Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-31-2017, 08:37 PM   #1
Jcfcamaro
Jcfcamaro's Avatar
Body filler help
Hey Guys, I could really use some help on buying the right/best body filler . I've been fixing rust on my cab and also replaced the rockers and cab corners. This is my first time doing body work so I'm kinda learning as I go . I'm planning on buying some dura blocks also. Any info would be great.
Jcfcamaro is offline   Reply With Quote
Old 12-31-2017, 09:21 PM   #2
suville
suville's Avatar
Re: Body filler help
I really like rage Ultra, check out Autobody toolmart. Also very happy with Kirker primers
suville is offline   Reply With Quote
Old 12-31-2017, 10:57 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
I'll read up on that. I think that's the same stuff a body guy used on my 67 camaro.
Old 12-31-2017, 11:25 PM   #4
mongocanfly
mongocanfly's Avatar
I'm using 3m professional gold filler on my truck....happy with the results....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-31-2017, 11:28 PM   #5
Jcfcamaro
Jcfcamaro's Avatar
Is it better to put one thick coat on or multiple coats.
Old 01-01-2018, 12:03 AM   #6
mongocanfly
I'm no body man by a long shot..minimal is better than multiple ...it usually takes me several coats to get where I want...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-01-2018, 12:55 PM   #7
MARTINSR
MARTINSR's Avatar
Print this out and set it by your favorite relaxing place and read it a few times.
"Basics of Basics" Body filler
By Brian Martin
What ever tools you use the trick is to not add the last "skim coat' till you KNOW that it is all you need. Don't try to block out that first coat, just use it as a base for the LAST skim coat.
I was taught this procedure after doing bodywork for a number of years and it really works well:
Just apply a nice coat of filler (what ever brand, whatever style, we will put that aside right now). Cut that coat NOT to make it perfect, but to get the basic shape and filling you need as a base for the skim coat. You can cut it with 36 40 or 80 depending on how big the area you are working is. In other words, if you can cut it fast with only 80 then do it. But I would say that this would be limited to an application that is no larger than about 8 inches.
If you happen to have a few high spots, see if you can tap them down.
If you have a few low spots add a bit more filler to ONLY those spots.
Re-cut these last low spots you have just filled with the same grit you have been using (most likely 36).
If you now have a surface that ONE skim coat will fill, then apply it. If you don't work with it a bit more, but NEVER add a little here or there and think you will finish it without a skim coat.
If you have a surface that is very close with only a few VERY MINOR low spots like poor feathering onto the metal, poor transitions from one application of filler to another, or from the metal that is "poking" up here and there you can do the LAST skim coat.
This skim coat is very important, you want it to extend over the COMPLETE area, this is well past the damage you have been working. Maybe as much as 3 inches past the plastic that you have applied to "rough" it out.
This skim coat can be regular filler or a polyester glaze like "Icing" or "Polyester glazing putty", that is your choice, I use both depending on the size of the area being worked. Do not use anything that doesn’t mix with a hardener. NO, “Spot putty” in a tube, only polyester putties or fillers. If it uses a hardener, it cures to a hard film. The “spot putties” stay soft and can become even softer when the solvent from the primer coats it.
You now run a block, long board, or hog even over this skim coat with a little bit coarser paper than you plan on finishing with to cut off the resin that has surfaced in the filler. I usually just use the 36 or 40 or whatever I have been on the "rough" work. BUT take CAUTION not to cut much off, you want to JUST take the very top, don't really sand AT ALL.
Now finish sanding with your longboard or block or hog or whatever using the finer paper like 80 on a large area or 120 on that small 8" sized area. Block it out to perfection with a nice feather edge to the surrounding metal.
I can't stress enough, the trick is to know when just ONE LAST skim coat will do the job. And apply it COMPLETELY over the surface. If you only one little low spot in the middle, DON'T just do it, skim the ENTIRE thing. You HAVE to have one LAST skim coat over the ENTIRE thing every time. If you get in the habit of this you will do it over and over on every dent you repair and find that you can do just about any dent with just two applications.
As you sand the filler let the board or block you are using run over the surrounding metal. If you only work on the filler you will sand it too low. You need to keep it as high as the surrounding metal, so use the metal as sort of a straight edge that you run the block or board off of.
Don’t worry if you cut through this skim coat here and there. In fact, you WILL most likely cut through. The point of that "LAST SKIM COAT" is that after you add it, you don't add ANY MORE filler. That "LAST SKIM COAT" is just that the LAST filler you add. If you hit a little filler below, or metal, that is normal and fine. The only thing you are looking for at that point is if the panel is FLAT. The filler skim coat is serving no other purpose than to finish you filler work, it is not a "sealer" or anything like that.
You can add fiberglass resin (“A” coat if you have a choice) adding the resin was exactly how I learned from the great Emery Robinson (my personal hero in the auto body world). But remember there was no products like polyester putties back then. When you add resin, that resin comes to the top of the film of filler. It is then something you have to deal with. The whole purpose of the SKIM COAT is to put a layer of filler over the top that is easy to block out with as little effort as possible. You want to be able to concentrate on making the panel FLAT not fighting with gummy resin, sand scratches and the like.
So the polyester putty though expensive is what I use.
How is this for an idea, a co-worker of mine showed me this very obvious tip.
Add pour-able polyester putty to the regular filler! What an idea! LOL A little pour-able squirted into the "bondo" really thins it out nicely.
The "LAST SKIM COAT" should be left to cure a good long time. Where you may jump on filler and sand it as soon as it is hard, the skim coat should be GOOD AND CURED for an hour or more. If you can of course, in the production shop you may not be able to wait that long. The benefits of the procedure will not be diminished.
A little added note, I have found that I don’t use 36 or 40 grit at all anymore. I went to work at a shop that didn’t use the coarser grits so I had to learn not to also. I have found that using just the 80 and then finishing the Skim coat in 120 or 180 works great, even on large panels.
At this shop it was the first time that I wasn’t doing my own primer work. This meant that I couldn’t “cheat” with a lot of primer and blocking the body work “one more time”. I found that I had to get the work PERFECT, then give it to the painter. I did this in an interesting way, I look at the last skim coat as even a more “final” step. I now look it as “primer”. You see I have used polyester primer, which is like spraying “bondo”. They are both polyester resin based and act and sand very much the same. So, I figured why not just “spread out my primer” as the skim coat! It has worked GREAT, the painter jokingly says, “do you think I’ll need to prime this or just paint it?” I tell him, “Just clear it, it’s a shame to hide that work under primer”.
This method has worked great for me, it’s more of a state of mind than a procedure.
And don’t be afraid to buy the best sand paper and use a lot of it, the cost of the paper will be nothing next to the time and muscles saved. Find the paint store in town that services the PROS the Body shops in town, that is were you will get the right stuff and the right info.
Additional Info.
Plastic filler refresher.
I thought that a little refresher on the basics of plastic filler was due.
Yesterday I did two small plastic filler jobs that I thought I would share with you. The procedure I lay out in the “Basics of Basics” for plastic filler is pretty clear, I just thought that a couple of real life repairs might be of help. I also wanted to walk through a repair when things didn’t go perfect. How you get out of trouble is almost as important (some will argue more important) than keeping out of trouble to begin with. The first repair was a small 18x12 inch dent in a door of a Hyundai. I don’t think I have to tell you, the metal is very thin on this car which poses unique problems. I have pretty good access from behind with the trim panel removed to push it out. It did need some shrinking (I used my stud welder with a shrinking tip). The metal was pretty close and I figured one filler coat with “regular” filler and a skim coat with polyester putty should be about it. I applied the “regular” filler (in this case Evercoats Rage Gold). I roughed it into shape using my 8” orbital sander with 80 grit. The panel was ready for my skim coat when I realized it had a problem spot. There was a 5” round area that was flexing. This is a common problem with stretched metal. It was straight (or close to it) when “relaxed” but when pressure was applied while sanding it would flex down. So, the pressure flexed it down and sanded it “flat” WHILE it was flexed. The panel then came up to it’s relaxed state and the filler that is on the area would then be high! This is a common problem with beginners, they don’t notice the panel is flexing and block and block and wonder why the panel is not flat.
I had to shrink it in that area so I sanded off the filler in just the effected area and shrank it with the stud gun until the metal was firm. I knew it was not close enough for my skim coat so I applied a thin coat of Rage, just on that one 5” round spot. The rest of the filler stayed as it was, sanded with 80 grit. When I sanded the spot I found that I had not put enough filler on it. There were a few “shiny craters” showing low areas. Now, it was pretty close and a skim coat “may” have taken care of it. But I don’t like “may haves” I like to KNOW when I apply the skim coat THAT is it. I went ahead and applied one more coat of Rage. I sanded it and it was done. NOW at that point I KNEW it was ready for the skim coat. I applied it and it was then sanded to perfection. If I had applied that skim coat too soon and found low spots not filled, I would have had to COMPLETELY skim coat it again, as shown in the next job. It was a mistake, I should have had the metal ready for filler and it would have been done earlier. But such is life. The other repair was on a quarter panel of a 2002 Ford Focus. It was a crease requiring filler in an area about 22x16 inches. As in the “Basics of Basics” you need to give the dent the respect it deserves. The actual damage before the repair was only about 18x6 inches. The paint was stripped out to about 24x18 inches, you need to be sure you are feathering out the filler unto undamaged metal. After pulling the dent (with an Eagle II electric dent puller, neat tool) I applied the filler coat with “regular” filler. I shaped it out rough with 80 grit just getting the body line that ran thru it close. No super detail, I only wanted the line to “be there” and would fine tune it with the skim coat. After applying my skim coat of polyester putty (Evercoat's “Glaze coat”) I blocked it out. I had two areas that were close, but not good enough. One was a tad low, the other had a high spot of metal from the puller poking up. I couldn’t get the high spot to go down with gentle tapping with the body hammer. If I could have done so, and gotten behind the low spot to tap it out I could have saved it. But that was not in the cards. I went ahead and tapped it down with a punch and hammer (to isolate the force) and skim coated the whole thing again. These areas were just four or six square inches in size but I know that feathering a little polyester putty into the surrounding very thin putty would likely be very difficult at best. I skimmed the entire panel. That’s right, the whole thing again. It is a “shell” of polyester putty. Very easy to block, no feather into existing filler. It is just like a primer over the area and much easier to work with. Even though it is more sanding, it is much easier. Again, a mistake necessitated the 2nd skim coat. But mistakes happen and if I would have tried to repair it without another FULL skim coat, it is likely I would have spent even more time to fix it.
Cut your losses and skim it again, but don’t plan on anything less than a skim coat to finish the job.
I want to say there are times when a tiny amount of polyester putty could be applied to pin holes or other VERY tiny imperfections without skim coating the whole thing. But these should be VERY little imperfections.
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-01-2018, 01:59 PM   #8
Jcfcamaro
Jcfcamaro's Avatar
MartinSr, What would your pick be for a brand of filler be for a first timer.
Old 01-01-2018, 02:43 PM   #9
MARTINSR
MARTINSR's Avatar
Evercoat's Rage gold or ultra. Or 3M Platinum. The better fillers make life easier, for the newbe or the experienced tech.
They sand easier, stick better, they are simply better and worth the money to get that easier to work with product.
Brian
1948 Chevy pickup
Old 01-01-2018, 04:24 PM   #10
Jcfcamaro
Jcfcamaro's Avatar
Thank you guys for the help. I've built a lot of cool stuff over the last 20 yrs and have always done all the work except the body and paint. All the shows and places I've been where people look at my toys always ask if I painted it and I have to say no then they want to know who did the paint. This 72 Cheyenne K10 I'm building will be one that I will be able to say ( I did it all ). I know I have a long road ahead of me but I usually succeed in everything I do because I'm a neat freak Lol.
Old 01-01-2018, 04:50 PM   #11
CC69Rat
CC69Rat's Avatar
I agree with what the others have said already. I really like the Evercoat products too. Rage Gold / Extreme / Ultra, etc. I like the Quantum 1 too.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-01-2018, 06:06 PM   #12
MARTINSR
MARTINSR's Avatar
If Evercoat made TVs I would buy one, that company is as good as it gets.
Brian
1948 Chevy pickup
Old 01-02-2018, 11:15 AM   #13
e015475
e015475's Avatar
Another vote for Evercoat's products. But using filler is more about technique than the product you use.
I'm still an amateur but I've read Martinsr's article a few times and always get something new out of it. Using filler incorrectly isn't hard -there's lots of hacks doing it. Using it correctly take some significant skill and practice.
Just did four fenders, a hood and running boards after metal work and here's a few 'lessons learned' (all stated at one point or another in the article above)
- Keep your sandpaper sharp. I use 80 grit on a durablock and check it often with my thumb to make sure the abrasive is still sharp. 80 grit or below is used to get to the panel contour. 180 is only to remove sand scratches prior to primer. Don't be cheap - change paper often
- Most beginners under-fill then over sand. Always keep the maximum contact area area of the board on the panel using a cris-cross pattern
- If you're straightening out panel irregularities, coat the whole panel with filler. The 'make a shell of filler' concept in the article is what I go for.
- The trick to avoiding pin-holes is to keep from overworking the filler as you put it on. I empty the mixing board onto the panel then start covering every square inch with filler. The final step is smoothing with the plastic spatula to get as uniform a 'shell' as possible.
- Ideally, this is the only time you should be using filler as you would have done all your metal work such that you only need a very thin coat to smooth the surface out. Reconcile yourself to the fact that 95% of the filler ends up on the floor as dust and there should be very little left on the panel.
- There's really no such thing as a 'spot repair' with filler. If you block it down and you've hit metal somewhere and you still have low spots, skim coat the entire panel again and block it. Small irregularities and pin holes can be filled with a little filler using a single edge razor blade as a applicator.
-Use guide coat liberally. I buy the $1 cans of flat black spray paint at HD and I buy 5 or six at a time.
-For large panels, you may have to apply the filler in sections. The area where the filler coats meet is where I have the most difficulty getting the panel to be straight, especially in higher crown areas. I let the first area cure until I can feather the edge before I overlap the next coat.
- Read Martinsr's article on how to feel a panel with your hands. Guide coat will get you close, but for the final tweaks, you need to be able to feel the panel irregularities to correct them. For panels with crowns that are not too high, I cheat a little and take and aluminum yardstick, turn it on edge and flex it with my thumbs to conform to the crown as I rub it on the panel. Usually there's enough aluminum oxide on the edge to leave a witness mark for the high spots (or you can coat the edge with a Sharpie and it will transfer) I knock down the high spots with 80 grit on a durablock and repeat the process till the witness mark is pretty much continuous (be sure you get any Sharpie residue off the surface before you prime - it will bleed)
- I consider myself very lucky if I can coat a panel just once with filler and get it flat or to contour. Usually it takes two coats, and sometimes three to get it right. It is a time consuming process and you need to reconcile yourself to keep repeating it until your panel is very straight. Evercoat's filler "Honey" can be used to thin the last coats for a more uniform and thin 'shell' - another excellent product.
- Try Evercoat's Featherfill as the final filler before you prime for your topcoat. Another excellent product from those folks.
Thanks for the excellent article Martinsr and I hope some of these amplifications will help somebody
e015475 is offline   Reply With Quote
Old 01-02-2018, 12:02 PM   #14
e015475
e015475's Avatar
Here's a link to the article on feeling panels for imperfections. The basic tenet is that you can't rely on methodical blocking and guide coat alone to achieve a flat panel - it has to feel correct to be correct.
http://autobodystore.com/forum/showt...ywork&=feeling
After feeling the panel, I'll mark where I think the irregularity is with a pencil then go back and sand with a block using 80 grit to contour (I always use a fresh piece of sandpaper when I get to this step- dull paper can introduce waviness and actually make it worse ) I keep repeating until the defect levels out and it usually takes a few iterations of chasing the imperfection with the block before you can't detect it anymore with your hand. I follow this with a dusting of guide coat and lightly block the entire panel to blend everything together. Then another dusting with guide coat and block with a light touch with 180 until the scratches are gone and you're ready for primer or Featherfill.
Old 01-02-2018, 01:03 PM   #15
Jcfcamaro
Jcfcamaro's Avatar
Thanks for the info! I'll read up.
Old 01-02-2018, 01:11 PM   #16
MARTINSR
MARTINSR's Avatar
Thanks for the kind words. Seeing people pull this stuff off themselves is why I love sharing my info.
Brian
1948 Chevy pickup
Old 01-02-2018, 01:56 PM   #17
e015475
e015475's Avatar
I wish I could have 'pulled this off myself', but it didn't quite come about that way.
My '49 was in a one-man body shop for a year and a half, and I finally asked the guy if it would get done any quicker if I came and helped out. I didn't expect him to say yes, but he said sure, come on in and work on it anytime you'd like. I'd just retired, so I started going to his shop everyday to work on the truck.
I'd always been a bodywork and paint hack, but between what he taught me and what I read from articles like yours I've learned a lot and improved greatly.
I'm on my second project now, a old MG with a coach-built body (metal over a wood frame) Same arrangement as on the truck - I show up at his shop to work and he fills in all the gaps for stuff I don't know how to do. So far I've learned the basics of metalwork, including fabricating new doors for the MG on the English wheel, making crowned patch panels on the wheel, shrinking/stretching/planishing/straightening with a hammer a dolly, welding with gas, and on and on. The latest has been how to perfect your metal work with fillers, so this post was timely.
The guy with the body shop hires guys to work but they last a couple of weeks and leave. I don't really understand why, as I have a lot of fun doing it - it might of even been a great career if I'd started it forty years ago.
Old 01-02-2018, 03:45 PM   #18
MARTINSR
MARTINSR's Avatar
I was 15 when I bought my truck with paper route money for $200 (black and white photo is it's first day home). A few months later, and I was 16, I chopped the top. I loved this stuff so much and had all kinds of plans on cars to build.
I was delivering my newspapers and as I rolled up on my bike at a customers house he was getting out of his truck and going in and he had a shirt on with the name of a local Chevy dealer and "Body Shop" on the front of it. I was kinda confused, no kidding, I asked him if he worked at a body shop. He said yes and it hit me like a rock, I could do this stuff for a job? This man, owned a home and had a wife and all and he did this for a job? I was blown away, It had never crossed my mind that I could do this as a job, holy cow! I went to work full time a week after graduating high school in June 1977 and have fed my family and put a roof over my head ever since.
Few days I want to go home you know what I mean? I have enjoyed doing it for 40 years.
You are very lucky to have that guy! I hope you got him a nice bottle of his favorite wine or brandy or what ever for Christmas.
Brian
1948 Chevy pickup
Old 03-17-2023, 03:49 PM   #19
dagnabbitt
dagnabbitt's Avatar
Old thread, I know, but I am trying to select a body filler and have been sidetracked by the Evercoat product lines' bizarre naming conventions.
What is the best product: the Evercoat Gold, Ultra, or EXTREME? Are they all basically the same?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 03-17-2023, 07:06 PM   #20
mongocanfly
i dont know all the differences, but ive used a good bit of the ultra...and i really like it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-18-2023, 11:07 AM   #21
dagnabbitt
dagnabbitt's Avatar
Good enough for me: that's the one I will try, thanks.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 03-22-2023, 09:38 PM   #22
65truckowner
65truckowner's Avatar
Evercoat is the way to go for sure. I used some other junk for a few trucks then bought evercoat and no comparison hands down
65truckowner is offline   Reply With Quote
