07-10-2011, 08:10 PM | #1 |
AC in our trucks with a SBC - which side for the compressor?
Howdy.
I'm just curious... for those of you that have or had added Air Conditioning to your trucks.... looking at the engine from the front of the truck... which side do you have the ac compressor on? The reason I ask is my alternator is on the left. Anyway, just curious.... -W |
07-10-2011, 08:16 PM | #2 |
Re: AC in our trucks with a SBC - which side for the compressor?
Left side looking at engine.
(which actually is the right side)
72 C-10 04 HD Fatboy 82 Suzuki GS850 Cafe 78 GS1000 Skunk |
07-10-2011, 08:42 PM | #3 |
most aftermarket ac folks has it set up on passenger side.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-10-2011, 08:43 PM | #4 |
07-10-2011, 10:24 PM | #5 |
Senior Enthusiast
When I added A/C I purchased a set of Alan Grove brackets and moved the alternator to the driver side allowing the compressor to mount on the passenger side. Mounting it on the driver side is going to require some inconveniently long hoses.
07-11-2011, 01:50 AM | #6 |
60-66 Nut
The original location for the A/C in the '72 and older trucks is on the passenger side with the alternator on the drivers side. Of course this is with the short water pump. In '73 when GM went to the long water pump in the trucks, the alternator went to the passenger side and the A/C on the drivers side
07-11-2011, 10:03 AM | #7 |
Mine is on the driver side.
07-11-2011, 10:09 AM | #8 |
maybe a serp belt system is in your future?
07-11-2011, 11:28 AM | #9 |
Mine is on passenger and it is a 60's era aftermarket unit installed in 1966
66 C20 LWB CS 327/TH400 A/C |
07-11-2011, 02:51 PM | #10 |
looks like a newer pump on that 66 setup...
07-11-2011, 04:32 PM | #11 |
I have a 91 burb serpentine belt system and it is on the passenger side, I thought when I measured my water pump it was a long shaft but maybe I misunderstood how to measure it. Kieth
R4 compressor in place now pass side, will soon be a sanborne...... http://kieth.smugmug.com/Trucks/66-G...805843_BqZMQNP |
07-11-2011, 08:25 PM | #12 |
New pump and condenser the old one's went bad so the new ones run R134
05-04-2023, 08:30 PM | #13 |
My serpentine setup came out of a 96. Compressor on drivers side
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
05-04-2023, 08:59 PM | #14 |
My '64 has an early 80s SBC with passenger-side alternator, and a custom new wiring harness for that application. So the A/C compressor will be on the driver's side.
05-05-2023, 12:04 PM | #15 |
Woooowee..... Dusted this one off.
05-09-2023, 03:59 PM | #16 |
05-09-2023, 07:38 PM | #17 | |
05-09-2023, 08:10 PM | #18 |
The first photo is of my old engine and the second is of my new engine. I had to get different brackets because my new engine has Vortech heads and a vortech intake manifold. Both are from Allen Grove.
05-19-2023, 08:50 PM | #19 | |
This first one allows the large suction hose to run along the firewall, behind the carb. Still a medium-long hose, but much nicer routing than over the top. This extension pipe for the condenser inlet crosses over to the driver's side. It allows the hose from the discharge of the compressor to drop down and connect through the left side of the radiator support. This is a much shorter hose than having to run over the top and into the condenser on the right side. |
05-22-2023, 02:00 PM | #20 |
And here is the completed install. The extra pipe adapters allowed me to simplify and tidy the hose routing significantly. It turned out nicer than most left-side compressor installs that I've seen.
05-25-2023, 05:56 AM | #21 |
05-25-2023, 08:42 PM | #22 |
Grrrrrr. Why are we relying too an old thread.
05-25-2023, 09:25 PM | #23 |
Sorry bout that. Did a search for something and this came up. didn't notice the date
05-25-2023, 10:49 PM | #24 |
Not a problem to reply to an old thread if the reply has related information and provides meaningful input to the overall message board.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-26-2023, 08:43 AM | #25 | |
That being said, I'm amazed sometimes @ the time gap on some. Twelve years is a pretty decent stretch.
