04-10-2023, 09:53 PM | #26 |
Re: Site feature trucks list and information
Here is my 72 C20 Cheynne Super. I bought it back in 94 after an accident in a 69 GMC C20, long story but I only paid $150 for it. It originally came with the big block 400, T400 trans, AC, Tilt, AM/FM Push Button Radio, Houndstooth Seat and Overloads springs. I built a 511 CI, Perf Built T400 trans with Gear Vendors and 4.10 rear gears. Tri-Y headers with 3" exhaust and 40 series Flowmasters. Interior has been sprayed with Lizardskin heat / sound barrier and also Flatline Barrier placed on top with new carpet. Customer Auto Sound stereo with 6x9 cab corner speakers and a 8" Bazooka Bass. Fuel tank removed from behind the seat and installed a Boyds custom made 30 gallon fuel tank that is behind the rear axle. Installed a Fi-Tech Fuel injection with an Aeromotive In-Tank fuel pump. Widened steel rims - rear are 16x10 and front are 16x8. Customer built Wizard radiator with 2 x 14" SPAL brushless fans that are PWM. AC has been converted to R134A and kept as close to stock looking as I could get.
Continued |
04-10-2023, 09:55 PM | #27 |
Here are a few more pics -
04-10-2023, 10:05 PM | #28 |
Not sure if this was only for certain trucks but I thought I would include my 2000 S10 Xtreme drag truck.
I bought and built this truck back in 2013. It is currently running a 374 CI small block which has a Dart Little M block, Callies crank, Manly rods, Diamond 14.5 CR pistons, Comp Solid Roller cam, Dart Pro1 heads that has been port matched to a Dart intake, T7D Shaft Rockers. ATI Pro T400 trans with a 9" converter, 4" aluminum driveline, S& W Backhalf 4-link, 9" rear with Strange Aluminum center section with spool and 4.71 gears. 32x14x15 Good Year slicks. Front runs QA-1 Pro Coils with TRZ upper/lower tubular control arms. Continued |
04-10-2023, 10:06 PM | #29 |
A couple of more pics of the 2000S10 Xtreme
04-11-2023, 11:33 AM | #30 |
Catchy title goes here..
Information on how to submit is in the first post. Thanks!
