05-21-2023, 11:43 PM | #1 |
70 C10 SWB Frame Measurement Needed
Hey all, hoping someone can help here.
I'm in process of installing a Summit frame brace kit and things aren't lining up. I'm trying to figure out if it's the kit or my shortened frame (done by previous owner) I'm looking for a measurement from the rearmost upper rivet of the front body cab mount and the frontmost upper rivet of the trailing arm crossmember (see pic) I'm off by 3/16" on one side and 1/4" on the other. Top pic is from the instructions, bottom pic is what I have. I measure 29 5/16" on one side and 29 3/8" on the other, but my frame holes are 29 1/2" and 29 5/8" I fear it's the frame because the holes aren't even the same side to side. |
05-22-2023, 01:32 PM | #2 |
Re: 70 C10 SWB Frame Measurement Needed
Frame specs are below for the SB. It doesn't have the measurement you're after but it does have two different ones you an use. The 43.03" and the 72.49" measurements from the reference hole just past the trans cross member location shown in the first photo. 2nd and 3rd photo go together and you could use the N or O measurement.
I just installed that chassis brace this weekend and had to open up the holes on one side of the chassis brace to allow the bolts to be 1/8" rearward due to the same issue. I shortened my frame and one side was just slightly 1/16 - 1/8" longer than the other when welded back together. I finally got it in there . |
05-24-2023, 12:11 AM | #3 |
Thanks for the drawings Problem is, I still have the cab on the frame, I only removed the bed, so I don't have easy access to any of the gauge holes. On top of that, it's sitting in a driveway that isn't level.
I also don't have a reference hole by the bellhousing crossmember. If I'm reading the 1st drawing correctly, it should be 2.78" from the center of the crossmember, and there's nothing there. Looking at another thread, seems someone else had to slot the holes as well, so I think I'll bolt the front in and just slot the rear piece as needed. https://67-72chevytrucks.com/vboard/...d.php?t=837552 |
05-24-2023, 03:23 PM | #4 | |
My frame was SWB to start with and the rear cross member rivet holes are where I started. I figured they were oriented correctly and square to the frame rails, as they seemed to be, because they lined up perfectly. All the slots I put in were in the front frame brackets.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
05-24-2023, 03:53 PM | #5 |
If you still need the measurement, let me know and I will measure it after work.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-24-2023, 08:56 PM | #6 |
05-24-2023, 09:31 PM | #7 |
Driver’s side measures 36 and 3/16, almost 1/4, and the passenger’s side is 36 and 3/8. I wonder why they are not symmetrical…. Mine is a ‘70 original SWB frame.
05-25-2023, 01:03 AM | #8 | |
Now I'm less concerned about the frame being out of whack, guess I'll just do my best to square up the trailing arm crossmember to the frame rails and call it good. |
05-26-2023, 09:30 AM | #9 | |
05-26-2023, 09:55 AM | #10 | |
Good luck with it, the brace seems to really stiffen the frame.
05-26-2023, 02:50 PM | #11 | |
If your surface isn't flat and level you need to shim your frame supports (jack stands) to get the frame level. Using a cheap 360 degree Lazer level and a tape measure can get you with in the 1/8 of level needed for most vehicles. Once again if you've already done this please accept my apology. I've seen to many cars marginalized by poorly installed subframe connectors and/or roll bars.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-26-2023, 05:45 PM | #12 | |
I'm lucky enough to have a nice level surface to work off of...
05-26-2023, 06:34 PM | #13 |
You would think it would be, but 10 or 12 years ago we had a guy bring a nice mid 70's Camaro into the body shop to get his doors aligned. They were hard to open and you had to really slam them to get them to shut. We assumed they would need new bushings in the hinges but, after inspection we found the hinges were nice and tight. So we looked further thinking the car had been wrecked or something similar. The only thing I found was a set of frame connectors that looked newly installed.
After some discussion with the boss, he called the owner in and, after some more discussion, the owner admitted he had installed the connectors a couple months earlier. When asked how he installed the connectors he said he just jacked the car as high as possible on one side and welded that connector on before moving to the other side. He claimed not to own any jack stands just a floor jack. Fortunately for him his welds were poor and not nearly enough so it only took me 3 hours to remove them and grind everything clean. Then he paid us to install them a second time.
05-26-2023, 09:56 PM | #14 | |
I had the rear higher so I had room to work and get everything in, but I moved the jack stands to where the axle would be to try and simulate where the weight would be and levelled it out front to rear best I could before tightening all the bolts. |
