Old 02-08-2023, 07:23 AM   #1
Getter-Done
Getter-Done's Avatar
208 Transfer Case Rebuilt Kit/ Bearing,Chain&Gaskets
Where is the best place to buy parts for my 208-transfer case?
I will be putting new seals and gaskets for sure.
Probably a chain.
I will tear it down first then order parts.
So, bearings will probably get replaced also.
I just bought one for spare parts.
So I have Extra Stuff
84 Chevy K-20
Old 02-08-2023, 11:07 PM   #2
JJH Jimmy
JJH Jimmy's Avatar
Re: 208 Transfer Case Rebuilt Kit/ Bearing,Chain&Gaskets
I got the rebuild kit for mine from torque king.
https://torqueking.com/search-result...roducts&page=3
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 02-08-2023, 11:14 PM   #3
Getter-Done
Thank You
I will check them out.
I will tear it down and get a List.
84 Chevy K-20
Old 02-09-2023, 04:00 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
I bought a kit from EBay about 4-5 years ago for my 205. It had all the consumables in it and was about $100.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 02-09-2023, 04:07 PM   #5
Getter-Done
I did not think about e-bay.
I will search it also.
84 Chevy K-20
Old 02-18-2023, 08:46 AM   #6
Getter-Done
Just to update.
After several days of research.
From multiple places.
I went with Torque King.
Staff was very helpful, and the price was competitive.
Shipping was free another key point I went with them.
Although as an option
They include {Shipping Assurance}
You have the option to delete it.
This sounds like a Good General Discussion Thread.
I am making a fixture plate on a rolling table to build the Transfer Case.
That way I don't have to roll around and wrestle with it
Thanks for the input JJH Jimmy and 57taskforce
84 Chevy K-20
Old 02-18-2023, 07:41 PM   #7
JJH Jimmy
JJH Jimmy's Avatar
I just drilled a hole in an old 4x6 I had laying around and a scissor jack on the other other side to hold it while I worked on it. It worked good.
1985 Chevy K20
1994 GMC Yukon
Old 02-18-2023, 10:01 PM   #8
Getter-Done
That will work
I welded up a fixture to use on a floor jack years ago,
To put a transfer case in cause of a no helper issue.
Sometimes I have spare time at work,
While my machine has long run times
You heard the old saying (Idle Hands)
So, this is where that began.
Access to a milling machine behind the Big machine I run.
And a scrap plate of aluminum.
And then This.
Name:  208 plate.jpg
I will probably finish it up tomorrow.
It's supposed to get up to 60 degrees.
I will use threaded rod and spacers for the holding/leveling.
My parts are scheduled to be here Tuesday.
I hope to show my Nephew this process.
That is part of the reason for the extra effort.
84 Chevy K-20
