05-23-2022, 01:51 AM | #1 |
C10 CLUB Y QUE!
suspension (airbags)
So for some odd reason my passenger side seems to ride as if there is no shock installed. Bounces a lot more than the driver side. I've replace the shocks with new ones. but i still get that passenger side bounce. not sure if maybe my A arms shafts might need to be replace maybe?
Thanks for help... |
05-23-2022, 05:24 AM | #2 |
Moderator
Re: suspension (airbags)
IHmmm that sounds strange, do you have sway bars?
05-23-2022, 01:08 PM | #3 |
C10 CLUB Y QUE!
Yeah i got that as well. I know it can't be the shock angle since both side are the same. Maybe it's my cross bar shaft.
05-24-2022, 08:25 AM | #4 |
It could be bind. If you're not sure, re-check things to eliminate that.
05-24-2022, 11:22 PM | #5 |
C10 CLUB Y QUE!
now im wondering where could of i be getting a bind? shafts too tight?
05-24-2022, 11:34 PM | #6 |
Yes. Unless you're 100% sure, it's worth checking.
05-25-2022, 10:11 AM | #7 |
C10 CLUB Y QUE!
So the shaft needs to be loose enough to turn by hand right?
05-25-2022, 10:54 AM | #8 |
There shouldn't be much resistance on the older threaded rubber lined steel bushings when pivoting them from compression to extension. Check upper & lowers.
The later 73-87 rubber pieces will have more resistance/bind.
05-25-2022, 10:06 PM | #9 |
C10 CLUB Y QUE!
ok ill re check them and see thanks for the info.
06-04-2022, 10:54 AM | #10 |
C10 CLUB Y QUE!
Issue was fixed when i installed new rear shocks
06-04-2022, 12:45 PM | #11 |
Thats good then 😎
06-05-2022, 03:47 PM | #12 |
C10 CLUB Y QUE!
yeah thanks for the help Scott
06-05-2022, 04:16 PM | #13 |
Anytime. I ruled your shocks out because of the mention about them already being replaced. You wouldn't expect that so it makes trouble shooting more difficult.
Share some pics!
