Active Member
![]() Join Date: Dec 2020
ISO Blazer Jimmy spare tire carrier carriage bolt
ISO Blazer Jimmy spare tire carrier carriage bolt...and nut
Active Member
![]() Join Date: Jan 2008
Re: ISO Blazer Jimmy spare tire carrier carriage bolt
I’m just curious and this question may be ignorant as I’m not completely sure, I have a couple of carriers that I’m restoring, I have the carriers and oversized washers, but as far as the bolts go, isn’t it almost exactly like a carriage both readily available at any hardware store?
Active Member
Ya probably pretty close.
Active Member
WOW 👏 what a genius I never thought about using Google...thanks
It's easier, though less productive, to ask, then wait hours, than do a search that returns answers in a second or check a hardware store, where nuts and bolts live.
Active Member
![]() Join Date: Aug 2015
69-72 is a 7/16 fine thread carriage bolt that is over 6” long. Hard to find that as common hardware, if they exist at all. GM used a lug nut to fasten the wheel, hence the 7/16 fine thread bolt.
73+ changed to a 1/2 coarse thread and z-bar wing nut, so common carriage bolts are easy to come by in that thread. The washers were identical across years. Hope that helps.
71 K5 CST Blazer 350 70 Suburban 350 71 Chevelle SS 454 69 Olds 442 454 (yes, Chevy power!) 68 Camaro RS 327 66 Chevelle SS 396 Members I have met: 62cdan, 60case, daddymoo2, aotte1, 70shortfleet, countr, Cowboy#40, chevy71super, davischevy |
#9 | |
Active Member
Thanks that helps some., but I need an example to measure. |
