04-26-2023, 11:03 PM | #26 |
Re: 1970 C10 ChassisFab Build Thread
Got a remote battery jumper installed so the frame won't be stuck on the ground if (when) the battery dies.
My 1970 C10 ChassisFab LWB to SWB Build Thread |
05-08-2023, 03:34 PM | #27 |
Tear down and rebuild of the non-tilt column
05-08-2023, 08:29 PM | #28 |
just read your build thread nice really nice work @ light speed compared to me being stalled Im getting in the passenger seat of this build
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
05-10-2023, 04:16 PM | #29 |
Clean, clean, and clean some more. Gonna spray these all with ospho and then epoxy prime everything together.
This Evaporust stuff is no joke! Wish I could dunk the whole truck in it
05-11-2023, 11:02 AM | #30 |
Looking good.
05-11-2023, 10:25 PM | #31 |
That stuff is amazing. I didn’t believe it till I used it myself.
Nice progress
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-05-2023, 11:22 AM | #32 |
Parts got a little Ospho bath. I will let this coat sit for awhile to cure. Then, I will reapply the Ospho, quickly pressure wash each part, and dry. The parts will then be ready for epoxy primer and underhood satin black.
06-06-2023, 06:36 AM | #33 |
Your doing great! This is going to be a very nice truck! Does your frame cut down area seem strong?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-06-2023, 01:13 PM | #34 |
Appreciate it! The ChassisFab C notches are very very thick metal, much thicker than the original frame. I had a mobile welder come and do the frame so I'm confident in its strength.
07-04-2023, 09:09 AM | #35 |
following along! Found this while searching for chassis fab reviews posts on here!
1970 - Green LWB C10 - 250 I6/3OTT 1969 - Blue/White LWB C10 CST - 350/TH400 1950 - Original Patina 3600/S10 |
07-06-2023, 12:00 PM | #36 |
subscribed
1966 C10 Mary 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
07-10-2023, 10:51 AM | #37 |
Looking good. I noticed the track bar is not adjustable. Do they set up their rear suspension so the rear diff is centered at ride height? I've done a couple air ride setups with parallel 4 link and track bar and the track bar is usually adjustable for that purpose.
07-10-2023, 11:06 AM | #38 | |
07-11-2023, 06:57 AM | #39 | |
Can't wait to see this project completed. My 69 has a M2 front end and coilovers all around but I'm thinking about swapping to air. |
08-22-2023, 12:44 PM | #40 |
any updates?
08-22-2023, 03:00 PM | #41 |
Keeping me on my toes, I appreciate the motivation from this group! Here's some status updates:
1) I built some wood blocks to get the frame off the ground. The frame moves around pretty well on the Harbor Freight rollers! 2) Engine is back from the builder! It is now a 357 with aluminum intake and Brodix IK heads. I am waiting for some parts to arrive so I can smooth the block with fillable polyester primer and shoot it with orange and clearcoat. Once I finish painting it we can drop the engine/trans in the frame and then route the exhaust. I'm debating with myself whether or not to get a Gear Vendors overdrive unit to pair with the TH350. TH350 is freshly rebuilt and a great transmission so I would like to keep it. Plus a cat tax for those interested.
08-25-2023, 12:51 AM | #42 |
ThermAC delete and some block work before filler primer
09-18-2023, 06:42 PM | #43 |
Engine painted, and got the decals installed. Just needs a clearcoat!
09-18-2023, 11:00 PM | #44 |
Nice build.
Are those original early style rocker covers, or reproduction? |
09-18-2023, 11:11 PM | #45 |
They are reproductions from Ebay. Good quality, can't complain!
09-19-2023, 12:53 AM | #46 |
09-19-2023, 12:57 AM | #47 | |
https://www.summitracing.com/parts/AMD-W-541
09-19-2023, 10:10 AM | #48 | |
09-25-2023, 12:06 AM | #49 |
Got the motor and trans installed this weekend. Could not find the right torque converter bolts so that was a bit frustrating. Need to do some digging for the 4701rv torque converter.
And the last snag I kind of anticipated was the drag link hitting the oil pan. It is very close, only about an inch. I think I can bend the drag link just enough make this work. Otherwise I don't know if there is any aftermarket solution for a different shaped drag link. All in all I'm excited to start the exhaust!
09-25-2023, 07:14 AM | #50 |
Looking real good …. Drag see more on that ?I know I thought mine was close but it all lined up and clears the pan
