08-20-2022, 04:30 PM | #901 | |
Re: Working Man's Burbon
I looked at putting it under the dash thinking it would be slick and easy but, there just wasn't room without moving the whole cable towards the transmission. I decided that was going to be more work than running the wire to the transmission. Then the whole adapter saga started with only half of it showing up and the other half back ordered. It's so hard to feel like one is making progress these days.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-20-2022, 05:16 PM | #902 |
Yep, that makes sense.
08-20-2022, 05:29 PM | #903 |
Thank you.
08-20-2022, 06:59 PM | #904 |
Which speed sensor are you using and what is the purpose of the second speed sensor?
Thank you, TNANG Last edited by TNANG; 08-20-2022 at 07:16 PM. |
08-21-2022, 10:24 AM | #905 |
The Older Generation
You have been doing some pretty technical stuff here. I had trouble following what you were doing on both of them, let alone trying it myself.... LockDoc .
08-25-2022, 01:43 AM | #906 |
Could your Burb be any more dialed in? Great work and write up on the carb.
So What is the purpose of the speed sensor and even a second one? Are you adding cruise control?
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
08-25-2022, 07:30 PM | #907 |
EXCELLENT!!! Can't wait to start getting my Q-Jet dialed in. It starts pretty easily after sitting all night, and just the short little trips I've taken it seems OK. We'll see soon.
08-28-2022, 08:21 AM | #908 | |
https://67-72chevytrucks.com/vboard/...d.php?t=822382
08-28-2022, 08:36 AM | #909 |
Thanks Doc. But as someone who understands the magical inter-workings of locks you shouldn't sell yourself short.
08-28-2022, 08:40 AM | #910 | |
No cruise control control I just need to get my transmission lockup working correctly.
08-28-2022, 08:48 AM | #911 |
Thank you. Best of luck dialing yours in. It sounds like you're off to a good start already.
09-02-2022, 11:52 PM | #912 |
After getting mine back on the road, I pulled the 71 jets out of my Q-Jet, and replaced them with 70 jets. My lil 307 is much happier for the change.
09-21-2022, 10:44 PM | #913 |
I MADE FLAT RATE TODAY!
Yesterday I noticed something shiny hanging off the front of the WMB. Closer inspection revealed I had lost a bolt from the sway bar mounting strap. I started to reshape the strap when it dawned on me I might have a spare strap. After a bit of scrounging around the shop I located a similar replacement strap.(Photo #2) The replacement strap doesn't have any provision for greasing the bushing. So I cut the little nub off the bushing (Circled in photo #3) and drilled a hole in the strap on the front side so I can use a U-joint grease gun adapter. (Arrow in photo #3) The original mounts had zerks in the lowest part and I kept tearing them off on parking curbs. This should work better. I believe the reason the bolt fell out was the cheesy washers the mounts came with. Going back together I used heavy duty washers and nylock nuts. That should cure any future problems. I will do the same to the other side after a trip to the hardware store to get some more 1" bolts. Anyway it was under an hour to get the repair done.
10-12-2022, 10:16 PM | #914 |
Started the "Out with old and in with with the NEW process! After only two years of waiting for the upholstery shop.
10-21-2022, 11:08 AM | #915 |
Sorry for the cliffhanger posting. I thought I would be adding some installed photos later that day but, things did quite work out as I expected. After I got the new seat installed and sat on it I realized the foam cushion was way too tall.
Compared to the old seat I was now sat about 3 or 4 inches higher. When I sat straight and looked directly ahead I was looking at where the window seal meets the sheet metal. Obviously that wasn't going to work so I called the upholstery shop and they said to bring the seat back to them and he would take 2 inches of foam out of the cushion. So out with the new and in with the old! Ugh! Now more waiting for the upholstery shop! But before I put the old seat back in I needed to repair the frame. Months ago my buddy was riding in the truck and decided he needed something out of his pocket so he pushed against the back with his legs and BANG! The seat broke. In the months since with one side broke the drivers side eventually cracked and now the back now moves back and forth a couple of inches. After 4 hours of messing around with hammers, clamps, grinders and the welder I had the old seat repaired and installed. No photos of that part of the dog and pony show as I was racing to finish the repairs before dark. The next day I dropped the new seat off for the foam height adjustment. Fast forward to yesterday and here is the adjusted seat installed. It is still a bit too tall as I'm looking through the tinted strip across the top of the window. I'm hoping the foam will soften up some with use. If not I may have to modify the mounts to lower the seat an inch. Outside of that that the seat is nice and comfortable. The old lady even commented on how much better it feels than the old one. Big win there!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 10-21-2022 at 01:11 PM. Reason: Changed 2nd photo. |
10-21-2022, 11:26 AM | #916 |
Seat looks great! The color is about like the one I used in my suburban. I like the insert you went with for it. Its always nice to have a comfy seat.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
10-21-2022, 11:41 AM | #917 |
Thank you! The inserts are the 72 factory Highlander Grey plaid. I went for the "What if there were 67 Highlanders" vibe.
I was surprised how un-grey the Grey fabric is but the color seems to change between goldfish and Grey depending on lighting. I now need to finish prepping the back seat mounting brackets and get them installed with the matching seats.
10-21-2022, 10:57 PM | #918 |
Outstanding look!!! The colors go really nice together...and you got that fold-down armrest with cupholders that you so desired!
Woody |
10-22-2022, 11:05 PM | #919 |
Looks real good.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
10-26-2022, 11:34 AM | #920 |
BlahBlahBlah
Fold flat rear seat ... Early on in this thread someone mentioned when they installed the fold flat seat they had to move the front seat all the way forward for the rear to fold flat. Now you mentioned you were over 6ft, has this been the way it works for you having to move the drivers seat all the way forward to get the rear to fold flat? Or is your way of mounting the rear seat different than the other fella did his? Having the drivers moved all the way forward would be a no go for me and you're taller than I am.
10-26-2022, 02:20 PM | #921 |
Thank you sir! Compared to yours it's pretty basic.
10-26-2022, 02:20 PM | #922 |
10-26-2022, 03:01 PM | #923 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 10-26-2022 at 03:14 PM. |
10-27-2022, 10:53 AM | #924 |
BlahBlahBlah
Ok thanks for the clarification ... Glad to hear this is how it works out.
10-31-2022, 05:58 PM | #925 |
Some progress photos on the rear seats. Man I will say any savings GM saw when they went from a wood floor to a sheetmetal floor was more than eaten up by the 2nd row seats. There must be a hundred parts to them.
One really pleasant surprise has been how close the green upholstery and the powder coated seat backs match. I didn't have a sample of the new upholstery when I took the backs into be powder coated, so I just tried to match the old upholstery. I most certainly got lucky with that guess.
