Old 05-07-2020, 10:46 PM   #1
674wd
67 stepside 4 wheel drive
I have been working on this truck for a long time. about 95 % finished. Its a 67 4 wheel drive stepside with AC. Everything is along original lines including the buddy bucket seats. The drive train is heavy duty, 427 big block,New Venture 4500 5 speed manual, NP 205 transfer case and Dana 60 axles front and back with eaton type posi traction in both. I will get pictures on here as soon as I figure this site out. Still have to finish the AC and heater lines and clean up wiring under hood. Has Vintage air in it and cab is original AC cab from 67.
674wd is offline   Reply With Quote
Old 11-14-2021, 12:58 AM   #2
raggedjim
raggedjim's Avatar
Re: 67 stepside 4 wheel drive
This is a damn nice truck! Great work on it.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 11-14-2021, 07:37 AM   #3
jjzepplin
jjzepplin's Avatar
OH my! That's pretty fancy!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-14-2021, 07:57 AM   #4
68panelman
68panelman's Avatar
What a beautiful truck. Now I know what my 2wd 505 green 67 would look as a 4x4. Great job!
68panelman is offline   Reply With Quote
Old 04-03-2022, 01:58 PM   #5
674wd
Thank You for the comments. I will post some updated pictures on here. It looks a lot better now with off road tires and under the hood finished up.
Old 04-03-2022, 02:35 PM   #6
674wd
Here are a few recent pictures.
Old 04-03-2022, 02:40 PM   #7
674wd
I will try to put some start to finish pictures on here when I get a chance. I started with just a bare frame and gathered all of the body parts as rust free as I could find them. Did all of the work myself except the final body work and painting. It's basically a brand new 1967 chevy pick up with heavy duty drive train added and 6 inch lift springs all around.
Still need to charge up the AC and install the radio delete plate and a few small odds and ends.
Old 04-03-2022, 02:41 PM   #8
674wd
The colors are a green two tone option from a 1957 Chevy Car. The darker color is Sherwood Green and the lighter is Surf Green.
Old 04-16-2022, 02:18 PM   #9
674wd
I finally installed the radio delete plate. Couldn't find the original clips, so I followed someone's suggestion and purchased body molding clips, stainless fender washers and stainless nylon insert locknuts (aircraft nuts) .
The body clips must be 2 1/2 inches across and I purchased them from Classic Industries ( part number A19807) 5 in a pack- you will only need 2 for the job. I will include pictures. Also I put black duct tape on the back edge of the delete plate to prevent it from digging into the paint.
Old 04-16-2022, 02:57 PM   #10
Delco115
Oh my, ...... what a beautiful truck you have !!! Thanks for the pictures.
Delco115 is offline   Reply With Quote
