01-26-2023, 04:55 PM | #1 |
Jack Instructions, Stow Away
After having installed these, today marks the first I have nothing left to install in my rebuild, Pending stuff. The seat cover has been on order 6-7 months under a covid economy.
Apparently I get my $1100 OER radiator tomorrow though. Yeah, $1100 for what I hope is solid, from USA Radiator. The last two are junk and came from different manufacturers. Anyone able to find this decal? I found a "replacement" decal, but that's not it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-27-2023 at 01:48 AM. Reason: Revised due to new information |
01-26-2023, 07:20 PM | #2 | |
The Older Generation
Re: Jack Instructions, Stow Away
I have never seen a jack like that in a '67-'72 C10, 20, or 30. I wonder if it could be a decal from a C40, 50, or 60 I don't know if they even had a jack. The 5th picture is how the tool bag spring should be mounted. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-26-2023 at 07:28 PM. |
01-26-2023, 07:30 PM | #3 |
My ‘67 GMC has a jack like that….
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
01-26-2023, 07:31 PM | #4 |
Does your truck have a decal like his first picture? LockDoc
01-26-2023, 09:12 PM | #5 |
1. your decal shows a 4 headlight GMC, and the jack certainly looks odd. Mine is the common one that's available as a reproduction.
2. your lower floor spring latch is mounted backwards, compared to mine in a 72 C/10 3. your upper spring latch is identical to mine, with proper placement. this all suggests, if you have a Chevy, the manufacture put the incorrect lable, or your cab was replaced, maybe? |
01-26-2023, 10:19 PM | #6 | ||
Come to think of it, the jack I pulled from the truck seems to match the decal I was informed it was the wrong jack. Hmm. Both replaced or factory?, hmm. Quote:
Cab wasn't replaced but interesting that decal and jack is for a GMC. Might the difference be my 71 SWB 2WD was ordered with leaf springs, which came stock on GMC? But then, why would the jack be different for leaf springs? For what worth here's the jack I removed from the truck, which matches the decal instructions. Not saying it's original, but I learned long ago what must be doesn't always apply. Other than that, I can't find those instructions anywhere.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-26-2023 at 11:37 PM. |
01-26-2023, 11:45 PM | #7 | |
Yes! that is one unusual looking jack, IMO. and it looks taller than what is typically OEM. Do you have a 4x4 perhaps? I had a 72 GMC 4x4 but that was in the 80's and cannot recall what it had.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
01-26-2023, 11:56 PM | #8 |
Nope, 71 Chevy 2WD SWB with leaf springs. Until you guys chimed in, I hadn't noticed the jack matches the decal. At the moment I can't find either anywhere. Interested to know if jabborabbo has a decal to match his jack.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-27-2023, 01:14 AM | #9 |
I don't think you are going to find that jack decal anywhere unless you stumble on to an original one left over from a dealership or something. I reproduced the '67 only, Chevy jack instructions decal but it is different that that one. LockDoc
01-27-2023, 01:36 AM | #10 | |
Agree. At this point I'm just trying to verify it's original to the truck. Seems it would be considering the matching decal, but the cab floor may imply it takes the more common jack, and the decal shows the jack stored in what appears as the wrong direction I may just use a standard bottle neck.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-27-2023 at 02:23 AM. |
01-27-2023, 08:38 AM | #11 |
I haven’t seen a jack decal of any kind…
01-27-2023, 12:15 PM | #12 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 01-27-2023 at 12:21 PM. |
01-27-2023, 12:20 PM | #13 |
There is a company local to Oregon (https://www.fillingstation.com/) that sells a lot of decals on their site - including the jack instruction ones - that might be a source for you. Good folks there.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-27-2023, 02:26 PM | #14 |
hi guys, is the jack bag reproduced? thanks brown 70
01-27-2023, 03:27 PM | #15 |
There was a guy on here making them but I don't know what his status is at this time. I can't remember his board name. LockDoc
01-27-2023, 07:23 PM | #16 |
Here's a link to the bags LockDoc referred to. However, that thread says it's closed. Not sure why.
https://67-72chevytrucks.com/vboard/...d.php?t=715455
Jim |
01-28-2023, 10:34 AM | #17 |
thanks for the info guys, brown 70
