Old 07-05-2022, 02:39 PM   #1
C-cab23
C-cab23's Avatar
Front suspension questions
What is the difference between a 67-70 front suspension and a 71-72 front suspension ? Can they be interchanged ?
1968 GMC stepside long bed
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1946 Chevy 4 door sedan
1923 C-Cab
C-cab23 is offline   Reply With Quote
Old 07-05-2022, 03:31 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Front suspension questions
Different ball joints and tie rod ends. The hard parts are mostly the same. Crossmember, control arms. I think the center links are different.
Jason Banks is offline   Reply With Quote
Old 07-07-2022, 02:57 AM   #3
53burb
53burb's Avatar
one of big differences is 71 and 72 have disc brakes. Yes, they can be interchanged. complete cradles can be swapped.
53burb is offline   Reply With Quote
Old 07-07-2022, 08:46 AM   #4
HO455
HO455's Avatar
67-70's are more manly! 6 lug nuts and drum brakes.
The spindles are different too.
This thread should help answer your questions.
RIP Bob Parks.
Old 07-07-2022, 12:06 PM   #5
kwmech
Instead of jumping around in the different forums, post up what you want to accomplish with this truck. Give us a bigger picture of the truck also. We all like to see pics
Old 07-07-2022, 01:55 PM   #6
C-cab23
C-cab23's Avatar
What I want to do is lighten up the suspension to the half ton to give it a much better ride. Also I want to put disc brakes in the front. I plan on keeping the 9 foot bed cuz you don't see them very often. It has the 305 V6 with a 4 speed and I am planning on putting a 350 with a 5 speed. So basically I want to make it a much better driver. And I am open to lowering it a little too.
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1923 C-Cab
Old 07-07-2022, 05:46 PM   #7
kwmech
So going from 8 lug to 5 lug? or just want the softer ride? The V6 is comparable to the weight of a big block. Small block takes a lighter front spring. The springs are the same length, but the coil diameter is different for added weight. Right now what your are feeling when driving around is the stiff rear springs. give us a pic of the rear spring pack and where the leafs attach to the frame via the hanger. AND what does the weight tag say on the door pillar. 7500 or 10k
Old 07-07-2022, 09:34 PM   #8
C-cab23
C-cab23's Avatar
I will get pictures next week. The truck is at my shop and I am on vacation till Monday
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1923 C-Cab
Old 07-08-2022, 06:46 AM   #9
Easiest way is to get the whole from cross member (include steering box) from a 71 thru 78 1/2 ton. Unbolt ur 1-ton unit and put the new one in place. That way your front end parts fall under 1 year category for getting parts. Update any worn parts and you're good to goo there. Get a rear from same year trucks and bolt it to your current leafs. Maybe remove a leaf or to to soften the ride.
Old 07-08-2022, 11:00 AM   #10
kwmech
Easiest way is to get the whole from cross member (include steering box) from a 71 thru 78 1/2 ton...........
.................Maybe remove a leaf or 5 to soften the ride.
There fixed for ya
we haven't seen a pic of the rear springs yet, but if it's anything like my 1 ton, it has a lot of extras
Old 07-08-2022, 11:01 AM   #11
HO455
HO455's Avatar
A good spring shop will be able to build a set of custom springs to give you a softer ride.
Those High Clearance wheels aren't helping the ride either. They're either 17.5 or 19.5 (Hard to tell from the picture so, I could be a wrong. ) and those size tires generally are 10 plus ply tires which ride like Flintstone wheels.
If those truly are High Clearance wheels don't scrap them there are folks looking for them.
RIP Bob Parks.
Old 07-08-2022, 11:40 AM   #12
72SB
I would add a front sway bar to whatever conversion you do if you don't aready have one
72SB is offline   Reply With Quote
Old 07-08-2022, 09:34 PM   #13
C-cab23
C-cab23's Avatar
I don't plan on using those tires and wheels...I want to switch to either 5 or 6 lug wheels
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1923 C-Cab
