Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WTB Parts
Old 03-14-2022, 07:38 PM   #1
67sss
67sss's Avatar
1967 wiring harness
looking for a stock, uncut and unmolested complete wiring harness AND fuse block. I'm working on a 67 2wd v8 with a 3 speed and my fuse block is totally rusted out. I understand that other year wiring will work, however I'm trying to keep it simple.
67sss is offline   Reply With Quote
Old 03-14-2022, 11:38 PM   #2
Ironhorse
Ironhorse's Avatar
Re: 1967 wiring harness
Have the fuse block from a 67 GMC with the full seven hole gauge panel, the harness is pretty ragged and chewed. If have an interest in the fuse block let me know and I can take a look at it for condition. Should be able to come up with 6-7 inches of pig tail wires on it for splicing.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-15-2022, 05:58 PM   #3
Ironhorse
Ironhorse's Avatar
Looked at the 67 fuse block I have and it has nice clean fuse location printing but does have rust on the fuse clips. Maybe could be cleaned using a small dremel tool wire wheel, not sure there. Let me know if you have any further interest.
Wellington, Ks
Old 03-16-2022, 01:31 PM   #4
67sss
67sss's Avatar
I'm interested. Pics of fuse box would help. I can make the 6''-7'' pigtail work if that's the engine bay wiring. Working with someone else on a wiring harness he has. Hopefully between the 2 of you I can get what I need.
Old 03-16-2022, 08:33 PM   #5
Ironhorse
Ironhorse's Avatar
Still in the truck hooked to the wire harness which is rather hacked up here and there. Will get a couple pics taken tomorrow and post them. Hopefully will show what you need and your looking for.
Wellington, Ks
Old 03-17-2022, 10:45 AM   #6
C101968
I have a complete 67 C10 harness, for the whole truck.
removed carefully, no wires cut. in the box ready to ship.
Let me know, if interested.
Thanks, C101968
C101968 is offline   Reply With Quote
Old 03-17-2022, 01:06 PM   #7
michael bustamante
michael bustamante's Avatar
i have a 67 engine harness for a c10, that i have modified to hun HEI and internally regulated alternator with electricric choke and Tach. and a headlamp relay
All the harness has been lengthened to hide the wirng in the passenger fender
I install breathalyzers for a living so i have the means to modify the harness correctly and crimped and soldered all new joints
80.00 plus ship
1967custom
michael bustamante is offline   Reply With Quote
Old 03-17-2022, 05:17 PM   #8
Ironhorse
Ironhorse's Avatar
Looks like you have a few options but as mentioned here are pics of the fuse block I have. Still in the truck, can cut at most any length needed for splicing. Nice clear lettering, does have some scale on the fuse clips. $22 shipped, money order or $$, do not have Paypal.
Wellington, Ks
Old 03-18-2022, 03:04 PM   #9
67sss
67sss's Avatar
Ironhorse........thanks for pics. A little to far gone for me.
michael bustamante- thanks but a little to fancy for me. I'd like a stock one.
C101968- message sent.
Old 03-18-2022, 06:49 PM   #10
Ironhorse
Ironhorse's Avatar
67sss, understand, it is a bit rough but good clear legible printing. Too bad the fuse clips have the rust scale as they do. Good luck in your search.
Wellington, Ks
Old 04-04-2022, 05:08 PM   #11
67sss
67sss's Avatar
found one. Thanks for all that replied.
