Old 04-08-2022, 09:51 PM   #1
v30crewcab
v30crewcab's Avatar
5.3 4l80 71 chevy
I got a 71 c10 longbed, and I am looking to drop a 5.3 4l80 in it. Can you do it without a high hump if you move the motor and trans forward, and if you do that, will the driveshaft fit without shortening? just trying to plan ahead a bit. I have a high hump, but if it will fit without no reason to use it.
I know I'll have to change the slip yoke to a 32 spline.
Also, since its already auto, I assume I can reuse the trans crossmember and just move it? Thanks.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-10-2022, 08:07 AM   #2
Davidf
Re: 5.3 4l80 71 chevy
Engine/trans fits no problem on low hump without modification in any position. I had a single piece driveshaft made for my longbed. I used the trans yoke from the doner. I used Hooker Blackheart motor stands and trans crossmember with F body motor mounts.
Davidf is offline   Reply With Quote
Old 04-10-2022, 08:39 AM   #3
v30crewcab
v30crewcab's Avatar
nice thank you. I need to get rolling on this project I guess.
71 longbed 5.3 4l80
Old 05-08-2022, 01:17 PM   #4
v30crewcab
v30crewcab's Avatar
anyone else use the vapor canister vent on the pass side of the tank for fuel return? any issues? I'm planning on running the in cab fuel tank for stage one of this build.
71 longbed 5.3 4l80
Old 05-10-2022, 09:05 AM   #5
v30crewcab
v30crewcab's Avatar
I guess I'll order up a 72 sending unit for the return.
anyone use evil energy fuel line kit?
https://www.amazon.com/dp/B08KTBTWB6...NrPXRydWU&th=1
71 longbed 5.3 4l80
Old 05-10-2022, 05:27 PM   #6
kev2809
low n' slo
kev2809's Avatar
i went with evil energy hose but not the fittings. i went through summit and picked exactly what i wanted/needed for the fittings. havent ran the truck yet though, but they do look nice
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-10-2022, 08:54 PM   #7
v30crewcab
v30crewcab's Avatar
I like the look of the black hose and fittings. don't want red and blue fittings on the engine.
71 longbed 5.3 4l80
Old 05-10-2022, 08:59 PM   #8
kev2809
low n' slo
kev2809's Avatar
all my fittings from summit were black
I made a how to post with links to every fitting I used
-_--_--_ _________
Old 05-10-2022, 09:24 PM   #9
v30crewcab
v30crewcab's Avatar
good to know. thanks
71 longbed 5.3 4l80
Old 05-15-2022, 05:05 PM   #10
amashal
amashal's Avatar
I just finished my swap a couple weeks ago. I used the evil energy kit. I expected a few leaks just because this was the first time I made my own fuel lines. Primed the pump and didn’t have a single leak. I also used their inline pump and filters. So far so good. Have about 50 miles on it so far.
amashal is offline   Reply With Quote
