Old 07-14-2023, 11:02 PM   #1
kglowacky
temp sensor machining
Someone on this board was(is) machining the OEM temp. sensor down to fit the LS 1 head, Can't seem to find him on old threads, HELP Please.
kglowacky is offline   Reply With Quote
Old 07-15-2023, 05:05 PM   #2
LS short box
Re: temp sensor machining
May be not for you but I drill and tap the head for the correct NPT size. That way if the sensor fail a new one is only a NAPA parts store away.
Old 07-16-2023, 08:34 AM   #3
A1971Blazer
A1971Blazer's Avatar
I have been modifying the original sensors to fit the later model Vortec heads but not for LS family engines.
The standard sensor has 1/2"-NPT threads, the Vortec heads are 3/8"-NPT
the LS is 12mm
There isn't enough material to modify the original sensor to 12mm (.472")
here's a cut-away of an original sensor, the small end is .550" diameter.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-16-2023, 06:15 PM   #4
kglowacky
thanks, I was thinking you were doing machining for LS1 heads. My mistake.
Old 07-16-2023, 06:54 PM   #5
A1971Blazer
no worries…I wish they would work
1967 C10 Step side
1968 C10 Step side
Old 07-22-2023, 01:39 AM   #6
Accelo
Accelo's Avatar
I used one of these.
https://www.amazon.com/Engine-Adapte.../dp/B015NG418C
Seems it would change the calibration because it extends out so far.
I have not had any issues with mine.
Others use the LS part and connect it to the original system.
Maybe someone can find the link as I had no luck.
Cheers
Accelo is offline   Reply With Quote
Old 07-22-2023, 04:23 AM   #7
mongocanfly
mongocanfly's Avatar
I do what ls short box did...drill/tap pass head to npt..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-22-2023, 07:15 AM   #8
Joyridin
Cheers
I had one of those on my LS3. It did not work real well. After driving for a bit, the adapter would heat up and I think the sensor was picking up that temperature instead of the coolant.
Joyridin is offline   Reply With Quote
Old 07-31-2023, 12:57 PM   #9
JMac11
JMac11's Avatar
I drilled and tapped water pump for correct sending unit.
JMac11 is offline   Reply With Quote
