Old 06-05-2022, 07:39 PM   #1
7D2N
7D2N's Avatar
Side Glass Removal Question
I plan to have my single wall top raptor lined but I need to change the side glass. I found some info here to get seal warm and plastic tools to pry out, this is original near as I can tell it's not very flexible. Do they reproduce single-wall window seals?
Thanks 7D2N
Just for the fun of it
7D2N is offline   Reply With Quote
Old 06-05-2022, 09:30 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Side Glass Removal Question
Single wall glass seals are available. SoffSeal product maybe? Classic Heartbeat and GMC Pauls both carry these.
Old 06-06-2022, 09:49 PM   #3
7D2N
7D2N's Avatar
Thanks, I will check into them.
Old 06-07-2022, 09:43 PM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Take a sharp knife to your old rubber. Cut off one side and push out the glass.
Tom Vogel is offline   Reply With Quote
Old 06-08-2022, 09:24 PM   #5
7D2N
7D2N's Avatar
Thanks Tom, I will probably have to cut the old rubber seals not to damage my glass.
Old 06-09-2022, 10:25 PM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I guess this goes without saying, but have someone outside (or inside) to keep the wondow from falling.
Old 06-09-2022, 10:55 PM   #7
truckster
truckster's Avatar
A little glass cleaner on the rubber will make your utility knife slice through it much more easily.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-24-2022, 10:50 AM   #8
scott123
Check as you push. I have seen a number where adhesive was used and it gets on the top itself. Easy to break a window when pushing. But yep, the utility knife rips right thru most of the time.
Made me think of a funny story.....I had a top once that was way beyond any repair. Just not a lot to work with but it had two really nice side windows, Sun ray at that.
A guy wanted to buy them but they had been glued in the rubber and the rubber had been glues to the top. He offered way more that what I thought they were worth but back tracked when they would not come out. He said at home he could use a heat gun and get them out.
I told him to stand back and I uses a circular/skill saw and cut his two windows out giving him a bit of top as well.
The next day he posted he had met the "Marcel Leddbetter" of Blazer parts.
Not suggested as a means to remove your windows.
Scott
scott123 is offline   Reply With Quote
