Undercoating
I'm almost to the point of putting some kind of undercoating on the underside of my 61 cab and using the same thing on my inner fenders. I'm thinking about a lite coat of raptor liner. I've never used it before but seems like a good option. My truck is going to be more of a nicer weekend nice weather driver but occasionally go slowly down a gravel road. I'm looking for something that will prevent rock chips and hopefully knock down some noise and heat transfer. If anyone has any experience with raptor liner or have any other products I'd like to hear about them. Pictures would be nice too. Thanks
![]() ![]() Join Date: May 2015
Re: Undercoating
I've sprayed several different brands of coatings over the yrs
The underside of my cab and bed and inside the cab got lizardskin I used it based on the sound deadener quality it has It sprays easily and coats good, it cleans easily with water,smell isnt to bad Under my fenders I used raptorliner I used it mainly cause I just wanted to give it a try It sprays easily, and coats good But be warned.. the smell is bad Cleanup is not easy, you need acetone or lacquer thinner Between these 2 the lizardskin has a more rubbery feel to it, the raptorliner has a hard feel to it How well they hold up has yet to be seen by me But either one is messy..make sure you have everything you dont want it on covered up..the overspray goes everywhere
Re: Undercoating
A buddy of mine has a body shop and sprays Raptor all the time. Like anything prep is key.
On my hot rod projects I've just used spray bomb under coating. It goes on a bit smoother than Raptor. If you are so inclined I believe you can tint Raptor to some what match your paint color. My hot rods will never see snow or even a gravel road so the spray bomb has worked well for me. When I spray the under coating I put down a big piece of sheet plastic to catch the over spray. |
Re: Undercoating
I was talking to a guy tonight I've known for several years and was telling me he reduced down some raptor liner and got a finish similar to what some European cars have on their rocker panels. I don't want too rough of a finish, just a lite finish. I think I'm going with the raptor liner. I've got my truck and two others to spray in the future.... Thanks for the replies.
Re: Undercoating
I have thinned and sprayed Raptor with extra paint and reducer makes a nice matte finish, this is the tinted version. Raptor calls for 10% urethane paint, I have added as much as 50% paint and reducer, mix really well. 1.8 tip in a hvlp spray gun, still spits a little as it sprays but it lays down nice. On the top of dash, directly over epoxy, dash pad over adhesion promoter.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 01-07-2023 at 07:44 AM. Reason: Photos |
Re: Undercoating
I've sold Raptor Liner and other DIY bedliners wholesale to body shop jobber stores (for nearly 20 years) and can tell you that you're considering the wrong product for the job.
Bedliners like Raptor and others are nothing more than sprayable thick urethane. Ron Morton, who owned Dominion Sureseal, invented Gator Guard that used epoxies in the late 90's but found they chalked with age so he messed around with urethane to the point that he got it to "work" as a sprayable bedliner. Hard, textured finish and a successful marketing program made it a success as a DIY bedliner but it was never designed or meant to be used as "undercoating". Undercoating is a bitumen based product that never hardens completely and because it doesn't, it absorbs sound and flying road debris far better than any "bedliner" ever will! Stick with a product called "undercoating" for undercoating and leave the bedliners to the beds...as they were designed for. Keep it simple... it doesn't have to be anything else.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
#7 | |
Re: Undercoating
![]() Join Date: Sep 2002
Re: Undercoating
According to Lizard Skin, it can be used as an undercoating.
Re: Undercoating
I've used Raptor under 3-4 trucks and have always been happy with the results. As far as the comments on sound deadening, that happens on the inside of the sheetmetal, protecting from rust and road rash happens on the outside.
Plus, undercoating just plain looks like hammered dog poo. |
Re: Undercoating
I ordered some tintable raptor liner. I'm still going to use some sound deadening on the inside. Maybe lizard skin and something else under the carpet. I know it will never be as quiet as my new truck or car but it should be fine as it probably won't get driven as much.
Its a Truck Thing......
Re: Undercoating
I use Raptor and I like it.
Make sure you check out the U-POL website for hints and ideas. They have some good "How To" videos. Prep is key, distance from the gun to panel is key, pressure to the gun, what gun....I used the last gun with the kit and had to mod it a little on the plastic trigger. It laid down a nice texture. The product goes quick so keep that in mind if you use their gun. It takes about a week for the smell to flash off, at least that's about what it does for me. Oh, make sure you have a good respirator.....Not a mask.... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
