Old 06-12-2002, 04:18 PM   #1
DREW67
DREW67's Avatar
Assembly of stepside bed
CAN ANYONE TELL ME HOW TO ASSEMBLE A STEPSIDE BED FROM SCRATCH.
THANKS
DREW67
DREW67 is offline   Reply With Quote
Old 06-13-2002, 09:31 AM   #2
Erl
Erl's Avatar
I have been looking for the same information with no luck. I have a 68 GMC stepside with the original wood in the bed. I have another disassembled stepside bed that we are going to reassemble for another truck. I plan to use the GMC as a model. If you are not in a big hurry, I could send you some pictures when we start. If you do find any other information I would like to see it.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 06-13-2002, 09:45 AM   #3
johnnyp
Keepin' It Stock
johnnyp's Avatar
Get the Assembly Manual - you won't be sorry. Costs about $35 but it's money well spent IMO.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 06-13-2002, 10:06 AM   #4
Erl
Erl's Avatar
John,
I have the Assembly Manual and find it of limited use. Never enough detail. If you go to the section on the stepside bed, there is no detailed information, just overall pictures. I would like some good exploded views with part numbers.
Dallas TX
Old 06-13-2002, 11:20 AM   #5
johnnyp
Keepin' It Stock
johnnyp's Avatar
Yea, I've found too that some sections aren't as good as we'd want. I couldn't look in mine to see what the section on stepsides looked like because it's on loan to a friend.
Old 06-13-2002, 11:32 AM   #6
Mudder
Mudder's Avatar
well
Its pretty easy actually. if ya build it on the frame you should maybe put some 2x4's across the truck frame to hold it. bolt the sides to tthe front then the rear cross sill.(not sure if thats what its called) add all the other cross sills. should be able to look on your frame to see where the ones go that hold the bed down. you have to raise the bed up then a bit to put your boards in. outside 2 pieces first then just fillem in. fenders and then steps. when bolting togethter the sides and fron panles try to keep them as square as u can. stainless bolts are very nice. have fun, I did mine all by myself w/ noone to ask. ps good idea to leave bolts loose until u get it all togethter then go back and tighten everything.
Mudder is offline   Reply With Quote
Old 06-13-2002, 11:33 AM   #7
johnnyp
Keepin' It Stock
johnnyp's Avatar
Drew, I was just looking in my LMC catatog and it as some good exploded pictures of the stepside. Shows all the bolt attachment points for the end panel, step, tailgate, bedsides, and fenders. Maybe they will help. Also GMCPaul's site has a good FAQ sheet on wood installation.
Old 06-13-2002, 01:36 PM   #8
DREW67
DREW67's Avatar
Thanks guys you have been a lot of help. Erl when you get some pictures forward them on or post them of on the board. Again Thanks
DREW67
