Old 05-22-2023, 12:44 AM   #1
D-n-Tyke
Parking Break Rear Cable Help.
Swapping out the 8-lug 3/4 ton rear end for a 5-lug 1/2 rear end. Can I use the stock rear parking brake cables from the 3/4 ton brakes on the 1/2 brakes? I have the cables from my original rear end. The 1/2 rear end didn't come with any so trying to use what I already have.
Putting 1971 C10 1/2T 5-lug rear end in a 1969 C20 3/4T Suburban.
(I tried looking up park numbers to compare the two but can't find a part number for my suburban)
D-n-Tyke is offline   Reply With Quote
Old 05-22-2023, 06:31 PM   #2
D-n-Tyke
Re: Parking Break Rear Cable Help.
Still looking for help with this?
Old 05-22-2023, 09:50 PM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
No you will have to get the cables for the 1/2 ton rearend
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 05-22-2023, 11:35 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Here's what your looking for... https://www.classicparts.com/1966-72...ctinfo/71-771/ And here's LMC's image of the various parts of the E-brake cables... https://www.lmctruck.com/1967-72-che...g-brake-cables
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-23-2023, 12:42 PM   #5
HO455
HO455's Avatar
I don't believe you can as the 3/4 ton axle has different sized drums and backing plates so the inter-cable is likely a different length.
I don't believe there any difference in a regular long bed pickup and a Burban part numbers for the rear cables as I don't remember having any problems getting new ones for mine though NAPA back in 2017. Just be sure the person behind the counter understands which springs you have. They may have to look in the book () if their computer doesn't tell them which is which.
RIP Bob Parks.
Old 05-25-2023, 12:43 AM   #6
D-n-Tyke
Thanks. Yeah, went and looked at the cables last night. Cables on the 3/4T axle bolt to the backing plate while the 1/2T push thru the backing plate. So based on that I knew I needed 1/2T cables. However you just cleared up my next question, if the burbans ran the long bed cables. Although, looking at Truck Shop and LMC it looks like the same rear cables are used on both Short Bed and Long Bed trucks (and Suburbans). Is my research correct?
Old 05-25-2023, 12:52 AM   #7
Killer Bee
Killer Bee's Avatar
https://www.inlinetube.com/ may have the parts / info you need
for an axle swap you may have to call if search doesn't turn up something obvious
good luck!
Old 05-26-2023, 05:23 PM   #8
HO455
HO455's Avatar
I'm pretty sure the rear cables are the same for long and short beds. They both use the same trailing arms so the difference is made up with the intermediate cable.
RIP Bob Parks.
Old 05-26-2023, 11:02 PM   #9
D-n-Tyke
That's what I was thinking about the trailing arms too. That's for reassuring my thought..
Old 05-27-2023, 04:09 PM   #10
RustyPile
RustyPile's Avatar
It's been several years (2017) since i replaced the rear cables on my 1/2 ton SWB.. If I remember correctly, the front rear cables are the same for all 1/2 tons with coil springs - SWB, LWB, and Suburbans. The intermediate cable is determined by the wheel base.
RustyPile is offline   Reply With Quote
Old 05-27-2023, 11:41 PM   #11
zosoppp
The rear cables are different lengths depending on coil spring or leaf spring rear end.
I suppose the front cable might be different for the earlier hand lever vs the later pedal type.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
