Old 06-11-2023, 04:46 PM   #1
Alloyvert
Active Member
Speedometer gear ratio adapter lubricant?
I finally got my truck on the road and diagnosing a non-working speedo. As part of the troubleshooting, I removed the rear ratio adapter and when trying to manually rotate, it was very stiff. So I removed what appeared to be a plug on side and noticed a lot of hardened grease in the gear housing.
That freed up the sticking and it rotates very smooth. Does anyone know what type of lube is used? I assume it is some type of grease as oil would leak out around both connections like it did while I was flushing it out?
Adapter p/n 1563872 along with a couple photos.
Thanks for any help!
Alloyvert is offline   Reply With Quote
Old 06-12-2023, 02:53 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Speedometer gear ratio adapter lubricant?
I'd go with white lithium. As per my Google assistant.... It is a corrosion-resistant lithium grease for metal-to-metal, metal-to-plastic, and plastic-to-plastic applications. Primarily, white lithium grease is used to lubricate moving parts, such as 3D printer mechanisms, gears, spindles, hinges, latches, tracks, pulleys, cables, machinery, tools, and equipment.
AcampoDave is offline   Reply With Quote
Old 06-13-2023, 07:31 AM   #3
Alloyvert
Active Member
Thanks as lithium seems like a perfect fit for this application.
