Old 10-18-2021, 02:18 PM   #51
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 86 Suburban w/ 56k miles
These trucks look much better with the running boards removed. mine are gone too and love it.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-22-2021, 01:20 PM   #52
wazzabie
What is the story with these Chevrolet key fobs? I've seen another one with a 1985. Does GM match the original owner to the number on the key fob? Was this a dealer option? Is there any way to update GM records?
wazzabie is offline   Reply With Quote
Old 10-24-2021, 07:59 AM   #53
Corts60
Just here to tinker
Corts60's Avatar
I’m not sure. My guess is this was the later version of the protect-o-plate cards.
Old 10-31-2021, 10:47 AM   #54
Corts60
Just here to tinker
Corts60's Avatar
I was scrubbing the tank, prepping it for POR15 and found another build number. 83. It’s written everywhere: under dash, on firewall, on rad support, on frame. Pretty sweet that it is all still legible.
Got the new sender installed, going to paint the top of the tank with POR 15 and repair the few surfaces on the frame where the anti-squeak padding was holding moisture and causing rust. The rest of the frame in that area is still factory black and shiny which is awesome.
Next will be all new fuel hoses, gluing on the new anti-squeak pads and then getting the tank back in.
Old 12-01-2021, 10:04 PM   #55
Corts60
Just here to tinker
Corts60's Avatar
Well I got the fuel tank and all new hoses installed. Hooked up the new sender and…nothing. It still doesn’t work. Kinda made me mad a little bit. But, oh well we’ll continue troubleshooting. I thought maybe the gauge went south on me so I figured I’d get a new one. But then while I was looking up a new gauge, I started eyeballing the aftermarket tach kits and thought, yep, I’ll add that since I’m in the dash anyways.
So I got that installed tonight and works wonderful. I’m very impressed with the quality of the LMC tach kit. It’s probably the best aftermarket/reproduction part I’ve ever seen. It’s nice to see some high quality parts coming back on the market.
Now I have to focus again and solve this dang fuel gauge problem. I’m almost certain I have a break in the wire somewhere….
Old 12-02-2021, 12:31 AM   #56
evan
evan's Avatar
Nice. I've been looking at that tach conversion kit but they don't have the style to match my speedo in stock. I'll keep an eye out for it though. That looks great.
Evan B.
evan is offline   Reply With Quote
Old 12-05-2021, 02:15 PM   #57
Corts60
Just here to tinker
Corts60's Avatar
Thanks!
Old 12-05-2021, 02:19 PM   #58
Corts60
Just here to tinker
Corts60's Avatar
So here's what it was like to install the aftermarket tach kit; again, really impressed with it:
I took out the original cluster and swapped the original gauges, bulbs, and little indicator light covers to the new cluster.
The first pic the gauges are still in the original cluster. I took some photos of the stickers that were on the original cluster. I also took a photo to show the black finish on the aftermarket fuel gauge is just slightly more flat than the originals. But when it's all installed, you can't tell.
Old 12-05-2021, 02:29 PM   #59
Corts60
Just here to tinker
Corts60's Avatar
After the new cluster assembly was together, then I had to run the tach wire to the distributor. This required drilling a hole in the fire wall (cringe), but the grommet they supplied and the location I chose, I think it looks pretty factory.
I realized when I went to hook up to the tach signal, that the spot was already occupied? Turns out, my dealer installed Chapman security system not only locks the hood from being opened, but used the tach signal port on the distributor to kill the ignition. So, even if you pry'd the hood open, you wouldn't be able to tell why the truck wouldn't start because it all looks factory and everything is hooked up. Pretty cool system. I took some pics of what it looks like.
Old 12-05-2021, 02:31 PM   #60
Corts60
Just here to tinker
Corts60's Avatar
But in the end, the install was very easy and straightforward, the parts are quality, and the kit has everything you need. Even the power supply to the tach has the factory style plug.
Old 12-05-2021, 02:39 PM   #61
Corts60
Just here to tinker
Corts60's Avatar
Now that the tach distraction is over, I got back to troubleshooting the fuel tank problem. I've verified every wire, connection, and gauge function. Therefore, I think I bought a bum sender. I know the sender itself works electrically, because I tested it before installing it. So the float must've had a leak and filled with fuel. Can't be anything else. But I've already put a half tank of fuel in it and I'm just not in the mood to drain it and drop the tank again. So this is getting put on the back burner.
Honestly, I'm really considering fuel injection and putting in a TBI fuel sender/pump assembly in the tank when I drop it next time. We'll see!
Old 12-10-2021, 01:49 AM   #62
LT7A
That tach conversion is really clean. I'd like to do it, but I think I'm just going to go with the aftermarket column mounted / fold away tachometer option.
Old 04-10-2022, 01:43 PM   #63
Corts60
Just here to tinker
Corts60's Avatar
Finally we have a nice day in western Michigan!
Old 04-10-2022, 01:45 PM   #64
Corts60
Just here to tinker
Corts60's Avatar
This week I replaced the rusty original 2 1/4” tailpipe with a new 3” factory style like my ‘88 has.
Old 04-21-2022, 08:39 PM   #65
elimontfort
elimontfort's Avatar
Hey there sir I was wondering what type of remote lock unit you are using?
Well, I did a couple "Fancy" additions this weekend.
10 years ago I would've never thought about adding modern conveniences to my classic trucks because I am such a purist. But, as I get older, some conveniences are very nice to have.
So I put in a remote lock unit that ties in with the factory lock system. So now I can remote lock/unlock like a modern car and it also blinks the running lights.
I also put in a back up camera. After 20 years of hooking up trailers the hard way, I figured it was time to make my life a little easier. And this is a remote camera set-up, so I didn't have to butcher up wiring or drill any holes. It's not bad for $80.
elimontfort is offline   Reply With Quote
Old 04-22-2022, 06:19 AM   #66
Corts60
Just here to tinker
Corts60's Avatar
I bought a FicBox unit from Amazon. It’s like $15 or so. Been very reliable and the range is decent.
Old 06-30-2022, 03:09 PM   #67
Hart_Rod
Hart_Rod's Avatar
I've had one those kits in a box for about two years but still haven't installed it yet in my 87....:-(. Yours looks great and is kinda motivating me to get it done! Any lessons learned or suggestions to make the install go better? Thanks!
Rob
Hart_Rod is offline   Reply With Quote
Old 07-03-2022, 03:17 PM   #68
Corts60
Just here to tinker
Corts60's Avatar
Rob
Hi Rob,
It was pretty straight forward. I didn’t connect horn, so that makes it easier. I do remember having to remove the lower drivers kick panel, but I don’t remember to much other fuss.
Old 12-30-2022, 05:26 PM   #69
Corts60
Just here to tinker
Corts60's Avatar
Well I have some updates!
I’ve decided to install a modest drop, like 2/4 or so, and I’ve got new wheels!
These are 275/55R17 tires and Vision 17” wheels. I was going for a modern twist on a retro style and I’m pretty happy with it.
I had custom stickers made to add to the center caps. Lowering kit will be here next month and I’ll post more when I start that process!
Old 12-30-2022, 05:33 PM   #70
The wheel and tire combo looks good. Glad you kept some sidewalls on the tires. Looks so much better than the rubber band look.
Old 12-30-2022, 06:22 PM   #71
Corts60
Just here to tinker
Corts60's Avatar
Thanks Bill! Yes, having sidewalls was important to me. My goal was to recreate the classic 275/60/15 look on a 17” wheel. I really wish they made a white letter 17” tire.
I went with this size also because it is almost the exact same height as the 255/70/15 so I don’t need to change speedo gears or anything.
Old 01-03-2023, 02:07 PM   #72
65chevysub
65chevysub's Avatar
Finished waxing the roof and the passenger side...holy smokes. That's a lot of sheet metal!
When I had my 65 Suburban, I would say it's like waxing a barn, lol
65chevysub is offline   Reply With Quote
Old 01-03-2023, 02:08 PM   #73
65chevysub
65chevysub's Avatar
Originally Posted by TwoFiftyShifter View Post
My opinion - please remove! I bought an 87 with the same running boards. Once I pulled them off, I had a big smile on.
I'm putting boards on my 84 Sierra long bed. I like the look, but most importantly for my wife to get in and out easier, especially after her knee revision in the next few weeks.
Old 01-04-2023, 01:47 PM   #74
Corts60
Just here to tinker
Corts60's Avatar
Yep, sometimes function wins over form!
Old 01-04-2023, 01:48 PM   #75
Corts60
Just here to tinker
Corts60's Avatar
I got the black/gold center cap stickers today. I think this is a much better combo.
