11-28-2021, 12:57 PM | #26 |
Re: 1965 c10 patina build
Your making great progress looks good!
11-28-2021, 03:07 PM | #27 |
Great to see things moving along with your build!
11-29-2021, 09:49 PM | #28 |
But Found Her 25yrs Later!
If you are doing that well using flux core, you'll find it a breeze with gas shielded.
11-30-2021, 08:13 AM | #29 |
Yes I know but what I have is all I could afford at the time. It has been a great little welder. I would love to upgrade to a better one with gas so much better to weld with
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
12-01-2021, 12:11 AM | #30 | |
That's all I have for now also.
12-01-2021, 09:06 AM | #31 |
12-07-2021, 08:06 AM | #32 |
I have the cab on and part of the front clip. I am going to patch the drivers side fender it is really rough.IMG_4611 by Daniel Crymes, on FlickrIMG_4610 by Daniel Crymes, on Flickr
12-07-2021, 11:38 AM | #33 |
Good work! That fender looks very rough. Is a replacement fender a possibility? I guess it could be challenging to match the patina though.
12-07-2021, 08:50 PM | #34 |
I am planning on priming the rockers light gray and thought I would do the same to the patch panel on the fender. I hope it looks of like that
12-18-2021, 08:04 PM | #35 |
Did some work on the door rust today then hung the doorIMG_4627 by Daniel Crymes, on FlickrIMG_4626 by Daniel Crymes, on FlickrIMG_4629 by Daniel Crymes, on FlickrIMG_4630 by Daniel Crymes, on FlickrIMG_4633 by Daniel Crymes, on Flickr
12-18-2021, 08:04 PM | #36 |
I will do the body work then just prime the corners and the rear of the front fender.
01-30-2022, 08:13 PM | #37 |
01-31-2022, 12:58 PM | #38 | |
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
01-31-2022, 08:38 PM | #39 |
It is pine I am staining it the dark color you can see on one of the short boards in the picture. What color should I paint the metal strips?
01-31-2022, 09:47 PM | #40 |
I didn't repaint my strips, but they still have some of the original, black paint left. I really like the look of the black strips with the color stain I have. Post 588
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-01-2022, 08:32 AM | #41 |
Yes the black strips you have look great!
05-03-2022, 09:02 PM | #42 |
Slow go but got the interior painted and ready to put together. I order a bunch of parts just waiting on them.IMG_5437 by Daniel Crymes, on FlickrIMG_5438 by Daniel Crymes, on FlickrIMG_5434 by Daniel Crymes, on Flickr
08-21-2022, 06:30 PM | #43 |
08-21-2022, 06:31 PM | #44 |
Click on the picture for the video of it running
08-21-2022, 06:58 PM | #45 |
It's great to hear it run! For the radio cut outs, did your truck come like that, or did you have to repair and cut out for the radio? I will have to do mine soon and have a template, but will have to make sure it is correct.
08-23-2022, 07:02 AM | #46 |
I put a radio delete plate where the radio was.
08-23-2022, 08:18 AM | #47 |
09-25-2022, 07:26 PM | #48 |
Done with another project. Here are some pictures.IMG_5738 by Daniel Crymes, on FlickrIMG_5735 by Daniel Crymes, on FlickrIMG_5731 by Daniel Crymes, on FlickrIMG_5729 by Daniel Crymes, on FlickrIMG_5722 by Daniel Crymes, on FlickrIMG_5719 by Daniel Crymes, on Flickr
09-25-2022, 07:29 PM | #49 |
IMG_5720 by Daniel Crymes, on FlickrIMG_5714 by Daniel Crymes, on FlickrIMG_5713 by Daniel Crymes, on FlickrIMG_5732 by Daniel Crymes, on Flickr
