Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-22-2018, 12:52 AM   #126
Captainfab
60-66 Nut
Re: '60-'62 Power Brake Booster Adapter Bracket
In addition to those mentioned in post #1 of this for sale thread, there is a larger list in post #70. An even larger list including part numbers is included with every booster bracket.
Originally Posted by 60apache View Post
do you have a link to the compatible boosters?
Old 04-22-2018, 10:23 PM   #127
60apache
60apache's Avatar
thanks. aside from going to the parts store and measuring every one, does anyone know what the thinnest (closest to firewall) dual diaphram booster that will work with this bracket is?
60apache is offline   Reply With Quote
Old 04-22-2018, 11:21 PM   #128
Captainfab
60-66 Nut
I believe that most of the dual diaphram boosters will be close to the same depth. they are much deeper than a single diaphram booster. When you make a choice based on appearance versus suitability, you will usually be disappointed in it's function.
Old 06-20-2018, 10:44 PM   #129
Budman56
Budman56's Avatar
Thumbs up Re: '60-'62 Power Brake Booster Adapter Bracket
Payment sent thank you again. Awsum products.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 06-20-2018, 11:35 PM   #130
Captainfab
60-66 Nut
Payment received.
Old 04-19-2019, 10:52 PM   #131
mailman
mailman's Avatar
I need one for auto transmission.My truck was a 3 spd but converted and has the extra clutch hole.Thanks
mailman is offline   Reply With Quote
Old 04-19-2019, 11:25 PM   #132
Captainfab
60-66 Nut
I replied to your PM.
Old 11-25-2019, 09:20 PM   #133
Captainfab
60-66 Nut
Bump for those not aware that I make these.
Old 02-03-2020, 06:44 PM   #134
54Caddy
GM Addicted
54Caddy's Avatar
Have a black powder coated one available?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-03-2020, 10:22 PM   #135
Captainfab
60-66 Nut
No I do not have a powder coated '60-'62 standard booster bracket in stock in satin black powder coat. The powder coating takes about a week to have done, plus I am currently 4-5 days out on building and shipping orders.
Old 02-20-2020, 05:49 PM   #136
54Caddy
GM Addicted
54Caddy's Avatar
Thanks again John. Received bracket, painted it and installed with ease as always.
..Mac’s Garage..
IG:MacsGarage
Old 02-20-2020, 10:38 PM   #137
Captainfab
60-66 Nut
Thanks for the purchase, I appreciate it
Old 03-16-2020, 05:21 PM   #138
lowroder
Hi Captain.
Im John An i Have A 62 C10. With 4 spd an 235 6cyl.
Eventually ill be going to a auto trans. an most likely adding disc brakes . do you still offer the bracket kit for a 62 c10? how do i order. you may also email me at towm8tr@aol.com . Im in Ohio
lowroder is offline   Reply With Quote
Old 03-16-2020, 09:33 PM   #139
Captainfab
60-66 Nut
I sent you an email.
Originally Posted by lowroder View Post
Hi Captain.
Old 05-24-2021, 01:04 PM   #140
NathanC
Guest
Posts: n/a
Hi Captain.
I have a 62 C10 that I am converting to automatic.
Do you still offer the bracket kit for a 62 c10? If yes, I would like to order.
Also - once I have this, who can recommend a reasonably priced booster? I don't need the master cylinder as I added this a while back when I converted the front brakes to disc.
thanks,
Nathan
Old 05-24-2021, 10:06 PM   #141
Captainfab
60-66 Nut
I fabricate all of my products everyday including this booster bracket for the '60-'62 GM trucks. This is one way I attempt to make a living. All of my booster brackets come with a list of compatible boosters including part numbers. I will send you a PM with ordering and payment info.
Originally Posted by NathanC View Post
Hi Captain.
thanks,
Nathan
Old 06-14-2021, 12:01 AM   #142
62c30
I am needing one for a 61 and needing the bracket to mount a 73 and up power steering box. thanks
62c30 is offline   Reply With Quote
Old 03-17-2022, 07:21 PM   #143
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 04-04-2022, 11:11 PM   #144
60short
60short's Avatar
Hey Captain!
I am definitely a newbie to this whole thing, but can you tell me the difference between master cylinder bore, or how to calculate which one I should use?
I am looking to make minimal changes, but I have a transmission swap coming up ( t5) and I figure this is the only way to keep things straight while maintaining my drum breaks
Thank you
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 05-12-2022, 07:07 PM   #145
KVB
Could someone post a picture of how they modified the brake pedal pushrod please.
KVB is offline   Reply With Quote
Old 05-12-2022, 09:49 PM   #146
Captainfab
60-66 Nut
Here is a thread that shows one method.
http://www.67-72chevytrucks.com/vboa...d.php?t=564518
Old 05-14-2022, 07:56 AM   #147
KVB
Thanks.
Old 05-16-2022, 06:26 PM   #148
KVB
Here is what I ended up doing.
1965 GMC drum/drum
Power booster CARDONE 503715, 67-70 C10 application
Cut the eye off the end of the rod, threaded it 3/8”, 16 NC
Used a locknut, with a threaded 1.75” long union on the pushrod, drilled the union and rod, cotter pin.
Shortened pushrod length to 4.25”
Threaded the end which bolts up to brake pedal longer.
Old 09-27-2022, 05:37 PM   #149
Joe P
Active Member
1965 C60 Cab. Which Booster Bracket is correct? I will not be using the hydraulic clutch...
Joe P is offline   Reply With Quote
Old 09-27-2022, 10:58 PM   #150
Captainfab
60-66 Nut
Then you will need the '60-'62 standard booster bracket which is the subject of this for sale thread. All of my products can be seen and purchased in the online store at our website. Here is the link.
