Old 11-15-2022, 12:01 AM   #2676
Wikid61
Wikid61's Avatar
Re: Post Your Craigslist Finds Part 2
https://fortcollins.craigslist.org/cto/7548207547.html
Wikid61 is offline   Reply With Quote
Old 11-15-2022, 12:02 AM   #2677
Wikid61
Wikid61's Avatar
71 GMC 1/2 ton, 2WD, A/C cab, PS, PB, factory front disc brakes. 350 V8 with 4 speed manual. Resprayed original paint color back in early 2000's. Runs great and a fun truck to cruise around. I am the 3rd owner of this truck, bought it from a lady who's dad bought it from a dealer in California. I have a box full of receipts dating back in the 70's. I also have several new interior parts from LMC I never installed. This is a legit sale, I just moved from Utah a few months ago and towed it back to the Springs on Oct. 9. Clean UT title in hand. eight zero1 5eight9 25seven4
C10, Chevy, Chevrolet C10, Chevrolet, half ton, GM https://cosprings.craigslist.org/cto/7556329840.html
Old 11-15-2022, 12:03 AM   #2678
Wikid61
Wikid61's Avatar
1968 Chevy c10 factory short bed. 3rd owner minor rust in rocker’s. 5.3 ls engine 4l60e transmission. Completely rebuilt front end( CPP steering gear brake booster and master cylinder lowering kit and front and rear stabilizer bars ) new drive shaft. PSI WIRING HARNESS. New gas tank and fuel system. Drive anywhere. Nice patina! $38,500 https://pueblo.craigslist.org/cto/7554706075.html
Old 11-15-2022, 12:05 AM   #2679
Wikid61
Wikid61's Avatar
1972 Chevrolet Cheyenne Super-10 Original short bed big block 402 CI engine HI Performance Casting # 3999290 4 bolt main. 92,905 original miles, 400 Automatic Transmission. PS,PB, Tachometer, Bucket Seats console in the middle. Truck was in need of a full restoration. This truck has been in the restoration stages for the pass 4 years and pretty much close to be finished minus the little things like some bright work and front bumper. Truck is fully operational and runs great. Frame, sheet metal, body, paint and some new trim, bumper and bed wood and stainless strips all restored and beautiful condition. Truck was painted 11 months ago back to the original dark olive green with white top. Has all brand new suspension with 2" 1/2 front dropped spindles and 4" drop coil springs in the rear , new shocks at that time. Cab and rockers had original nos chevy panels repaired done in the typical areas of rust. Work all done correctly by a professional. Truck runs and drives beautifully. Absolutely beautiful 72 Cheyenne and rare with the Super-10 Model tach/bucket seats/Big Block https://denver.craigslist.org/cto/7556417503.html
Old 11-15-2022, 12:07 AM   #2680
Wikid61
Wikid61's Avatar
https://denver.craigslist.org/cto/7551704176.html
Old 11-15-2022, 12:08 AM   #2681
Wikid61
Wikid61's Avatar
https://albuquerque.craigslist.org/cto/7547223252.html
Old 11-15-2022, 12:09 AM   #2682
Wikid61
Wikid61's Avatar
Interested in selling my late father's 1972 C10 lwb w/ original patina. Before passing, everything was gone through and was driven daily. Body is straight and all doors open/shut well. Engine Runs/shifts well. It does have usual rust (rockers and cab supports need work), but most all other rust is just surface rust. Just needs to be enjoyed!
SBC 350w/ timing gears and Lunati cam (believe upgraded heads nut not sure)
Holley Performance 4 Barrel Carb
350 trans (to my knowledge)
All New:
Brand new (21 circuit) Wire Harness installed
Wheel Bearings
New Drive Shaft & U-joints
Tie Rod ends (inner/outer)
Front/Rear Brakes (new)
Dual Exhaust
CPP Steering Column (linkage needs adjusted, difficult to do with only one person)
Dash Guages (refurbished) with LED backlighting
All Lights works
Tires are 2 years old w/ 95%tread left
Gas Tank (relocated to under bed)
Have bench seat lowering brackets (not installed)
Body is not perfect, but has a lot of potential for the patina look! Truck is stock height, and is ready to be put at any stance you would like. Does need power steering pump and lines installed. Current gear box condition is unknown.
I do have clear Colorado title in hand!
I would keep it, but do not have the room. Also trying to finish my '64 GMC frame-off build.
Text: (6one5)30zero-64two6
**** I do Not Need help selling this vehicle.
Serious inquiries only.
No test drives without cash in my hand.https://denver.craigslist.org/cto/7550923054.html
No Trades! (I don't have the room)
Old 11-15-2022, 12:52 AM   #2683
CG
BlahBlahBlah
Wikid61, you sir are a machine!
Old 11-15-2022, 03:09 AM   #2684
Wikid61
Wikid61's Avatar
Yes, I have been labeled that in the past. In the 'zone'.
Old 11-15-2022, 03:10 AM   #2685
Wikid61
Wikid61's Avatar
https://seattle.craigslist.org/sno/pts/7556848808.html
Old 11-15-2022, 03:11 AM   #2686
Wikid61
Wikid61's Avatar
https://seattle.craigslist.org/tac/pts/7549396631.html
Old 11-15-2022, 03:13 AM   #2687
Wikid61
Wikid61's Avatar
https://vancouver.craigslist.org/van...552413412.html
Old 11-15-2022, 03:14 AM   #2688
Wikid61
Wikid61's Avatar
https://seattle.craigslist.org/sno/pts/7546477771.html
Old 11-15-2022, 03:17 AM   #2689
Wikid61
Wikid61's Avatar
https://spokane.craigslist.org/pts/7553445805.html
Old 11-15-2022, 03:18 AM   #2690
Wikid61
Wikid61's Avatar
https://sacramento.craigslist.org/pts/7557325621.html
Old 11-15-2022, 03:19 AM   #2691
Wikid61
Wikid61's Avatar
https://medford.craigslist.org/pts/7556288980.html
Old 11-15-2022, 03:19 AM   #2692
Wikid61
Wikid61's Avatar
https://klamath.craigslist.org/pts/7548201518.html
Old 11-15-2022, 03:20 AM   #2693
Wikid61
Wikid61's Avatar
https://roseburg.craigslist.org/pts/7554058620.html
Old 11-15-2022, 03:21 AM   #2694
Wikid61
Wikid61's Avatar
https://boise.craigslist.org/pts/7548809253.html
Old 11-15-2022, 03:23 AM   #2695
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/sfc/pts/7548082391.html
Old 11-15-2022, 03:25 AM   #2696
Wikid61
Wikid61's Avatar
Complete grill assembly and outer surround for grill 400. miscellaneous patch panel 50. 1972 one year only hard to find door panel in nice condition not broken clips 300. tinted wing windows and door glass with stainless wing window post no scratches 325. hard to find rear cab stainless trim75. good passenger door 50. good working window cranks, and tracks50. ac firewall unit complete125. Ask if you want out of will be full price. Package deal 650 takes everything! https://santamaria.craigslist.org/pts/7557385913.html
Old 11-15-2022, 03:25 AM   #2697
Wikid61
Wikid61's Avatar
https://fresno.craigslist.org/pts/7557251457.html
Old 11-15-2022, 03:27 AM   #2698
Wikid61
Wikid61's Avatar
https://sfbay.craigslist.org/sby/pts/7557225981.html
Old 11-15-2022, 03:40 AM   #2699
Wikid61
Wikid61's Avatar
CHEVY C10 K5 BLAZER PARTS
blazer consoles, interior spare tire holder and hard top one piece windows and 72 rear gravel guards (may fit 69-71)
many dash knobs, pulls and cigarette lighters 67-72, 72 door panels - white and blue, original deluxe door panel stainless, wiper arms, gun racks
67-72 steering wheel
instrument cluster is untested, parts only
CALLS ONLY FOR PRICING|
562 EIGHT EIGHT FOUR 4566
do NOT contact me with unsolicited services or offers
post id: 7557099837 posted: a day ago ♥ best of [?]
safety tips
prohibited items
product recalls
avoiding scams
Avoid scams, deal locally Bewar https://orangecounty.craigslist.org/pts/7557099837.html
Old 11-15-2022, 03:41 AM   #2700
Wikid61
Wikid61's Avatar
https://sacramento.craigslist.org/pts/7552374509.html
