Old 11-18-2022, 07:02 AM   #601
OKGMC4
OKGMC4's Avatar
Re: Yet another GMC build
So many hours wet sanding, compounding, and polishing but looks real nice. I don’t think you can really tell this fender has ever been cut. The other fender has a big black melted bug in the clear so I get to do more spot repair. Yippee!!!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 11-18-2022, 10:34 AM   #602
Rickysnickers
That looks very nice, but I'm sorry, I had to laugh at the last sentence
Old 11-18-2022, 09:47 PM   #603
56 3100
56 3100's Avatar
Nice work OKGMC4. Any more details on door speaker pods.?
56 3100 is offline   Reply With Quote
Old 11-19-2022, 07:48 AM   #604
Nut Case
Nut Case's Avatar
Strong work.... lots and lots of it
keep on keepin on
nutz
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 11-19-2022, 09:52 AM   #605
OKGMC4
OKGMC4's Avatar
Thanks, guys! I have the speaker pods in primer but haven’t decided whether to do vinyl or paint. Been so focused on paint haven’t really been working on interior.
Old 11-20-2022, 06:39 PM   #606
OKGMC4
OKGMC4's Avatar
More progress.
Old 11-22-2022, 06:25 AM   #607
OKGMC4
OKGMC4's Avatar
Am I the only one who’s noticed that it appears Dodge may have robbed some grill design cues off from GMC?
Old 11-22-2022, 06:56 AM   #608
OKGMC4
OKGMC4's Avatar
Dyed the charcoal door bottoms black.
Old 11-22-2022, 10:52 AM   #609
dsraven
Yeah, I noticed the dodge copycat thing too. Maybe they wanted them to look as good as possible when they are parked on the side of the road waiting for the tow truck, lol.
Old 11-22-2022, 10:44 PM   #610
Russell Ashley
Russell Ashley's Avatar
You guys are grasping at straws. I realize this is a GM oriented site but it's a stretch to compare those. Here's a couple to compare. This was my 69 Dodge and an 83 S10. I won't even bother to show my 65 Ford truck grill. I've had Fords, Chevy's, and Dodges, but the only one who ever left me walking down the expressway was a Chevy. I love them all including the 96 Z71 I have now.
Russell Ashley is offline   Reply With Quote
Old 11-22-2022, 11:15 PM   #611
dsraven
well, how do you suppose dodge got the blueprints for a chevy S10 grille that many years ahead of production.....weird.
Old 11-23-2022, 06:09 AM   #612
OKGMC4
OKGMC4's Avatar
It might also be safe to assume that maybe the designers may or may not have been inspired by the older trucks. If your grandpa had a cool truck when you were a kid it could stick with ya. I think nostalgia is the whole reason for the recent shapes of the Mustang, Camaro, and Challenger.
Old 11-23-2022, 01:30 PM   #613
57tailgater
Funny mentioning this. I happened to see a Porche Cayenne yesterday that had some sort of dash item that looked just like early 50's Olds dash clock install. Round, blended into the top of the dash and all! What goes around comes around!
57tailgater is offline   Reply With Quote
Old 12-02-2022, 07:25 AM   #614
OKGMC4
OKGMC4's Avatar
Been thinking of doing a spray in bed liner so I don’t have to be so picky about what goes in the back. Also want to coat the aluminum tool box so it blends into the truck better. I ordered an orange sample from Durabak and think the color looks close enough. Will probably pull that trigger after the bed is back on.
Old 12-02-2022, 04:22 PM   #615
OKGMC4
OKGMC4's Avatar
Foam, glue, vinyl, and staples. I’m officially 25 percent done with door panels.
Old 12-03-2022, 04:20 PM   #616
OKGMC4
OKGMC4's Avatar
I wrapped a speaker pod in vinyl. I used Morbern 4 way stretch from Sailrite. Not sure any other vinyl could have passed this test. Contact adhesive and stretch. Work out wrinkles and stretch. Stretch and staple. Then pull some more. Had to reactivate the glue in a couple spots with the heat gun. Then trim excess from the base with a razor blade.
Old 12-03-2022, 11:35 PM   #617
Kevin_C
looking good. I recently ordered the same 4 way from sailrite for my console. I'm hoping I can get it to stretch enough with all my curves.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 12-07-2022, 04:15 PM   #618
OKGMC4
OKGMC4's Avatar
More progress on the upper door panel
Old 12-07-2022, 05:01 PM   #619
hotrod1
56 - autocross
hotrod1's Avatar
That is so clean looking. Nice!
hotrod1 is offline   Reply With Quote
Old 12-08-2022, 10:42 AM   #620
Rickysnickers
That looks very nice!!
Old 12-08-2022, 02:20 PM   #621
hotrod1
56 - autocross
hotrod1's Avatar
This answer is probably back there somewhere, but what paint and color (satin black) did you use for the interior? Are you happy with the performance of the paint?
Old 12-08-2022, 04:56 PM   #622
OKGMC4
OKGMC4's Avatar
Summit Racing hot rod black, part number up312. I used it under the hood and also inside the cab. Lays down pretty well and easy to mix at 4:1 ratio.
Old 12-08-2022, 05:36 PM   #623
hotrod1
56 - autocross
hotrod1's Avatar
Thanks - Did u paint the chassis with that also?
Old 12-08-2022, 07:03 PM   #624
OKGMC4
OKGMC4's Avatar
Should have. Shot the frame in summit epoxy primer, then with Rustoleum semi gloss black. I mean, it’s covered, but the Rustoleum scratches pretty easy. That epoxy doesn’t budge. Since it’s a frame on a driver I can let it go…but so far if you bump the Summit black it stays put.
Old 12-08-2022, 07:08 PM   #625
OKGMC4
OKGMC4's Avatar
Wanted to get away from the billet grill look a little bit so shot the grills in semi gloss black, then used KP pigments hyper silver pearl in 4 coats of mid coat clear, then 2 coats of high solids clear. Was trying to match the pearl on the wheel spokes. Not 100 percent match but real real close.
