#3851 |
Re: What did you do to your truck today.The 3rd chapter
Expensive way to mask but I have three rolls that were given to me . 3M welding and spark deflection paper . Nice it has a little adhesive to hold it in place
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#3852 |
![]() Join Date: Mar 2021
Mark, it looks like your starter is too far away from the flex plate, if you have a starter shim in there, take it out ........ replace the Bendix as well .
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#3853 |
No shim ,it’s a Powermaster had a good gab when I installed it a few years ago . Think the damage was before my ownership and it got worse over time . I should have inspected the flex plate more thoroughly.
#3854 |
![]() Join Date: Sep 2001
I removed the bed wood to refinish it. My bed wood planks are Birch wood. I finished them many moons ago with polyurethane, that has not held up well. I plan on stripping that off and using an oil instead of a surface coating. I also replace the sending unit because the fuel level float floated away on the last one. I used a plastic float instead of the brass one this time around.
#3855 |
![]() Join Date: Dec 2012
Gearing up for a 4/5 drop and disc brake conversion up front this month -
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3856 |
68 C10 Longbed
![]() Join Date: Sep 2006
Installed new CCP rear sway bar on the 68.
#3857 |
I hooked my trailer up and helped my son move from one storage place to another
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#3858 |
![]() Join Date: Mar 2011
nice
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3859 |
#3860 |
68 C10 Longbed
Here’s some pics of the new CCP rear sway bar installed yesterday. |
#3861 |
68 C10 Longbed
https://www.67-72chevytrucks.com/vbo...1&d=1685707942 Here’s pics of the front sway bar installed on my 68 C10 last weekend. I used an original C10 bar with CCP mounting brackets and poly bushings. |
#3862 |
Nice thanks for posting my front is done and need to do the back have what I need just haven’t got there yet but this is a motivator
#3863 |
68 C10 Longbed
Yep, understand. Just so you know for the rear bar I installed you will need to drill (6) holes (at least for a 67-72 c10). Good luck👍
#3864 |
Rear bearings and shoes
#3865 |
#3866 |
![]() Join Date: Jul 2000
I installed a rear bar many years ago on a long bed truck that already had a front bar. The rear bar really made a difference in steering response and how flat the truck stays in corners. I mean, we're not talking Camaro, but it was a major improvement!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#3867 |
I re-installed my windshield wiper motor with a new washer pump. Kind of a PITA to get the three bolts started, but it all works great. BTW, Rock Auto had the lowest washer pump price by a large margin.
I used cowl-to-motor and shaft seals from GMC Pauls. They are first rate. And this is a great tool for removing and re-installing the wiper arms. Lisle 65750, Dorman 49023 ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 06-03-2023 at 09:54 PM. |
#3868 |
![]() Join Date: Feb 2009
Threw this together today, it's been a long time coming. The outer has been wall decor the last 7 years. Inner was shot, sanded, shot again and a clear coat, needless to say it's much heavier now. Took longer than I thought of course, nylon clips have to be sanded just right. Anyway, we install it tomorrow. Edit, installed. My assistant, really vise versa
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-03-2023 at 06:38 PM. |
#3869 |
Grill came out great .
All of the bearings and 2 of the races came today just waiting on the outer races and grease seals . At least there are no Chinese parts going on the truck . USA and Japan
#3870 |
68 C10 Longbed
#3871 |
68 C10 Longbed
Thx Mike, yes I can feel the difference.
#3872 |
Nothing actually done to the truck, because it's 30 miles away at my dad's shop for now, but parts boxes are arriving
![]() Still waiting on the shipment from Cliff's High Performance for the throttle shaft bushing kit and rebuild kit to make the carb as perfect as I can make it. Pic just because Last edited by wrangler94; 06-03-2023 at 03:18 PM. |
#3873 |
Uhh oh
#3874 |
Thanks, I installed one back in the mid-90's on my 72 C20 that was 7/8" diameter. I been wanting to go to this larger bar. Looks like I will be talking to CPP for sure.
#3875 | |
My dad had a gold 67 Impala 2dr hardtop with gold vinyl interior. Probably a different gold, but it was super cool!
