11-06-2022, 07:57 AM | #1 |
Re: 1986 K10 4 speed to 5 speed
Well now we are getting into the mut part of the truck… it’s an 89 1 ton cab with an ‘86 frame.
The 465 came with the ‘89 cab, it was a 1 ton dump. Not sure where the 208 came from. Thanks for this info, I’ll search up more info on the tranny/tcase info provided and see what I get. Also the truck has a 3” lift. |
11-06-2022, 08:07 AM | #2 |
This is the truck, I should also mention I mostly build 2WD so my 4WD knowledge needs work.
11-06-2022, 09:10 AM | #3 | |
The later 85 up trans crossmember will work with the nv4500/208 Its a pretty straight forward swap. Heck I did it in the 90s (pre internet days) so you shouldn’t have a problem. |
