Old 11-13-2022, 02:16 PM   #276
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: project "C10 Fever" (68 factory black 396 swb)
Looks great
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 12-25-2022, 08:01 PM   #277
68bowtie
68bowtie's Avatar
Made my seat track connecting rod today welding up a couple 3/16" rods. Tried to duplicate the factory setup as close as possible...
Should get the seat installed tomorrow, and start installing the fenders and grille.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
68bowtie is online now   Reply With Quote
Old 12-25-2022, 08:19 PM   #278
chewychevy67
That black and red looks so sharp. Almost wants to make me paint mine that way instead of red on red. Nice work.
chewychevy67 is offline   Reply With Quote
Old 12-26-2022, 04:17 PM   #279
68bowtie
68bowtie's Avatar
I agree. GM did some great things back then.
Old 07-30-2023, 08:48 PM   #280
68bowtie
68bowtie's Avatar
This truck deserves more attention than I’ve been giving it. I just ran out of steam.
My 11-yo daughter is really wanting to drive it when she turns 16, so we decided we would work together to get it across the finish line. It’s sooo close…
Today we installed the headlamps, wipers (OEM from the board that I buffed up), and bumper brackets.
More to come soon hopefully.
Old 07-31-2023, 01:36 AM   #281
68bowtie
68bowtie's Avatar
I got the inner fenders loosely installed.
Then I remembered this problem with the lower fender mounts. I am thinking I will try and see if I can redo what I removed. If anyone has any advice, I’m all ears. It’s the same on both sides. I know the correct repair is to replace the pillars, but I am not ready for that project.
Before I disassembled the front end, it had these large concave washers installed by the PO, something like below.
Old 07-31-2023, 01:39 AM   #282
68bowtie
68bowtie's Avatar
I do have these, I could try to carefully cut through just the outer layer of sheet metal, just wide enough to bolt these in. I think that will be a better interim solution.
Old 09-01-2023, 11:44 PM   #283
68bowtie
68bowtie's Avatar
I got the fenders and grille bolted up loose today. I think the body lines will be ok for now without shimming the body and core support mounts.
Old 10-15-2023, 06:05 PM   #284
68bowtie
68bowtie's Avatar
Quick video of C10 Fever idling…
https://rumble.com/v3pj0m2-1968-factory-396-swb.html
Old 10-15-2023, 09:35 PM   #285
zicc1835
zicc1835's Avatar
sounds Bad A$$
zicc1835 is offline   Reply With Quote
Old 10-16-2023, 05:32 PM   #286
loudchevy
loudchevy's Avatar
Sounds great. I love the red interior against the black exterior.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-16-2023, 06:12 PM   #287
mkmc69
mkmc69's Avatar
Love it!! The fact that your daughter is wanting help, even better!
mkmc69 is offline   Reply With Quote
Old 10-17-2023, 01:46 AM   #288
68bowtie
68bowtie's Avatar
Thanks guys
Old 10-17-2023, 09:20 AM   #289
Ol Blue K20
Sounds good!
Dale
Old 10-17-2023, 09:30 AM   #290
SCOTI
SCOTI's Avatar
Potato potato potato.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-20-2023, 09:02 AM   #291
cornerstone
cornerstone's Avatar
Sounds like it wants to beat up a F@rD!!!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-22-2023, 11:41 PM   #292
MS66
MS66's Avatar
Sounds good. I like the SS caps. What wheels did you use?
MS66 is offline   Reply With Quote
Old 10-23-2023, 12:16 AM   #293
68bowtie
68bowtie's Avatar
Thanks. These are 15” wheel vintiques series 62, custom backspace.
Old 04-13-2024, 10:54 PM   #294
Luke87gt
Love this truck! Nice job
And awesome to see you involving your kids.
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 04-13-2024, 11:47 PM   #295
68bowtie
68bowtie's Avatar
Thanks!
Old 04-26-2024, 02:09 AM   #296
HeavyHauler
Your interior looks nice! Now I know what mine will look like since it also came from the factory in the same colors but mine did not have AC and mine will have cloth inserts in the bench seats.
Good job!
HeavyHauler is offline   Reply With Quote
Old 04-26-2024, 02:25 AM   #297
68bowtie
68bowtie's Avatar
Thanks!
Mine came with fawn interior originally but I like the red much better. I decided since I’m not going 100% factory I would make the seat match the door panels rather than the cloth inserts.
Old 04-26-2024, 09:46 AM   #298
raggedjim
raggedjim's Avatar
I'm assuming you had to lengthen the front wiring harness to run the headlight wiring inside of the front fender? Did you just splice them in or replace all wiring new? I've been thinking about doing this, it's a much cleaner look.
Nice work on your daughters truck! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 05-04-2024, 01:12 AM   #299
68bowtie
68bowtie's Avatar
New goodies…
Old 05-04-2024, 01:14 AM   #300
68bowtie
68bowtie's Avatar
Hahaha so true
Nope the harness is good as-is, other than I need to add in side marker lights
