Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-08-2022, 07:48 PM   #901
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
so heres my plan for the floor. 2x6s bolted down using riv nut inserts. looks fun (not). well see how the rest goes..heres one little board down. want to get this row down so i can mount my air tank here...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-16-2022, 08:37 PM   #902
kev2809
low n' slo
kev2809's Avatar
got the front section done and the tank mounted. think i will start running all the air lines now
-_--_--_ _________
Old 11-16-2022, 08:58 PM   #903
LockDoc
The Older Generation
LockDoc's Avatar
Looks like that should work! Keep pluggin' away at it.....
LockDoc
Leon
Old 12-03-2022, 07:38 PM   #904
kev2809
low n' slo
kev2809's Avatar
got most of the airlines ran, just need to work on the front which i will be doing tomorrow. have been working on cleaning up and routing the wiring in the back, mainly for the compressors. also got the fuel hose buttoned up, and you know what that means! slapped some gas in it...and it fired right up! i have a video but need to figure out how to post it.
-_--_--_ _________
Old 12-03-2022, 07:39 PM   #905
kev2809
low n' slo
kev2809's Avatar
heres how i did the compressor wiring, i just need to tap the power wire into the truck fuse box and run to dual 8 gauge wires up to the battery and its done.
-_--_--_ _________
Old 12-11-2022, 08:12 AM   #906
KFF 1
KFF 1's Avatar
Looking good ! Nice work Kev
KFF 1 is offline   Reply With Quote
Old 12-13-2022, 10:08 PM   #907
kev2809
low n' slo
kev2809's Avatar
thanks!
dropped my old driveshaft off yesterday and hoping to have it back by the end of the week. getting oh so close to a trip around the block.
I have been messing around with the coolant and it just doesn't sit right with me. I put coolant through the radiator and the truck was getting hot it seemed. so I drained it, and pulled the upper hose and filled it up through there with the trucking running. I filled it up til it wouldn't take anymore, then topped off the radiator. the gauge seems high? I plugged my torque lite into the OBD2 port and it shows 188/90. that seems about right with an LS. I just don't see why this gauge shows so high?
-_--_--_ _________
Old 12-14-2022, 03:39 AM   #908
BAD1916
That trip around the block will feel amazing after all the work! I don’t know if the same problem exists with these trucks but at the Mustang shop I work at we have issues with the aftermarket sending units causing the gauge to read way higher than it should. It’s frustrating as hell. Sometimes a different brand resolves the gauge problem.
BAD1916 is offline   Reply With Quote
Old 12-14-2022, 05:22 PM   #909
kev2809
low n' slo
kev2809's Avatar
its a new stock sender (i drilled and tapped the passenger side head to use a stock style one). i mean, tbh, if this is "normal" looking for our style trucks then i really dont care. but from reading around and looking at other peoples gauges it seems 180-190 should be right in the middle somewhere. i tested the wire by unplugging it (went all the way cold), then grounding it (went all the way hot) so i know the wiring is good. i think i might still have the old sender off the 305 i took it off of, i could try and put that in and see what happens
-_--_--_ _________
Old 12-14-2022, 05:26 PM   #910
kev2809
low n' slo
kev2809's Avatar
oh, also got my driveshaft back today. was a pretty penny but if works out then who cares lol. slapping some quick paint on it, hopefully can get it in tomorrow then get the yokes brush painted. i stuck with the stock 1310 u joints, and the driveshaft guy suggested a slip shaft installed since it has air ride.
-_--_--_ _________
Old 12-20-2022, 07:12 PM   #911
HO455
HO455's Avatar
thanks!
Maybe this is the cause?
http://67-72chevytrucks.com/vboard/s...d.php?t=840259
Where does the needle rest at when the ignition is off?
RIP Bob Parks.
Old 12-20-2022, 08:48 PM   #912
kev2809
low n' slo
kev2809's Avatar
well, when I cycle the key on, then back off, it's sitting a little bit before the C. so it seems right. I need to fix my cooling issue I guess before dialing in the gauge. IF the torque lite is right, today it was reading about 195 and stayed there.. but the gauge was in the red. I'm having a hard time getting air out the engine.. I think.
today I got it up to temp and began squeezing the upper and lower hoses with the cap off to see if the air will purge. this time the upper hose finally started getting warm, but the lower stayed cold. the coolant inside the radiator was also cold. but the drive side tank of the radiator was really hot, passenger side was cold. it's odd.
this past weekend I put a new water pump and 187 degree thermo stat (old pump was leaking from the bearing). hopefully will have time to play with it tomorrow and try a different method of getting air out of the engine
-_--_--_ _________
Old 12-20-2022, 08:52 PM   #913
kev2809
low n' slo
kev2809's Avatar
also, does the top radiator hose have to be perfectly level? I felt like it didn't start getting warm until I pushed it back and kinda down. the passenger side of the hose was hot but the driver side wasn't... if you go back to page 36 post #888 you can see a picture of how it sits on the shroud
after I was squeezing it and pushing it down I felt like that's when the entire hose started getting warm
oh, also, I have my overflow hose just pointing down and running into nothing. should I make an overflow bottle for it to run to?
-_--_--_ _________
Old 12-23-2022, 07:16 PM   #914
kev2809
low n' slo
kev2809's Avatar
so, I drained out all the coolant. pulled the upper hose, filled the water pump til it topped off. put the hose back on. filled the radiator. ran the truck with the cap off and it tops out at about 197 and holds. truck gauge reads almost all the way hot. my issue is still the same. upper hose does get warm, but lower hoses is cold. driver side tank is warm, passenger side cold... like the t stat isnt opening to allow coolant to flow THROUGH the radiator. truck doesn't over heat at all but I feel even at 197 the stat isnt opening. the thermostat is a new 187 degree stat. this is all driveway no open road testing. but my 2002 avalanche with a 5.3 gets to just at 210 no matter if it's sitting there or driving on the highway.
-_--_--_ _________
Old 12-23-2022, 11:27 PM   #915
LockDoc
LockDoc's Avatar
If you have a meat thermometer run it with the cap off and check the antifreeze temperature when it gets up to operating temperature. If you don't think it is getting hot enough to open the thermostat put a piece of cardboard in front of the radiator.
LockDoc
Leon
Old 12-24-2022, 07:21 AM   #916
kev2809
low n' slo
kev2809's Avatar
I stuck my finger in the radiator and it's cold. that's a great idea on the cardboard idea!
-_--_--_ _________
Old 12-24-2022, 12:18 PM   #917
LockDoc
LockDoc's Avatar
See if this thread has any info you can use....
http://67-72chevytrucks.com/vboard/s...d.php?t=513897
LockDoc
Leon
Old 12-24-2022, 04:33 PM   #918
HO455
HO455's Avatar
Judging from the gauge being around the "C" mark and then reading just below HOT when the truck isn't running hot I would say there is an issue with the guage.
When you said you used a stock sender was it a stock sender for the truck as opposed to stock for the engine. The guage requires a specific sender to be accurate.
These threads may help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=587190
http://67-72chevytrucks.com/vboard/s...d.php?t=726700
RIP Bob Parks.
Old 12-24-2022, 07:15 PM   #919
kev2809
low n' slo
kev2809's Avatar
thanks I just ordered up the part number in that thread, hope it corrects the stock gauge. I tried to run the truck up to temp today with cardboard blocking the radiator... but it still didn't get passed 197. I did notice the coolant in the radiator got warm after a while, but the lower hoses never got warm at all. I'm thinking maybe I need to get it on the road and see what happens, or switch to a 160 degree thermo stat
-_--_--_ _________
Old 12-26-2022, 11:47 PM   #920
kev2809
low n' slo
kev2809's Avatar
not much done today while waiting on a few things to come in. added 2 gallons of trans fluid, will top it off when I start it up the next time. need to add some brake fluid and bleed the brakes. I pulled the rear diff cover and damn that oil was dark and ugly. letting it drain over night and will get that back put together with some new gear oil. oh, also ordered up a 2.5" exhaust pipe kit with flowmaster flowfx mufflers. going to try my hand at making an exhaust
anyone wanna take a guess at what gear ratio it is? all I know is it's a 12 bolt..
-_--_--_ _________
Old 01-08-2023, 07:19 PM   #921
kev2809
low n' slo
kev2809's Avatar
well, got a lot of stuff done lately. have all the fluids topped off and ready. had to order a trans crossmember for the exhaust to clear. got the exhaust welded up and in, although it's not how I wanted to run it. couldn't get any clearance after the TA crossmember so I had to dump them right after. waiting on the e brake rebuild stuff to come in, and need to tackle the front air bag fitting swap. pulling the PTC and putting in compression.
tried to start it up after the exhaust and it runs like crap and shuts off. I did leave the o2 sensors in while welding the exhaust, maybe I fried them? no idea what else it could be... only thing different from last start up to now is the exhaust. I was probably an inch or less away from the sensor where I welded.
-_--_--_ _________
Old 01-09-2023, 08:55 AM   #922
C130Nav
There should be a couple of 2 digit numbers stamped on the outer edge of the ring gear. 1st should be a "3X" or "4X" followed by a "1X".
Eg; a 4:10 ratio would be like "41 10"
a 3.42 ratio would be like "38 11"
C130Nav is offline   Reply With Quote
Old 01-09-2023, 11:59 AM   #923
LockDoc
LockDoc's Avatar
Check post #2 in this thread. There is a ratio chart there.
https://www.67-72chevytrucks.com/vbo...d.php?t=578793
LockDoc
Leon
Old 01-10-2023, 09:28 PM   #924
kev2809
low n' slo
kev2809's Avatar
damn, slapped the cover back on right after that picture lol. oh well.
swapped new o2 sensors and same issue. while it was running I unplugged the MAF and it ran great. plugged it back in and still ran great. idk if it's the sensor going bad, but I took the battery disconnect off. I feel like maybe the constant disconnect is messing with the computer. just throwing ideas out there, who knows
-_--_--_ _________
Old 01-11-2023, 12:45 AM   #925
LockDoc
LockDoc's Avatar
I have a disconnect on my '03 Chevy Suburban. I have to use it all the time and so far no problems with it. I suspect it has to do a re-learn each time but I haven't noticed any abnormal operation. You might try some electrical contact cleaner on the MAF connector.
LockDoc
Leon
