Old 12-04-2022, 07:24 PM   #1
rustycars63
1949 chevy truck ignition switch
What is the best ignition switch for an in dash switch for a ls 5.3 swap ?
rustycars63 is offline   Reply With Quote
Old 12-04-2022, 09:28 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 1949 chevy truck ignition switch
Are you rewiring the truck?. I used American autowire harness for the truck side..it came with a really nice dash switch.. but you can get a universal key switch at oreillys as well
The only thing needed from the switch for the LS is switch on power to the ecm, the starter wire routes the same as any other engine, from switch to nss to starter solenoid
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-05-2022, 10:07 AM   #3
rustycars63
Thanks I will be rewiring truck and will us aaw harness for now just need switch to see if engine will run. thanks. What kit from aaw did you use ?
Old 12-05-2022, 11:49 AM   #4
mongocanfly
I used the hwy15
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-05-2022, 03:03 PM   #5
rustycars63
thanks
Old 12-05-2022, 05:45 PM   #6
LS short box
Just note. The ECM needs 12 volts in the start and run positions. Also the ECM needs a constant 12 volts. Two separate wires.
Old 12-06-2022, 09:42 AM   #7
rustycars63
Any one have a 2005 ignition switch ls swap wiring diagram. Harness has been modified with Brandons web site. Thanks
