Old 12-21-2022, 01:29 AM   #1
Mr3Speed
5.3 LS oil pan clearance
The factory LM7 - 5.3 LS oil pan fits into my 69 c10 by a good ways with Dirty Dingo Slider engine mounts. There is probably 5 inches between the pan and the cross-member. (pics will come once the engine is mounted in the truck)
Mr3Speed is offline   Reply With Quote
Old 12-21-2022, 01:36 AM   #2
Accelo
Accelo's Avatar
Re: 5.3 LS oil pan clearance
Yes the pan will fit the chassis. The extended part of the truck pan, that part that is below the cross-member, is just too low for a lowered truck. It is a couple inches below the factory cross-member.
If you plan on lowering your truck I can't recommend the factory truck pan. Stock or higher I don't see an issue with it.
Cheers
Accelo is offline   Reply With Quote
Old 12-21-2022, 09:58 AM   #3
Joyridin
Here are all the various pan dimensions. You might be able to use a factory pan if you do some measuring.
https://www.improvedracing.com/gm-ls-oil-pan-dimensions
Joyridin is offline   Reply With Quote
Old 12-21-2022, 01:33 PM   #4
evan
evan's Avatar
That's a cool resource. Kind of strange they didn't include the Gen 3 truck oil pan though (2006 and older) since it's so common on swaps.
Evan B.
evan is offline   Reply With Quote
Old 12-21-2022, 03:41 PM   #5
Accelo
Accelo's Avatar
I agree it is a missed addition to the cool site with references.
The early truck depth is 9"
The gm retro fit pan is 7.750
Old 01-01-2023, 12:22 AM   #6
Mr3Speed
Pictures from my not lowered truck, dirty dingo sliders and the factory 5.3 pan
Old 01-01-2023, 11:45 AM   #7
Jason Banks
Jason Banks's Avatar
That doesn't look too bad.
Jason Banks is offline   Reply With Quote
Old 01-01-2023, 05:49 PM   #8
LS short box
Just remember LS pans don't dent they break if you hit something really solid.
Old 01-02-2023, 09:48 AM   #9
Joyridin
And the bottom of that pan looks to be in the perfect location to get smacked if you go over a large speed bump or something to that effect.
Old 01-02-2023, 11:32 AM   #10
hewittca
hewittca's Avatar
For reference, here is the clearance with the 302-1retro fit pan. Keep in mind, this is also with a 3/4" pancaked crossmember, so the pan would be even more protected with a stock crossmember. I went with the 302-1 because it gave me almost 2 more inches between the crossmember and vertical face of the sump area compared to the 302-2. The consequence is that the 302-1 is about 1/2" deeper, but that turned out to be a safe compromise.
Builds: Green Gus the 68 C10 ; Bluey the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-03-2023, 12:09 AM   #11
evan
evan's Avatar
Thanks Mr3Speed and hewittca for the pictures. I've got a 302-1 on order.
Evan B.
Old 06-04-2023, 11:08 PM   #12
Tmend
Tmend's Avatar
Great pics and will also be ordering this pan. Would you mind sharing if anything else is needed. Does the factory dip stick tube get used. I’m going to be attempting my first 5.3 swap into my 72 suburban. Thanks much
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 06-05-2023, 08:56 PM   #13
LS short box
On my LS1 swaps with LS1 coil covers I use the Lokar oil dip stick. I find the truck and Camaro stock dip stick too long and kind of in your face.
I think Trans Dapt has a less expensive version of the Lokar.
Old 06-06-2023, 12:18 PM   #14
hewittca
hewittca's Avatar
I don't know if the factory dip stick works. I was under the impression that it did not so I ordered what was supposed to be the correct one for this pan, which happens to be from a Camaro. It's PN 12625031 tube and 12669528 stick. It looks fine for my build, but it does stick up quite a bit if you're trying to do something cleaner than my truck. Other than that it was a straightforward swap. I would definitely add the second mounting bolt on the oil pickup tube. Stock only has one but there is a treaded hole for a second and the tube that comes with the kit has a hole to let you utilize it.
Old 06-06-2023, 03:08 PM   #15
Jason Banks
Here's the Dorman part numbers for the GM Part Numbers above.
DORMAN 921-045
DORMAN 921-044
When I did mine I think the Dorman were slightly cheaper...
5.3 ls, clearance, ls swap, oil pan
