03-05-2023, 08:47 AM | #351 |
Re: Build that 71 402 already
Awesome truck, I really love everything about it! Great job on the restoration!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
03-05-2023, 10:53 AM | #352 |
The most comprehensive and thorough build I've ever seen. Well done.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
03-05-2023, 12:33 PM | #353 |
Thanks a bunch guys. 68, it's too bad we don't live closer, I think it would be very cool to help get your truck to your liking. Unbelievable snow incidentally, I can't believe it. Stopped snowing around midnight, but woke up to another blizzard and it's non-stop. About that US radiator, near as I can tell it's an only choice OER. It's super nice and the others are junk.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-05-2023 at 01:01 PM. |
03-05-2023, 01:14 PM | #354 |
Amazing job Tony. I am a huge ochre fan too. I learned when I had mine, that the color was way more popular with men than it was with women. I'm sure the upholstery will turn out great .
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
03-07-2023, 07:40 PM | #355 |
Results are in, the rebuilt transmission won't go into Reverse. That was done 2018. So carb tune and choke are still pending. The shop says trans is full and flow through the system.
I arranged for towing, but while we were )*^)ing around I asked what they thought of driving it home 6 miles. They were somethin' like, "I've been known to". Unregistered, no bumpers, untested. 27 year tires So it was a bad day. They pass on anything more than outside the transmission and pan. Old man says he can't recommend anyone, and it appeared I may have to pull the transmission............Oh NOOOOO! The shop that rebuilt the transmission won't R & R, and warranty is well expired. I wouldn't want to leave it there anyway, they have WAY too many employees for starts. The shop guys dialing this in and I go back 50 years. Old man felt sorry for me I guess he asked a special favor of a transmission and ? shop 30 miles from here. I spoke to them, and it sounds like they've taken an oath of honor. Old man says don't tell them what to do, you'll piss them off and me too Fluid is full and I'm 99.9% sure I installed the torque converter right. Three clicks and/or feels you're in, proven by an approx. 1/8" gap between the flex plate and converter with the bell housing mounted. Pull the converter forward and bolt it. It's likely not the fluid, though perhaps I took a risk. While the trans. shop that rebuilt it recommends Dexron 4 only, I used Mobile Delvac Allison approved synthetic. I read it's the best for a fresh transmission, even rebuilds of old. So perhaps it's the governor, some rod, couldn't tell you. Goes in Monday. What a money pit, I'll probably pay to have it hauled. Could rent a U hail trailer I suppose, and push it off, but its kind of a hassle. Really, I should just buy a trailer at this point.........Hmm. About the drive home and such. Everything works so far but the fan blower is making noise. I'm little nervous about the resistor, because the connector in the new harness leaves much some to be desired. Sure, plug it in all the way if you can and break something. But I think it's just the the blower. Beyond that this truck stinks badly, a real toxic smell, you figure that's all new finishes and crerekote especially? I didn't expect that, it's STRONG. So not all bad, I just have to pull out another $1500ish and extend this BS till done, and figure out why the noise. I can't track it down anymore, the transmission is now leaking badly with the engine running, and the carb. isn't tuned anyway. Not sure why the leak beyond the pan gasket was leaking and was supposed to be replaced. No reason to do that now.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-07-2023 at 10:00 PM. |
03-13-2023, 01:59 AM | #356 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
03-25-2023, 02:13 PM | #357 |
Golly I'm in 4K for a transmission counting towing. I don't know which is worse compared to 2K for just a radiator counting towing as well. I'm probably in too close to 7K in do-overs.
The shop for the first rebuild filed down the reverse pin or something like, so it wouldn't engage. The new shop said perhaps that was done with the thought it would smooth out reverse, but regardless they messed up. The new shop said they had to replace the converter as well, and installed "something more heavy duty". They threw a rebuild kit at it, installed the Moroso gasket and ARP bolts, and said yes, the Allison approved fluid I'm using in the transmission is a good choice. Nice shop, great work, they R&R the transmission scratch-free to the tune of $1700. Truck runs rougher than I'd like, but the next stop is for carb. tune and divorce choke. Then to a shop for alignment followed by an A/C charge. From there I get to install the grilles, and the bumpers I haven't selected yet. Came home from the shop to find my bench seat cover arrived, it's the exact material as it was new, wow. $900+ gets the same, and this one was ordered about 1 year ago. I've developed a kit for how to build these from the ground up. The primary document is a 68 page assembly guide packed tight with details. The kit's nearly done pending installation of what remains. It's easier to say what it doesn't include. It doesn't go into the core of things short assembling drive shafts, oil pump, timing chain and some etcetera's. In other terms, it doesn't describe how to rebuild an engine, transmission, steering box etc. The document also doesn't ramble on like my posts☺, it's short and sweet with a rhythm to it. Some background, I wrote business and system processes for many years. Other then research, the hard part was figuring out what everything was called; because all of this was new to me. At any rate, this document is the best I've written. Perhaps 1000s of original part numbers and identifications are captured by the guide and a document with part numbers. It includes approx. 650 images and illustrations as well. I'm selling copies of the kit for $42.50, but heck, for board members let's say $32.50. If you're interested, you'll see that's money well spent, too many hours went into the development and research. More time was spent on that than building the truck itself. Here's a Facebook page sampling some of the kit. Anyway, please let me know if interested. The kit will be ready by June. https://www.facebook.com/profile.php?id=100091294598717
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-25-2023, 03:12 PM | #358 | |
thanks for your efforts. lmk when available
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-25-2023, 05:40 PM | #359 | |
03-28-2023, 10:33 PM | #360 |
Came across this tonight "by accident". Kind of cool
03-28-2023, 10:47 PM | #361 |
Great Info
03-29-2023, 01:25 AM | #362 |
Wow cool. Is that 1972 truck specific?
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
03-29-2023, 01:10 PM | #363 |
I don't think so. I searched for a 71 wheel and this came up. Did the codes change often? Seems they wouldn't.
03-29-2023, 09:38 PM | #364 |
Awesome. Good point, I bet they didn’t change “much” aside from new options that came later.
05-03-2023, 11:50 PM | #365 |
Good day today, my A/C is charged. Kind of cool, I've owned the truck 34 years and the A/C hasn't been operational until today.
One thing I learned from building this truck is best to save as many o-rings as possible for last, at least in this climate. They had to replace all the AC o-rings, I had a feeling they would, the a/c was built a year or so ago. I greased the rings and tighten everything snug, figuring to let the experts tighten the nuts. Oh well. $450 on top I don't know, 3K to restore the rest of the AC from the evap core to condenser. Polished these up today too, they came out super I was going to replace the decals, but one is as good as new; the other has mileage I can live with. Trying to decide on tires, the painter has the wheels and caps are ready. Leaning on these but kind of expensive. https://www.performanceplustire.com/...1:ts:23575-15/ Did I mention I have a 4th radiator to install yet? Yeah I'm pretty good at it now Yeah sure, the first two were junk. Then what you'd expect to be a nice one leaked, and after installing their replacement I realized they installed the filler WRONG, wtf? Cap jacked up the finish on a radiator bracket, so WTH, now I have two sets of upper radiator brackets to have powdered somehow, another do-over, gross. My FIFTH attempt at a radiator is currently being built, they promise the A-team this time My bumpers are in Fresno, I'm crossing my fingers. $1700ish. Other then that the seat is pending, door cosmetics and flooring are pending that, and I'll install the grilles someday, declare her done. Oh yeah, speak of radiator brackets, for curiosity and another option, I bought a pair of NOS upper brackets. Part number matches the book. I had to bend the bracket's top nearest the shroud quite a bit, almost flat. The brackets come raised, and miss the shroud's holes by 3/8" or so, - same for reproductions. I don't get it beyond it's a great fit all the way around to bend them right. If that's what the factory was working with, then that could explain why so many shrouds were fitted wrong. At least for BBC, probably 4-row radiators (A/C), where many were struck by the fan at the bottom because they were off the bottom clips. The original shrouds don't lie, but the brackets sure seem too, at least for a 4 row radiator. Heck, the factory didn't even install one of my lower brackets right. 4 row requires a simple mod of the core support, but they only did one side.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-04-2023 at 01:03 AM. |
05-04-2023, 12:05 AM | #366 |
I'm trying....
Ever so close. I'm excited to see her get to the finish line. Can only imagine how you're feeling. Continued kudos on outstanding work.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
05-04-2023, 12:48 AM | #367 | |
I forgot to mention, the A/C shop's owner took a look at my truck and then pulled the cover off his 68 Roadrunner 426, OMG original parts, and very clean. Not exactly a full restoration, a lot doesn't need it, the car speaks for itself. I wish I asked to take a picture of the engine bay, mint and so impressive. I have to say an original BBC engine bay is a beautiful thing, but wow, that 426, with no A/C is basically a tremendous BLOCK with nothing but simple all the way around. Short the duel injecting carb business, I don't have a clue. He bought it from a guy who has 11 426 passenger cars.
05-04-2023, 02:06 AM | #368 |
What’s happening with bumpers in Fresno? Chrome plating used OEM?
Also, what’s the goal with the radiator, are you having it (them) rebuilt so they are original? Those tires are awesome. I like a little wider stripe, but I’m sure you’re going for whatever is closest to original.
05-04-2023, 07:42 AM | #369 |
hi Tony,great work,beautiful truck and off-the-chart attention to detail.i feel for you with all this rad trouble.wished we were closer,i'd build you a rad and it wouldn't take 5 attempts?you've built an amazing truck.you must be very proud.good for you.can't wait to see what you build next?
take care.all the best.Greg |
05-04-2023, 11:37 AM | #370 |
Thank you.
Yeah the OEM bumpers are being replated. Some places in Ca. still do triple plating, apparently. Place is called Moreno's Chrome. I hauled them to Fresno last week. I may run with the 3/4" white wall instead of the 3/8". I was looking at Coker tires, but it would seem they're no longer built well. Folks seem real happy with Diamond Backs. First radiator from Summit had bad transmission fittings, and really wasn't worth a dang to begin with. I never should have installed it. Second from Speedway was full of loose welds, I only installed it temporarily to run new transmission lines. 3rd came from US Radiator, it leaked. 4th from them has the filler in the wrong spot, they're sending another. US Radiators are heavy, look, and generally fit like OEM.
06-03-2023, 07:02 PM | #371 |
Threw the grille on today, it's been a long time coming. The outer has been wall decor the last 7 years. Inner was shot, sanded, shot again and a clear coat, needless to say it's much heavier now. Took longer than I thought of course, nylon clips have to be sanded just right. My assistant, really vise versa, he's body and paint guy dropped these wheels off today. Tires due "in a month", bumpers due "call back in two weeks", upholstery & flooring is supposed to call. Other then that and a few decals it's done. I ended up choosing these tires. Diamondback 235-75-15.
06-03-2023, 11:47 PM | #372 |
I’m guessing August 21st all that is final. That’s still a lot of waiting…
06-04-2023, 06:48 AM | #373 |
Nice Work
You have an Over the Top build. So you recommend US Radiator? They are about 3 hours from me. I may get my next radiator from them.
07-06-2023, 12:28 AM | #374 | |
These wheels were on this truck 26 years ago, until today. It had 15x8 Rallys, which I'll restore as another option, but the truck drives far and away better on the original wheels and good tires. Tires are Diamondback Auburn. Bumpers are due to be finished Friday. Other then that, still waiting on a call for upholstery and flooring. Edit, I still had to install the correct valve stem cap yet I bought some brass valve stems, but darn, wrong fit. The old man had some nice stems though, really, probably closer to original, which have a "clear" finish.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-06-2023 at 08:06 PM. |
07-06-2023, 12:29 AM | #375 |
Looks amazing with the wheels all together
