08-02-2022, 04:36 PM | #1 |
Dana 60 Problems
1970 C20 with HD leaf spring suspension and full floater D60 4.10 gears. I have a vibration that comes in at aprox 50 strong at 60-65 and fading at 70mph. Also causing a loud rumble type noise in the cab.
Putting the truck on jack stands I can duplicate the issue. Items eliminated are wheels, brake drums and driveshaft/u-joints. I can remove the wheels and drums with no change. Entire 2 piece driveshaft has been rebuilt balanced and then later shortened (trans change) and rebalanced again. Rearend shop said my pinion angle was off, so I installed 2 degree shims, shimmed the center carrier support lower. Working angles of the 3 u-joints are all under 2 degrees. Nothing has changed after all this work I don't notice any noise but the vibration is strong, shakes the rear view mirror. Any experts out there have comments?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-02-2022, 05:33 PM | #2 |
Re: Dana 60 Problems
Was the vibration there before you shortened (trans change) the driveshaft?
08-02-2022, 10:40 PM | #3 |
Yes been there for quite a while. I can't really say when it started. When I had the TH350 trans in the engine screamed and had unknown to me a mis installed clutch fan that ended up breaking the front of the water pump off. I was always thinking just poor tire balance. Even bought new tires and had everything road force balanced.
If this helps I also ran it on jack stands with the rear portion of the drive shaft removed. Silky smooth
08-02-2022, 11:06 PM | #4 |
Is the yoke installed deep enough?
Same motor with the t350 as it is now with the 700? Also, is the output shaft on the trans at the centreline between the frame rails or offset towards the passenger side rail? Last edited by geezer#99; 08-03-2022 at 12:29 AM. |
08-03-2022, 09:38 AM | #5 |
Ill have to check, same trans mount just moved back in frame. Different 350 engine, like I said I can't really pinpoint when the vibration started, but it seems to be getting worse. I do drive it daily
08-03-2022, 10:28 AM | #6 |
Just throwing this out there, but over tightening the Ujoint caps can cause the joints to bind. Empire drive line gives the spec of tightening till the lock washer flattens then another, I think, half turn, it's on their web site. Or look up torque spec. Anyhow, I always start with the Ujoints.
j
White K20 |
08-03-2022, 11:49 AM | #7 |
Back story on drivetrain and changes recently--pics help sometimes also
08-03-2022, 03:29 PM | #8 |
Could be a case of the square body vibration mystery. There are multiple threads about a similar vibration at similar speeds. Most trucks don't have it. A few do. Those that have it generally resist attempts to fix. My 75 C10 does it sometimes although the speeds where it happens tend to be 65~75.
Things on mine that have been replaced over the years without fixing the vibration issue: All u-joints, Center drive shaft bearing, rear axle bearings, engine, flex plate, rear drums, front rotors, rear spring bushings, several sets of tires. Also had the front end redone with many parts replaced. Most of these parts were replaced because they needed replacing or I thought they did and not just to chase the vibration issue. |
08-03-2022, 09:56 PM | #9 | |
Posted via Mobile Device |
08-03-2022, 11:51 PM | #10 |
Have you measured the trans position between the frame rails yet?
08-06-2022, 01:30 PM | #11 |
A few things. What engine and transmission mounts are you using ? Poly will transfer vibration.
All 3 u joint operating angles must be equal. The rear axel when viewed from the side should be pointed down 1-2° less. Allow for that in your calculations.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-06-2022, 03:43 PM | #12 |
How much movement is in the pinion? Does the seal leak.
08-07-2022, 03:04 PM | #13 |
Factory replacement mounts. Rubber. I'll have to check my notes on the measurements. The operating angles of the u-joints are small, but I don't believe they are exactly the same.
08-08-2022, 01:32 PM | #14 |
Here are my measurements with the truck sitting in the garage. All measurements are based on angled down from front to rear of truck I'm also including the rear axle in this definition.
Engine/trans 2.2, front drive shaft 3.3, rear drive shaft 4.3, rear end 2.6. Per Spicer's app operating angles of the u-joints are 1.1 1 and 1.7 I obtained these from shimming the trans mount up slightly, shimming center carrier support down little over 1" and 2 degree shims at the left spring perches. I have not had a chance to measure the center line of everything horizontally yet, but eyeballing it trans looks to be centered and rear end is slightly towared the passenger side.
08-09-2022, 10:01 AM | #15 |
If I am reading your measurements correctly you should be good with the driveline angles. My 57 dump has way worse angles and doesn't vibrate. That has 5.14s so the shaft speeds are up there.
08-09-2022, 10:15 AM | #16 |
Thats what I think, the rear end shop is convinced that my driveline is the issue, since there is no noise from the differential that they could hear. They did look at it prior to shimming the trans mount 1/8" up and the carrier support 1/8" down (I already had shimmed the center support 1" down) Just trying to get this fixed, its the only issue I have for the truck outside of the body/bed rehab.
08-09-2022, 12:51 PM | #17 |
Still waiting for a pic of the driveshaft
08-09-2022, 01:48 PM | #18 |
No pictures as of now.
Back story: Always had a vibration at 50+ MPH blurred the rear view mirror. Totally stock C20 suspension with HD suspension and leafs in back Always thought it was tires. New wheels and tires: no change balanced tires multiple times: no change Went from TH350 trans to 2004R trans: no change Brand new crate 350 engine: no change Had driveshaft rebuilt including carrier support and balanced: no change swapped out th2004r for 7004r and had driveshaft shortened and rebalanced: no change Disc brake upgrade in front with rebuilt suspension: no change New rear brake drums: no change New tires (thinking old ones were the cause): no change Now I really started getting into this Put truck on jack stands supporting the rear end. Could duplicate vibration at speed. Remove tires: no change Removed brake drums: no change Removed rear half of driveshaft: smooth I reinstalled drums and wheels and only lifted one side of rear (open diff so you can do this) ran truck up to speed in gear: no change reversed sides up and retried: no change This told me it definitely was not axle or wheel assembly on either side: Read up on this as much as possible and shimmed center carrier support down 1": made it smoother on acceleration at lower speeds Rearend shop said my pinion angle was bad. Shimmed the rear up 2 degrees and replaced all the leaf spring bushings: no change at hwy speeds Rearend shop still says pinion angle is bad after test drive. I added a 1/8" or so plate moving rear of trans up and another 1/8" plate dropping center carrier support down. The addition of the 2 shims had the effect of changing the rear driveshaft angle a little. No change From what I can see without measuring the trans tailshaft is centered in the frame as well as the center carrier support. Looks like the pinion yoke is slightly on the passenger side of the frame.
08-09-2022, 01:53 PM | #19 |
No movement that I can feel. Does not leak. Rear end was rebuilt by a dealership years ago. they had my folks source a used ring and pinion as they didn't have one. All new bearings. I'd be surprised if not more than 20K miles on it.
08-09-2022, 04:44 PM | #20 |
My next test would be to load the suspension down or physically strap the suspension to simulate a load. If this changes it you have an angle issue. That said I think that you have a bearing issue with the axle. Either a loose pinion or wheel bearing. The axle being centered is not that big of an issue. Many axles arnt centered. Think of this. If the axle is square and the driveshaft is centered then the driveline angle, side to side, should be good. Same operating angle. As long as the angle isn't a true zero you can have angles bigger than recommended with no harm. The guide is for max ujoint life before you hit the vibration limit.
My 5500 dodge has had an empty vibration at 55mph since new. Once some wieght is on the flat bed it is basically gone. My angles are within spec. It does happen. Another thing you can try is flipping the driveshaft yoke 180 degrees and check that. Only seen 1 truck that this worked on. Edit late thought. How is the engagement and spline wear after the carrier bearing. This can add alot of potential vibration. Last edited by burnin oil; 08-09-2022 at 05:02 PM. |
