68 hood with no trim
I put the hood on Saturday afternoon but I’m thinking I should paint the underside of the front lip white . Not sure if it’s correct or not but think it would look better . What are your thoughts ?
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 07-04-2023 at 04:18 PM. |
Who Changed This?
![]() Join Date: Jan 2013
Re: 68 hood with no trim
If there is no trim going around the perimeter, I would say yes. The fender-to-hood line is offset. No idea how it's supposed to be, either.
Paint it!!
BlahBlahBlah
I have a local truck buddy that had one made. Looks great, but if I remember correctly (been a bit since I looked at it), the original vin tag was a combo of stampings and painted letters and numbers. His was all stamped, no paint like original had. People with no clue would have no idea, especially if rosette rivets were used. Personally not something I would use, hate to get caught even if it was used as a legit replacement for a damaged one.
#5 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Was the white originally painted in the grille area with no surround trim or did the two go hand in hand? I'd paint white the same as the fenders have white.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Paint it...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Dec 2009
Paint
I think either way you would be fine. And honestly, there aren't that many examples of white painted grill surronds on non trim trucks.
I did find one and it was painted.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
![]() Join Date: Jun 2002
I like the way this blazer was done. Not sure if it is stock that way but it looks good to me.
https://www.tmiproducts.com/blog/mat...1972-k5-blazer Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
And another one that is SUPPOSED to be mostly original paint.
That looks the best like like.
To get that look which I really like I would need to repaint the fenders which I really dont like. Might be able to back tape at the ridge line but it may or may not look good
BlahBlahBlah
Sheesh, hate it when that happens lol... So whatever you decide its going to look great just like the rest of the truck (I think Im responding in the correct thread ha)
#15 | |
![]() Join Date: Feb 2002
#16 |
How much hassle is it to add the anodized aluminum molding?
#17 |
I removed it all . I dont care for it on a stepside since there are no side mouldings to blend it
#18 | |
I've seen some '68s without it, but I'm pretty sure they were owner-removals. Your truck. Your call.
#19 |
Well aware of this, I know more about blazers and jimmy's than I do the trucks! I was referring to the paint breaks on non trim 68 hoods/grills. But I think the break is correct because I found these pics also.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd Last edited by raggedjim; 07-10-2023 at 11:23 PM. |
#20 | |
Looking closer, the Grille Hoops appear to be the MY '67 type, with a D-cross section [and in steel]. The '68 MY type trim on hoops, eyebrows and hood lip had an irregular cross section. An extra ridge for stability not needed on the steel hoops. So I guess I'm wrong in assuming all '68s came with the nose trim.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-11-2023 at 12:38 AM. |
#21 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 07-11-2023 at 08:26 AM. |
#22 |
I’m going to paint the lip white at some point seems like the easiest solution.
#23 |
I like painted grill surround painted the same color as the rest of the truck.
#24 | |
#25 |
I like it much better I did cheat though I used a wide white vinyl pinstripe . I wanted to make sure I liked it before painting it
