02-19-2022, 10:19 AM | #101 | |
Re: 57 Fleetside C4 build
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
02-19-2022, 10:22 AM | #102 | |
02-19-2022, 07:46 PM | #103 |
Cam specs for the cam they used are.
Duration at .050 Intake 217 Exhaust 225 Lobe Lift Intake .370 Exhaust .270 Valve Lift @ 1.7 Intake .629 Exhaust .629 Lobe Separation 113 Intake Center Line 110 Steve
09-11-2022, 05:42 PM | #104 |
Hi All, I am behind on posting about the progress on my project and will update to present. This will start from March till now. The first pictures are of the hood and bedsides being in the first coats of primer. Nor real exciting but all part of the process. Steve
09-11-2022, 05:59 PM | #105 |
Some More primed parts. Steve
09-11-2022, 06:23 PM | #106 |
With all the body panels in the first coats of high build primer I moved on to the chassis. These are pics of the disassembly. Steve
09-11-2022, 06:41 PM | #107 |
After the disassembly of the chassis I began to recondition individual components as needed and paint. Steve
09-13-2022, 09:04 AM | #108 |
You’ve made great progress this summer. Keep up the good work! I really like your garage.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
09-13-2022, 04:47 PM | #109 |
Thank You. I am making decent progress now. Right now getting the cab ready to paint the firewall and put truck bedliner on the bottom the cab then will put the cab on the chassis for the last time!! Steve
09-13-2022, 05:03 PM | #110 |
Some pics from late May early June. I sent the frame out to be sand blasted and some more pieces of the chassis that I cleaned up and painted. Steve
09-13-2022, 05:18 PM | #111 |
These are pics are from late June early July. Frame came back from sand blast and got it prepped for epoxy primer and gloss black single stage urethane. I only filled some of the pits in the frame and smoothed out some of the welds. I am going for a nice driver that I could show if I wanted not a Kindig build. Steve
09-14-2022, 04:57 AM | #112 |
Well I think I kin dig it! Sorry, just had to say it.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
09-14-2022, 10:21 AM | #113 |
More pics and hope to be caught up soon. These are from late July as I was assembling the chassis. Steve
09-14-2022, 10:30 AM | #114 |
Still in late July. More chassis assembly pics. Steve
09-14-2022, 06:41 PM | #115 |
Some more progress pics from July. I have a rolling frame at this time and then turned to getting the 6.0 LS and 4L80E trans cleaned up and painted. Steve
09-14-2022, 06:53 PM | #116 |
More Engine and trans pics with final paint on them. Steve
09-16-2022, 06:25 PM | #117 |
Pics from early August. Reinstalled all the accessories back on the engine along with the core support I test fitted the radiator so could figure out the fan situation. Everything fit well put only have .140" of space between the fan and the water pump. Won't know if I will be all right till I hang the sheet metal but am pretty confident. Steve
09-16-2022, 06:42 PM | #118 |
Pics from late August. Frame and drivetrain pretty well squared away. Back to the body now. Almost caught up with the updates. Steve
09-16-2022, 06:58 PM | #119 |
Blocked out the cab for the first time. There is a lot of mud from all the panel replacements and 65 years of dents. Here are the pics. Steve
09-17-2022, 09:11 AM | #120 |
This should get me caught up on my project. I put three coats of 2K primer surfacer on the cab. I will block all this out with 180 put a couple more coats of 2K the block with 400 and paint. Getting closer all the time. I have painted the middle of the firewall with color. The next step is to spray the bottom of the cab with tintable raptor bed liner then put the cab on the chassis for the last time. Steve
09-19-2022, 06:26 PM | #121 |
Sprayed the raptor bed liner on the lower part of the firewall, Lower plenums and the bottom of the truck. I tinted it per instructions and it came out a little lighter but acceptable. You really don't see much of this once all together. The cab should go back on the chassis this weekend. Steve
09-20-2022, 01:11 AM | #122 |
nice job. looks great. curious, are the lower rear cab corners inner and outer or just the outers? hard to tell in the pics and they are so smooth.
09-20-2022, 09:17 AM | #123 |
Looks great! I’m anticipating seeing color. We are both at the same point in our builds. If all goes well for me I hope to paint my cab today. Keep up with the progress pictures.
09-20-2022, 09:18 AM | #124 |
Thanks for the comment. I did inner and outer cab corners. Steve
09-20-2022, 09:26 AM | #125 |
Great job is all looks very sanitary....
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
