick is impressive for a carb set-up.
03-07-2022, 10:05 AM | #657 |
Moderator
Okay that's cool. I'll take it.
03-07-2022, 10:22 AM | #658 |
03-07-2022, 10:34 AM | #659 |
Moderator
I'll have to pull a couple and see. When I first started this they looked terrible, too much fuel.
03-07-2022, 06:21 PM | #660 |
Nearly 18 mpg is great especially doing 70mph. Sounds like she's dialed in. If it starts easy and burns clean... great job.
03-07-2022, 10:24 PM | #661 |
Any more details on the carb you're using?
I'm familiar w/the Demon brand but not so much their current product line & that particular model. Is it for a spread-bore intake or standard Holley square set-up? Easier for tuning vs. Q-jet or Edel/Carter style? What about vs a Holley?
03-07-2022, 10:33 PM | #662 |
Moderator
It's a Street Demon 1901BK. Square bore. Super easy to tune and work on. I hate working on carbs but this one makes it a pleasure, if you can call it that.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 03-08-2022 at 12:48 PM. |
03-08-2022, 04:30 PM | #663 |
Moderator
Spark plug:
03-08-2022, 09:45 PM | #664 |
Color is definitely getting better….
03-08-2022, 09:47 PM | #665 |
Moderator
Thats as good as it gets.
03-25-2022, 08:25 AM | #666 |
Moderator
When I changed the metering rods from 60/52's to 58/50's the mileage went from 18 to 12. Albeit the quick trip I checked it on was only 6.2 miles up and 6.2 miles back and I passed a slow-poke on the way up. That may have hurt it some.
You know the deal they were doing 50 in a 65 on a two lane road, I had to conduct a high speed fly-by. And then starting out I had to floor it to get into traffic. On second thought that whole run was completely different than the rest, too short ect. I'll try again latter.
03-25-2022, 09:16 AM | #667 | |
03-25-2022, 09:59 AM | #668 |
Moderator
Ya I don't see it as normal either. I checked timing, vacuum etc. as soon as I got home, ensured everything was snug. Doesn't seem right to me either.
Hey on a good note volts are awesome.
03-25-2022, 12:06 PM | #669 |
Follow with interest, they have achieved a great result, I will do the same with my engine and have also put an AFR connector in the Header
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
03-25-2022, 12:44 PM | #670 |
Moderator
That's an idea I have been considering and should have done.
03-26-2022, 06:50 PM | #671 |
Moderator
10.8 mpg after a 30 mile round trip. I might be off a bit because I'm using a wooden dowel dipstick and a ruler instead of the gas gauge.
So in the AM I will put the old metering rods back in and see what the deal is. I just feel like at 18mpg it's lean as in no balls engine wise. Better today for sure. Oh on another note I went to the Waco So-Cal store show where they had a car show. They had six plaques for awards. I received Best of Show Truck and Fan Favorite.
03-26-2022, 08:58 PM | #672 |
Man, you're going to need a dedicated shelf for all the awards you keep getting. Congrats!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-27-2022, 09:30 AM | #673 |
As CW said, your carpenter skill will be next for these awards, shelves will be necessary….congratulations…
03-27-2022, 11:35 AM | #674 |
The Shelf will be necessary, the Awards will increase in the Summer with the Great Truck.
03-27-2022, 01:37 PM | #675 | |||
Moderator
So I dropped in the 60/52's today drove 15 miles to the lake, turned around put the AC on and drove back. 15.4 mpg. This drive had a stop sign and a turn around. Driving 65/70 mph then into a small townish area 35/40 to the turn around and back. I should add that it is a hilly route to and from so a lot of extra accelerating trying to keep the speed the same. Just doesn't seem as good with the 58/50's in it but I will live with it for now I guess.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 03-27-2022 at 01:53 PM. |
